Old 03-01-2011, 12:18 AM   #526
Bruce88
Bruce88's Avatar
Re: It’s Just A Pickup
Originally Posted by mcbassin View Post
Nice work on the seatbelt installation. Great idea. Couple of questions, did your cab come with shoulder belts? If not, how did you do the upper anchor points? is there a re-inforcement welded in? I can't tell from the pictures. thanks
From what I’ve seen in the Factory Assembly Instruction Manual all of our truck cabs have a reinforced 7/16 – 20 nut plate in the upper corner. Trucks without the shoulder belt option just have a plastic cap covering the nut.
My Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=318544
Bruce88 is offline   Reply With Quote
Old 03-04-2011, 05:34 PM   #527
Bruce88
Bruce88's Avatar
What’s with the confusion some have
Some of it is understandable and some is just a lack of information
The electrical wiring of the windshield washer & wiper motor seem to cause problems for some. When their trying to troubleshoot why it’s not working or how to hook it up with stock wiring and sometimes wiring it from scratch.
The electrical circuit is basic but with a twist, normal on other circuits the power is controlled thru the switches but on the wiper circuit the ground is controlled thru the switches. You need to keep this in mind when understanding or troubleshooting the system.
There’s a good how to (Testing Windshield Wiper Motors) by LockDoc on this forum http://67-72chevytrucks.com/vboard/s...d.php?t=413551 . I did run into a word that I was not familiar with concerning wiper motors (Non-depressed park motor or depressed park motor). What’s that mean and how does it apply to my installation? Well hears a definition that might help, on a non-depressed park motor when the wiper is turned off the motor will park the wiper blade at the bottom of the window. With a depressed park motor when the wiper is turned off the wiper blade is moved below the window into a stowed position under the cowl or hood (normally found on newer cars and trucks). Our 67 – 72 trucks only use a non-depressed park motor.
The wiring diagram has a small error that could cause a problem especially when wiring with a non-stock wiring harness. The diagrams show the power wire going to the center terminal of the three terminals on the motor, this is the wrong terminal (see picture below)
The factory prevented wiring the wiper motor wrong with a special connector and terminals on the motor. The connector has a open slot on one side so that when it’s put on the terminals the small bent tab on the terminals will allow the connector to go on in one way only. If you try to put it on wrong you will probably break the connector or bend the terminal, but we all know some people will try (smile)
You’re not going to see a bent tab on the #3 low ground terminal or slot it’s just a single wire connection. On the washer pump connection the connector has the open slots but the pump terminals (not shown) may or may not have the bent tabs on the terminals. It doesn’t mater how you connect the pump, it’s a electro magnetic solenoid and will work as long as it has power to one terminal and a ground on the other regardless how it’s hooked up.
As you go down to the parts store to get a wiper motor, the first question the parts man asks is what do you need a 3 terminal or 4 terminal wiper motor, (he doesn’t know) both wiper motors can be used and the only difference is a extra terminal not used on your installation. So the answer is what one do you have in stock and do they mind if the one you turn in (Core charge) doesn’t have the same number of terminals. Why the extra terminal I don’t know, possibly the 4 terminal motor is also used on another car or truck. The extra terminal is a jumper terminal to the #2 power terminal.
The gasket that goes between the wiper motor and the wiper mount, I picked up from LMC. To give some more sealing in this area I put some glass ribbon sealer on the edge of the wiper mount and after the motor was in smoothed the seal out with my finger on the outside area. Maybe this will help prevent any leaking, the installation drawing doesn’t show any seal being used.
A couple of pictures from a view point that you normally can’t see. As I was loading up the dash with some of the parts that go in there and before the steering column was installed or wiring harness. It definitely gets tight in there fast (smile).
May your wipers always work well when you need them, in my state I need them a lot (smile).
Enjoy your build
Old 03-08-2011, 02:03 PM   #528
Seventy Two
As always, yours thread is very informative. Thanks Bruce!
Seventy Two is offline   Reply With Quote
Old 03-09-2011, 02:22 PM   #529
raider65
raider65's Avatar
Awesome pics keep them coming
It's not rust...It's character!
raider65 is offline   Reply With Quote
Old 03-09-2011, 05:09 PM   #530
waylon.brown1
WOW!! just found your thread! subscribed!!
Waylon
waylon.brown1 is offline   Reply With Quote
Old 03-12-2011, 11:55 AM   #531
Hottrucks
Redefining LowBudget
Hottrucks's Avatar
any pics of the headliner done ??
never mind found them what do you think of it?? I just wish it was a compartment instead of a cb mount
heres a link to the head liner for those interested
http://www.ioffer.com/i/67-72-chevro...shell-62810236
1970 C10 CST fleetside 472 ....big dreams little cash...
SunShine Syndicate..
