Old 09-21-2023, 12:42 PM   #5326
leegreen
Re: What did you do with your truck today, Part 3
In use it is more about squeezing many times and moving it around than brute force, not sure vice grip compound action would be better, but I think the locking feature would be a detriment.
The piece that goes inside the gutter has to be smaller than the finished profile to fit into the gap, so over-doing it would give you a stretched section that you would have to deal with.
I was pretty much able to get to 'metal finished' but probably spent a hour or two on each side.
leegreen is offline   Reply With Quote
Old 09-21-2023, 05:17 PM   #5327
unclebrad
unclebrad's Avatar
Just got the tires mounted onto the new wheels and got them onto the truck.
NVRDONE - Yes, for now, I have 6 lug on the back (original rear axle) and 5 on the front. As you can see, it isn’t visible with the hubcaps on there. Rear axle upgrade is on the list but won't happen soon.
55 Cameo w/ 409/700r4
unclebrad is offline   Reply With Quote
Old 09-21-2023, 05:56 PM   #5328
Tempest67
Tempest67's Avatar
beautiful looking truck there uncle Brad
Tempest67 is offline   Reply With Quote
Old 09-21-2023, 08:12 PM   #5329
mr48chev
mr48chev's Avatar
I mowed my way through the weeds to get to mine today. Now I need to pull weeds behind the sailboat to get to the shed that I have alot of the parts stashed in.
I did open the hood on the truck to get some photos for someone.
My ongoing truck projects:
Old 09-22-2023, 12:46 PM   #5330
_Ogre
_Ogre's Avatar
looking good uncle brad! perfect would be 4 headlights, but i'm just being picky there
shop air compressor timer
Old 09-22-2023, 01:26 PM   #5331
unclebrad
unclebrad's Avatar
Ha! Guess I'll have to settle for slightly less than perfect. ;-)
Old 10-08-2023, 08:42 PM   #5332
fauXGT
fauXGT's Avatar
Running out of nice weather, so decided to paint the firewall so I can drop the engine in next weekend. Then spend the winter wiring and plumbing.
Then paint the rest of the exterior in the spring.
Chip
'51 Chevy 3600 5 window
C4 Vette front/rear suspension & drive train
full Rusto-Mod
'92 GMC Sonoma GT VIN #0015
'91 GMC Sonoma GT extended cab 1 of 1
fauXGT is offline   Reply With Quote
Old 10-08-2023, 10:36 PM   #5333
Kansas T
I finally painted my frame.
1952 Chevy 3100 "work in progress"
Kansas T is offline   Reply With Quote
Old 10-08-2023, 10:41 PM   #5334
dsraven
feels good I bet/
Old 10-09-2023, 10:45 AM   #5335
Russell Ashley
Russell Ashley's Avatar
Man, that thing is beautiful, and knowing it has a 409 under the hood adds to the beauty. It's hard to believe that people used them hard, like any other pickup, but they did. I guess that's why there's so few nice originals left.
Russell Ashley is offline   Reply With Quote
Old 10-09-2023, 10:49 AM   #5336
Russell Ashley
Nice. That truck is going to get attention when it's done.
Old 10-09-2023, 01:58 PM   #5337
mr48chev
mr48chev's Avatar
For now all that means that if you go any distance you need to carry a second spare to match the front or travel with a buddy who carries one that will fit like my buddy used to do. We never needed it for his car but my having a spare that fit his car that didn't have room for one solved the issue.
That is a great looking truck and exactly what I was wanting in 1974 when I had a real want for a Cameo.
Old 10-09-2023, 05:10 PM   #5338
dsraven
or a multipattern wheel. wont likely need it but good to have if you do.
Old 10-14-2023, 05:17 PM   #5339
1project2many
Today I took the truck out for a drive with my son. It's so nice when everything works. At the hardware store I spotted a '54 that was a mix of new and old tech. Ended up meeting the owner and getting to swap truck stories for a bit. Nothing special for the truck, but a nice fall day for me and for my son.
1project2many is offline   Reply With Quote
Old 10-15-2023, 11:49 PM   #5340
fauXGT
fauXGT's Avatar
Got the engine back from the shop yesterday(bro-n-law), and prepped and painted today.
Next weekend mating with transmission and slipping into the truck.
Chip
full Rusto-Mod
Old 10-16-2023, 08:58 AM   #5341
my56chevytruck
my56chevytruck's Avatar
very nice looking ride
RUBBER DOWN AND HIT THE ROAD!!!
1940 Ford Dlx Coupe
1969 Mach1
my56chevytruck is offline   Reply With Quote
Old 10-16-2023, 08:31 PM   #5342
lgh1157
Sanded my roof
Bolted up my new wheels and spare
Got my blinkers working ( reversed polarity flashers with a ground )
lgh1157 is offline   Reply With Quote
Old 10-17-2023, 06:24 PM   #5343
nvrdone
put it to work! went to Lowe's and picked up some roofing materials for a shed I'm building.
49 chevy 3100 3 window. 327 / m21 4 spd, 12 bolt w/ 3:55's
Bought in 1973 for $235.00. Had it longer than my wife & Kids!!
nvrdone is offline   Reply With Quote
Old 10-20-2023, 07:41 AM   #5344
Oldtruckwelder
Oldtruckwelder's Avatar
First time moving on it’s on power in decades.
Test ride through the neighborhood went well.
JT from SC
Oldtruckwelder is offline   Reply With Quote
Old 10-20-2023, 08:36 AM   #5345
dsraven
Cool. That's a milestone. Great job.
I like the seat, been there a few times myself.
Old 10-20-2023, 08:37 AM   #5346
dsraven
Old 11-02-2023, 08:39 AM   #5347
Oldtruckwelder
Trying this bodywork gig again with filler over SPI Epoxy vrs over bare metal.
A little back story.. years back I had started this project with filler over bare metal and covered in red oxide primer. Life got in the way and truck was stored in a non climate controlled shop for years.
Starting over I discovered that the red oxide primer was a thing of the past so all panels were stripped down to bare metal again. I found rust forming under the filler which I’m sure would have caused failure to the paint system down the road.
I have heard lots of discussion about filler first vrs primer first.
I essentially had created my own science experiment with the truck being stored all of those years. I’m aware that the red oxide primer and filler are porous which probably contributed also.
Hopefully will be able to finish the project this time.
JT from SC
Old 11-02-2023, 09:26 AM   #5348
leegreen
looks good!
There are 2 reasons I was able to keep my 40+ year project and restart it a few years ago. Free storage (outside). I sprayed enamel over the unfinished body work inside and out before storing it outside uncovered for what was planned to be 1 winter.
keep after it and get it on the road!
Old 11-02-2023, 10:14 AM   #5349
dsraven
great science project results. thats why I do the epoxy first too.
what do you have left to do on the project, just body or are there other items on the list?
if you could post up some full frontal, side and rear pics that would be great. always good to follow along and see another project in action, it keeps the rest of us fired up on our stuff.
Old 11-02-2023, 10:14 AM   #5350
dsraven
