Old 09-10-2009, 11:30 AM   #526
68 TT
Still plays with trucks
68 TT's Avatar
Re: Glock's new project: "Fred"
Another option is to use the Astro van A/C compressor. It is a smaller more compact unit than is used on the other GM vehicles of the time that looks a lot like the Sanden unit.
You may be able to snag the mount brackets off of the Astro van and modify them to work in conjunction with the stock LS brackets to make your own high mount kit on the LS engine.
I would see what they did in the $400 kit and make similar parts to use the Astro van compressor. They are inexpensive, easy to get and a factory GM part you can get over the counter anywhere in the country they sell GM parts.
You can get them as R-12 or 134a compressors too so if you are doing a retrofit like yours with most of the stock R-12 system in place you could stick with the R-12 version and not deal with the conversion issues.
68 TT is offline   Reply With Quote
Old 09-10-2009, 01:58 PM   #527
glock35ipsc
Next project: 1970 K10
glock35ipsc's Avatar
OK, I decided to go with the high side kit. The time I put into modifying the motor mount was all for nothing, but I'm not upset. It led me to find out that other ways do exist.
So... that means unless you really want to modify the engine stand, the adapter plate, notch the frame, and reroute the trans cooler lines.... you can simply use the adapter plates I used and have everything else literally fall into place. I'll just wait until next month to get the bracket kit and the compressor since the weather is kind of cooling off now.
I ordered two new gas tanks from Rock Auto a little bit ago (1987 tanks with the baffles). I also ordered an adapter from Street & Performance to mount the coolant temp sending unit for the gauge in the rear of the passenger head. The adapter screws into the M12x1.5 hole in the head, and they come in 1/8 NPT, 1/4 NPT. 3/8 NPT and 1/2 NPT. I needed 3/8 NPT for my stock sending unit.
And as I was typing this, UPS showed up with the 5/16" and 3/8" FI hose and the FI clamps. Guess I know what I am doing this weekend!!!
I also drew out my fuse block setup, along with the relay wiring I'll need to do for the fuel pump and the electric fans. Easy stuff, but I like having it on paper to refer to. I'll end up with a 4-fuse block (3 ignition and 1 battery hot to the 2006 harness), along with 1 relay for the fuel pump and 2 relays for the fans (1 lo, 1 high)
Bob
1970 Chevy K10 LWB "Goldie" 350/TH350 next project!!
1981 Chevy C10 LWB 355/TH350 - My son's truck
LS SWAP FORUM! Tons of LS swap info here!
PLEASE CLICK HERE TO SUPPORT THE GREATEST BOARD ON THE NET!
CLICK HERE FOR THE FAQ INDEX by KRUE
glock35ipsc is offline   Reply With Quote
Old 09-10-2009, 08:07 PM   #528
menace121978
menace121978's Avatar
man... i have been waiting to post until i see the a/c set-up. so the tbss compressor wont work? what other ls combo has a high side a/c compressor?
i'm asking because as you know i havent bought mine yet... and i'm thinking if there isnt another affordable ls powerplant out there with the highside a/c this might change my mind ($$)on the swap. $400 for the pulley mount + the compressor?...
your really doing it the right way by getting the '87 tanks too Bob... i have it wrote down in my notes somewhere to do the same. but its just getting pricey.
iduno, this has really got me thinking...
$1200 700r4
$1200 heads
$200 cam
$200 serp set-up
$200 a/c compressor
whats your thoughts? i'm going to find out what gen III has a high mount a/c... maybe 6.0's?
"Dennis the Menace"
1978 Silverado (2wd, 1/2 ton, short bed)complete nut & bolt frame off restomod LQ9/4L80E
MY LS SWAP/FRAME OFF BUILD BOOK
2006 TBSS way too much to list
menace121978 is offline   Reply With Quote
Old 09-10-2009, 08:44 PM   #529
glock35ipsc
I have a link on my puter at work that I will post for you tomorrow. A guy took a pre-Vortec 4.3 V-6 mount and modified very easily to accept the smaller radial type compressor that Fred originally had. It looked like it belonged there, and was installed on a Gen III. It's just not what I want to do.
I'll also post a pic of an TBSS compressor that was mounted on a Gen III block. It didn't look like it mounted directly to the block, which I thought it would, but it looked like the made 4 adapters to go on each bolt hole.
The problem with using one from the other LS setups, which would be from a car, is that they all sit closer to the front of the block. Example, using strictly made up numbers.....where the truck serp belt would sit 4" in front of the head, the car belt would be 2". The pulley alignment would be way off.
BUT, you could certainly use the entire front of another LS setup, LS2-3-6-7. I think I have drawings of the different car setups and where each item lives, I'll post those tomorrow too.
**EDIT:
I just read this part again. The bracket kit is $197, and I found compressors for as low as $145 today. Current Performance sells the compressor and bracket kit together for $397.
For me, spending the $350-$400 is worth it versus messing with the frame in this location, plus having easier access to the compressor for servicing, not having to reroute ($$) the tranny cooler lines, and using a better proven compressor.
Bob
Old 09-10-2009, 08:58 PM   #530
glock35ipsc
Originally Posted by menace121978 View Post
........but its just getting pricey.
, it only gets more expensive as you go! I was well in to the 5 figures on the 68, and it wasn't close to being done!
$1200 700r4
$1200 heads
$200 cam
$200 serp set-up
$200 a/c compressor
Are these figures for your current engine, or a 'budget' list for an LSx?
Take a look as you Goat, I would think that might be higher.
Bob
Old 09-10-2009, 09:07 PM   #531
menace121978
thank you Bob!
those figures were for the crate 350 i have...