Mikes Sandwich Fair Run OCT 8th 2011
Hottrucks is offline   Reply With Quote
Old 03-12-2011, 04:19 PM   #532
Bruce88
Bruce88's Avatar
Hi Hottrucks
My headliner did come with a cover for that area of the headliner (see below picture). You could cut a hole and make it a small compartment to put things but I think it was with the thought to put the radio in the headliner and it would be covered by the cover and give a place to drill the holes for the radio mounting (see installation picture below).
I know that a CB seams out of date today by many but I wanted one and this was where it worked for me. There was two problems with using the cover with the CB. (1) The CB is longer than a radio and mounts differently. (2) The speaker for this CB is in the bottom of the CB case and the cover would cover it.
I did modify the headliner a small amount to be able to use the CB in that area. I did place a 3 inch x 8 inch peace of sheet metal on top of the plastic headliner to spread the load of the CB mount, CB’s are generally heaver than a radios and with two screws going up into the plastic I didn’t want the CB falling down. On both sides of the area I drilled some holes to be able to install the screws from the CB mount to the CB case and then covered the holes with some plastic caps. I also put a hook between the speakers to hold the mike cable out of the way. Ref back to the install post #500 on this build thread http://67-72chevytrucks.com/vboard/s...318544&page=20
Another one of those modification I didn’t talk about or show, sorry about that I just didn’t think (smile). For me I liked the way it turned out everything is up and out of the way.
Old 03-12-2011, 04:38 PM   #533
Hottrucks
Hottrucks's Avatar
thanx I'm Oh to familair with CB's hanging from the ceiling I drive a BIG truck everyday ...they now make a zip cord that pulls back in for the cb cord check your local truck stop they work well to keep the cord from slapping you around
thanx for the info
Jeff
Old 03-12-2011, 09:43 PM   #534
ivanuf2
ivanuf2's Avatar
Subscribed. The best built on the forum
ivanuf2 is offline   Reply With Quote
Old 03-21-2011, 10:17 PM   #535
chevytruckluver
Eat, Sleep, Drive a Chevy
chevytruckluver's Avatar
any updates Bruce?
Trey
Silence may be Golden, but Duct Tape is Silver!
72 Short Step
57 "big window" short step
chevytruckluver is offline   Reply With Quote
Old 03-22-2011, 05:42 AM   #536
Bruce88
Bruce88's Avatar
Originally Posted by chevytruckluver View Post
any updates Bruce?
Not really Trey unless you want to see some pictures of my yard (smile). Been mainly doing spring yard cleanup and those outside jobs around the house after coming out of winter.
Did find some time to run a few of the wires under the dash but not done with them yet.
There is one little thing, I didn’t like how the stock speedometer cable was routed it seemed to me that it needed to be a little bit longer. Was unable to find a speedometer cable the desired length so I plan on using a Lokar (SP-1500U) U-Cut-To-Fit speedometer cable kit. I found a problem with the Lokar instructions and sent them an e-mail with a possible correction to the instructions. (Hear is the e-mail and pictures posted below)
A possible problem that might exist for some with your U-Cut-To Fit GM & Chrysler Speedometer Cable Kit Installation Instructions.
I understand that this kit is a universal kit for GM & Chrysler speedometers with a 5/8 – 18 threaded ends and a transmission with a 7/8 – 18 threaded ends. But not all speedometers with a 5/8 – 18 threaded ends have the same end configuration.
I’m installing the Lokar SP-1500U speedometer cable kit on a stock 1972 Chevy C10 truck speedometer with a 5/8 – 18 threaded end. The Speedo cable tip does not sit flush with the Speedo end fitting. If I fallow your instruction (step 4) and mark the inner cable at the end of the fitting and not subtract the additional end that sticks out past this surface the cable will be binding inside the outer cable, if I could get it on (see attached picture).
I plan on subtracting .321 from the mark made per step 4 and cutting the inner cable there (not flush with the end). Per my calculations this should give me 1/16 to 1/8 inch free play to move back and forth and prevent any binding condition.
Not all speedometers are made the same and the .321 dimension above is just on my installation, other cars and trucks may have different dimensions. But if there is an area that extends out past where the surface that the Speedo end fitting will sit it needs to be taken into consideration before cutting and crimping the inner cable.
Possibly a note on step 4 that this condition might exist and needs to be checked and calculated into where to cut the inner cable. After the cable is cut and crimped it’s too late.
Hope you find this information a benefit to installing your speedometer cable kit for others.
Bruce
I should be able to post some updates on the build within a week or two. Hope this tidbit of information wets your appetite (smile)
Enjoy your build
Old 03-28-2011, 05:17 PM   #537
Bruce88
Bruce88's Avatar
Bending and twisting
Then looking for a comfortable position to see and do the work
All the wiring and parts are installed under the dash except the speedometer cable.
