11-02-2013, 10:34 PM | #526 |
Re: Project: Bad Bagged '68.5
Here's a couple more views.
11-02-2013, 10:45 PM | #527 |
What was I thinking?
Great job everything looks awesome!
Justin '68 C/10 Custom Long wide bed '78 GMC Sierra short wide Project: Second time around...'68 short wide http://67-72chevytrucks.com/vboard/s...d.php?t=423949 |
11-02-2013, 10:53 PM | #528 |
11-03-2013, 12:33 AM | #529 |
A guy with a truck
Killing it. Great work
-Chris Instagram _elgringoloco_ '70 Short-Wide How to: Ruin a perfectly good C10 ‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd '72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD) '72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD) '05 Yukon Daily Driven (not so stock) Yukon (SOLD) ‘07 Yukon Denali (daily) Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy |
11-03-2013, 08:19 AM | #530 |
just went through entire build, looks great!
11-03-2013, 10:27 AM | #531 |
just went through the whole build. nice work man! coming along! killer!
build thread - 1972 C/10 "Ethyl" 1974 C/10 " Paw Paw" C/10 Club Louisiana instagram - @esso_c10 @projectpawpaw |
11-03-2013, 08:38 PM | #532 |
Thanks guys! I can't believe you went through the whole build. That must of took FOREVER!
11-03-2013, 09:52 PM | #533 |
Nice work
"The way it is" truck build http://67-72chevytrucks.com/vboard/s...d.php?t=359200 |
11-04-2013, 07:48 AM | #534 |
Village Idiot....
VERY VERY nice !!
http://www.hubgarage.com/mygarage/n2billet -67 SWB Custom Porterbuilt Front and rear 20/22's Hazel Sold -71 StepSide Porterbuilt Stage 2 with 20/22's Stella Mae Sold |
11-04-2013, 09:29 AM | #535 |
Nice job, looks great
Keith 66 Suburban Burb Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=751361 IG: bennett68c10 |
11-04-2013, 10:27 AM | #536 |
I'm just glad to be here!
I really dig the bumper mounts! Like how the bed mounting frame is done too. Great work!
Karl 1965 Chevy Stepside(Grandpa's Old Blue) and (July 2015 Shop Build!)(2020, the Saga Continues) http://67-72chevytrucks.com/vboard/s...d.php?t=372424 The LST Challenge: http://67-72chevytrucks.com/vboard/s...=1#post7812257 Korbin's 1st Square: "Sunburn" http://67-72chevytrucks.com/vboard/s...d.php?t=418618 1985 GMC Sierra: "White Trash", Korbin's 2nd now... http://67-72chevytrucks.com/vboard/s...d.php?t=632305 Henry - 1984 Chevrolet, Owen's 1st Square |
11-09-2013, 10:44 PM | #537 |
Re: progress pics
Hey r u using factory contol arms?
11-11-2013, 02:56 AM | #538 |
11-11-2013, 08:25 PM | #539 |
Wow! First time I've come across this build. Your metal work is just ridiculous. Possible relative of ebfabman I think. Great creativity and imagination ill be following from here on out. I'm nervous about a little rust repair. I better just dive in and figure it out as I go.
Scott 67 c10 sold 89 c1500 90 k2500 91 s10 #chevyonly |
11-11-2013, 08:26 PM | #540 |
Forgot to mention your flawless hard lines you bent...
11-11-2013, 09:14 PM | #541 | ||
Nope, I have ride tech arms.
11-11-2013, 09:31 PM | #542 |
11-12-2013, 12:05 PM | #543 |
67cheby
amazing work !
11-14-2013, 12:00 AM | #544 |
Great job!
72 Cheyenne shorty "CheyLow" 72 3/4 long 4X4 69 SWB "Prospector" 68 C/10 shorty - "Picacho" http://67-72chevytrucks.com/vboard/s...d.php?t=428379 sold to "93redsled" Have you heard about C10 Talk? C10 Talk is a podcast all about C10 Trucks, the builders, the vendors, and most importantly the C10 Community. Check us out online at www.c10talk.com |
11-14-2013, 04:25 PM | #545 |
Awesome build man, love the idea on the inner bedsides. Subscribed for sure
ANDREW 1972 Chevy SWB Cheyenne Super JANE http://67-72chevytrucks.com/vboard/s...d.php?t=462072 1972 GMC Jimmy PENNY http://67-72chevytrucks.com/vboard/s...d.php?t=735827 1968 GMC patina swb PEARL http://67-72chevytrucks.com/vboard/s...d.php?t=731315 1972 Chevy K20 BRUCE http://67-72chevytrucks.com/vboard/s...d.php?t=805788 1972 Chevy SWB Highlander OLIVE Build thread coming |
11-24-2013, 05:23 PM | #546 |
awesome build!....crazy attention to detail!
my build threads '86 C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415628 '67 C10 http://67-72chevytrucks.com/vboard/s...d.php?t=635078 '63 GMC http://67-72chevytrucks.com/vboard/s...d.php?t=674682 |
12-04-2013, 10:44 PM | #547 |
Was out surfin' to find a build to catch my attention.
Definitely has my attention! Following along |
01-21-2014, 11:05 PM | #548 |
Got a little something done on the truck today. I needed to make a bracket to tie the bed frame to one of the bed supports. Here is the area I was working with.
The bottom piece is 1/8" plate which will accept a nut and bolt. The top is 1x2 .125 wall tubing which I wanted to put a threaded bung in. I picked these up from Summit. The have a lip on them which I cut off for this application. Next step was to design a bracket. Here is what I came up with made out of 3/16 plate. The upper two holes are slotted to allow adjustability in the height of the bed for final fitment. Next step was to drill some holes. If you guys dont have rotobroach's, GET SOME! They are one of those things that once you get them you will ask yourself how you lived without them. They cut like butter. Leave the bimetal hole-saws for wood! For this job, I used the largest size in my kit which was .75 inch...same diameter as the threaded bungs. OK, next step was to weld in the bungs. I had to figure out a way to make sure the bungs were welded in perfectly straight and square. So I came up with this little tool...a simple steel plate with some a hole for a nut and two more to expose an area to put a couple tack welds. The plate is clamped to the work surface to hold everything tight. Here it is clamped in place and ready for a couple tacks. Notice the chamfer on both the bung and the hole...and little vasoline for anti-spatter. Tacked and then tool removed and tacks ground smooth. AND THE MONEY SHOTS! Enjoy...let me know what you think. |
01-22-2014, 11:18 AM | #549 |
very nice Jlaird
"Fear makes the wolf look bigger" http://67-72chevytrucks.com/vboard/s...d.php?t=305629 |
01-22-2014, 04:06 PM | #550 |
Looks goo, I like your idea on this.
Personnally, I would reshape the angle iron bracket it bolts to so that it "hides" behind the outter bracket.