Glad to be out from under the dash and the wiring around the fuse block might not
look the best but it’s functional. I think that I just about maxed out the stock fuse
block with the added circuits and rerouting of some of the wires. I did put some
small labels on the added wires down at the fuse block to help identify the new
circuits. This should help in the future in remembering where all the wires run if I
ever have to figure out a problem (Hope not, but you never know) (smile).
Possibly a let down on documenting this post with all the new parts used. There
are plenty of small parts like little rubber bumpers, fire wall insulation, air ducks
and so on that where used. More than I feel like listing.
For those interested in the added wires and rerouting of some you need to look back
thru this build thread and you can see the wiring drawings that I made to help me
figure out how I was going to do it.
There’s so much going on behind this basic looking dash and the pictures probably
don’t show all the work that went into it, but hears some pictures I hope you find of
interest.
Size:  100.8 KBName:  Dash-2.jpg
Size:  99.8 KBName:  Wiring-2.jpg
There’s plenty of wiring to do outside the dash area all the wires and lines added are
just run thru the firewall and still need to be hooked up. Onto the speedometer cable,
floor shifter, and floor covering. I better get to work (smile).
Enjoy your build
Old 03-28-2011, 05:20 PM   #538
70LonghornCST
Moderator
70LonghornCST's Avatar
Mr. Clean aint got nothing on this truck. OUTSTANDING!
2018 Chevy Crew Cab
2006 Impala SS
1965 Plymouth Sport Fury
1970 Chevy Longhorn
  • Bucket Seats
  • Shoulder Belts
  • Front Tow Hooks
  • Factory Air
  • Factory Speedwarning, Tach & Vaccum
  • Factory Tilt
  • CST Package
  • AM/FM Radio
  • Bumper Guards
Richard
70 Longhorn CST Build
Adding an AM/FM Decal
70LonghornCST is offline   Reply With Quote
Old 03-28-2011, 05:23 PM   #539
VA72C10
VA72C10
VA72C10's Avatar
nice work as usual!
Looking for a 67-72 swb or blazer project in or around VA.
VA72C10 is offline   Reply With Quote
Old 03-28-2011, 06:47 PM   #540
JasonBird
'67 C-10 LWB Driver
JasonBird's Avatar
looks like new Bruce! keep up the great work! your posts are very informative!
'67 C-10 LWB - My Build Thread
'67 C-20 LWB - My Donor/ Parts truck - SOLD!
'92 GMC SAFARI VAN - My Parts Go Getter
'06 KIA SPORTAGE EX - My Commuter
"All of this crap better make a truck!" - my wife Sue.
Proud U.S.M.C. Dad!
JasonBird is offline   Reply With Quote
Old 03-28-2011, 09:33 PM   #541
FRENCHBLUE72
PROJECT 7DEUCE
FRENCHBLUE72's Avatar
Nice job the wiring looks great.. Did I miss it or is there a reason the needles are different colors?
GO BIG GREEN GO DUCKS
MEMBER #6377
Project "7DEUCE"
Old 03-29-2011, 12:11 AM   #542
Bruce88
Bruce88's Avatar
Good eye for detail, the speedometer is a very light/faded orange from age and the fuel gage is new. Give the fuel gage 30 years and they should look the same (LOL). One of those little details I didn’t take care of when I rebuilt the instrument cluster. I’m just going to live with it for now.
Old 03-29-2011, 12:07 PM   #543
propanemudtruck
Local Redneck Authority
propanemudtruck's Avatar
I imagine we'll live with it too then...
As always, great clean build and perfect documentation!
-Kevin
four on the floor feel the beat in your soul
movin to the rhythym pumpin til ya cant take no more
dance if you want to do what you came to
you cant ignore the feeling of that four on the floor
propanemudtruck is offline   Reply With Quote
Old 03-29-2011, 04:35 PM   #544
nuke1
nuke1's Avatar
Your builds and attention to detail always amazes me!!!
James
1968 GMC "HAVOC"
1986 GMC "Frank"
J.J.R.H. Design & Consulting
My 68`Rebuild "HAVOC": http://67-72chevytrucks.com/vboard/s...d.php?t=316300
A 58' chev build thread: http://www.67-72chevytrucks.com/vboa...d.php?t=311238
1969 Camaro Pro Touring http://67-72chevytrucks.com/vboard/s...61#post3513361
Swiss Cheese: http://67-72chevytrucks.com/vboard/s...d.php?t=384390
Adjustable Trailing Arm How-To: http://67-72chevytrucks.com/vboard/s...d.php?t=321100
1968 Ford Farm Truck: http://67-72chevytrucks.com/vboard/s...=1#post6555587
nuke1 is offline   Reply With Quote
Old 03-29-2011, 04:50 PM   #545
gcburdic
Restoration Virgin!
gcburdic's Avatar
Awww Bruce....with all this detail and you forget to do this it's a quick fix...I say go ahead and paint it bright
Geoff with a G
1968 Chevy C10 SWB The Mistress
1972 Custom Deluxe C20 Suburban A Suburban Named Isabella
1966 Ford Mustang Mama's High School Graduation Present
gcburdic is offline   Reply With Quote
Old 04-01-2011, 01:47 PM   #546
DesertCat
DesertCat's Avatar
Hey Bruce, nice build and excellent documentation!
What length did you end up with for your speedo cable?
DesertCat is offline   Reply With Quote
Old 04-01-2011, 04:51 PM   #547
Bruce88
Bruce88's Avatar
Hi DesertCat
I haven’t installed or cut the speedo cable at this time but when I do I will post the length I ended up with.
I did contact Lokar concerning cutting the cable (see post #536) and their response from the tech department was that they had never run into the problem noted and was sending the information to their research and development department to take a look at it.
I think that my approach that I will use as stated in post #536 will work and plan on using it when I cut the cable.
Hopefully I will have that information for you in a week or two. I’m just slow some times, OK a lot of times (smile), and there’s some small little problems that have cropped up that I’m taking a look at (not associated with the speedo cable), that I like to take care of at the time they crop up. Sometimes in a build minor tweaking of a plan as you put it together is needed for my self satisfaction with the end results.
Enjoy your build
Bruce
Old 04-02-2011, 12:54 PM   #548
67cheby
67cheby
67cheby's Avatar
if you arent writing "HOW TO" manuals for a living i think you are missing your calling ....SUPER NICE WORK as always
67cheby is offline   Reply With Quote
Old 04-02-2011, 02:06 PM   #549
Riveted1
Tasty Cakes!
Riveted1's Avatar
I agree with 67cheby! Reading your thread is like going to school to learn how to rebuild these trucks! Thanks and keep up the awesome work!
I'm a little and a lot
Ground beef: A cow with no legs.
'66 Chevy SWB "Penny"
'67 Chevy Big Window SWB- aka "Pearl"
'72 Burb- "Betty" "It's not a hearse dammit"
'99 Chevy Ext. cab Silverado
Riveted1 is offline   Reply With Quote
Old 04-03-2011, 02:17 PM   #550
Bruce88
Bruce88's Avatar
Not necessarily speeding along with the build (smile)
But hears the info on one small part, the speedo cable
Breaking out the tape measure, the stock speedo cable that came with my truck measured out at 63 inches with a 7/8 – 18 threaded end on the transmission end and a 5/8 – 18 threaded end on the speedometer end.
I looked at how the stock cable was routed from the factory and the stock 63 inch cable could be used even with the 700R4 trans that I’m using. But I didn’t like the shaper bend that is needed at the fire wall grommet, this area is normally a sharper bend on the stock installation than the rest of the run. I’m of the opinion that the speedo cable should have a consistent curve/bend to the run, with this thought in mind I would need a little longer speedo cable.
Then the disappointment at finding one that fit my needs set in. After going around to a number of different parts stores in my area (no I’m not going to list them), I found that a number of different length speedo cables where listed for our trucks (this can be found on the web stores too). Things I didn’t like about the cables that I looked at, I found that some didn’t measure out in length as what was on the box or per part number specks, some shorter and some longer by inches and even feet. All the cables looked to be a cheaper version than the stock cable, smaller outside DIA and made outside of the US and none of them came with the fire wall grommet install on them. Maybe my standards/expectations are to high and the cables, if I could find the right length would work just fine, but didn’t find one that was close. With this experience I didn’t want to order one over the web, not knowing what I would be receiving, maybe some of the same problems.
Decided to go with a Lokar SP-1500U U-Cut-To-Fit Speedometer Cable. This cable has a high cost about $70 but is of very high quality exceeding a stock factory cable and I can get the exact length that I want by cutting it to that length. See previous posts #536 & #547 concerning the minor problems I ran into regarding cutting this cable.
One of the problems that I’ve run into in the past concerning installing a new speedometer cable is finding or installing a fire wall grommet on the assembled cable, getting the grommet over the cable end fitting. A trick that I’ve used before and works for me is to use a electrical grommet and a short length of tube. (See below picture)
Hear are some pictures of the cable installation. Normally the speedo cable is held in place by two clamps, one on the cab body and one on the frame. Decided not to use the attach point on the cab body because it held the cable to close to the body causing a sharper bend in the cable at the fire wall grommet. I might add a small bracket and clamp to the brake booster brace for added support. You might not find this brace on all of our trucks. As to what length of speedometer cable did I ended up with, it is 66 ½ inches long.
As I hang my head down in shame (smile) Ill be pulling the instrument panel and painting the speedometer needle. Thanks guys for seeing that detail I should have done when I cleaned up and rebuilt the instrument panel such a long time ago. Keep an eye on me and make sure I don’t miss anything.
Enjoy your build