$400 for the entire setup isnt too bad... i'll look at the goat tonight.
"Dennis the Menace"
Old 09-10-2009, 09:55 PM   #532
glock35ipsc
I just read this one a guys blog, so true!
One of my buddies believes there’s a law called, “The $200 Law”. Driveshaft? $200. Radiator? $200. Belts and hoses? $200. AC compressor? $200.
Bob
Old 09-10-2009, 09:56 PM   #533
glock35ipsc
Bob
Old 09-10-2009, 10:19 PM   #534
menace121978
thats how it goes... then there is that $1000 law when i want to do something to the goat! i swear everything on that dang car is 1k.
we'll see how it goes... the more i think about it, the top mount kit isnt too expensive... and also going that route i wont need to have a special someone modify the engine mount table or cut the frame. which also saves a few bucks.
SOMETIMES IT JUST SEEMS SO MUCH SIMPLER TO PUT THE OLD 350 BACK IN W/ A PAINLESS WIRE HARNESS
"Dennis the Menace"
Old 09-10-2009, 11:17 PM   #535
clinebarger
That law really takes effect when you get a boat= Break Out Another Thousand.
clinebarger is offline   Reply With Quote
Old 09-11-2009, 07:29 AM   #536
nlped
nlped's Avatar
^^^ Amen on the boat thing. It's just a hole in the water to throw money. Money I have set aside to throw at my truck...and Mustang...and the shop...and.....you get the point
Carter
1968 Chevy SWB Fleet... Walt
1963-1/2 Ford Falcon Futura...Martha
nlped is offline   Reply With Quote
Old 09-11-2009, 08:56 AM   #537
JohnC
JohnC's Avatar
....SOMETIMES IT JUST SEEMS SO MUCH SIMPLER TO PUT THE OLD 350 BACK IN W/ A PAINLESS WIRE HARNESS
There is easier, and doing something different. It's really a matter of opinion. Really from this thread Bob has made the swap look pretty easy. Yes a lot of homework, and $$. However, the end result will look sweet. On the flip side there are a lot of old school 350's in trucks that look sweet as well. My suggestion would be to lay everything out on paper, and really look at both setups. Then decide which is better for you, and the current project you are working on.
JohnC is offline   Reply With Quote
Old 09-11-2009, 10:03 AM   #538
glock35ipsc
^^^ Agree. Just FYI, by the time this swap is done, I will have probably right at $4500 in it. That's counting every last hose clamp, can of paint of degreaser, gauge cluster, AC stuff, gas tanks, harness rework and tune, etc.
Bob
Old 09-11-2009, 10:47 AM   #539
menace121978
thanks for the heads up on the $...
the goats compressor is mounted really low also. its hard to tell exactly how low because the way the motor mounts but it still looks low when i look at the frame rails of the truck. oh yea, did you already figure a way to mount the '06 radiator in there?
$4500 huh... i'm going to figure exactly how much $ it will be to get 300hp out of this 350 w/ a new 700r4 to see which route is more cost effective. i never plan on dd her... just shows and cruises so mpg is a mute point...
sorry to brain storm right in the middle of your build Bob!
"Dennis the Menace"
Old 09-11-2009, 12:05 PM   #540
68 TT
68 TT's Avatar
If you only want 300 hp out of a 350 then you can get away with a pretty inexpensive setup.
It all comes down to how you want it to look and if you want EFI or not.
A stock set of 1.94 valve run of the mill small block heads, a 280 degree hydraulic cam, an RPM intake & 600 to 750 carb with headers and a decent exhaust will get you 285 hp to the rear wheels. That is about 340 hp at the crank. I have run this combination on several vehicles and it sounds nice with just a little bit of a lope, runs great and is tame enough to use as a daily driver. You don't even need a stall converter with it.
You can freshen up a decent condition 350, install the required parts and build a good exhaust system for under $2000.
When you want aluminum heads and/or EFI things get expensive quickly and the LS engine becomes a viable option.
Old 09-11-2009, 12:14 PM   #541
joe231
joe231's Avatar
What kinda torque?
that is about the set-up I'm thinking but with a performer intake....285 at the rear wheels ain't bad
CHEVY ONLY
Old 09-11-2009, 12:39 PM   #542
mcbassin
Still Learning
mcbassin's Avatar
$4500 seems like a bunch of cash....but just the smooth power, fuel ecomony, and reliability may make it worth it, not to mention how cool this rig is going to be.
totally agree with this
Boat=bottomless money pit
This guy claims this engine is 300 hp model
Price seems pretty good but you'll have to add shipping.
http://cgi.ebay.com/ebaymotors/5-3-V...Q5fAccessories
mcbassin is offline   Reply With Quote
Old 09-11-2009, 01:01 PM   #543
glock35ipsc
My feelings exactly!!
Bob
Old 09-11-2009, 03:24 PM   #544
glock35ipsc
http://www.maliburacing.com/forum/vi...p?f=34&t=79059
Bob
Old 09-12-2009, 01:01 AM   #545
Driveway Dreams
I have car A.D.D.
Driveway Dreams's Avatar
Bob, I gotta put the rest of my bolts in my truck and hook up the wires and drive out to see Fred again. Coming along really nice. GOOD WORK!
-Gerald
Building vehicles in memory of the first "car guy" I ever knew, my Grandpa. Bob Dunham 1935-2009. Rest in peace.
61 GMC Suburban SOLD
The 86 build thread SOLD
Are you a Colorado member?Click here.
Driveway Dreams is offline   Reply With Quote
Old 09-12-2009, 01:07 AM   #546
menace121978
thanks for those reference pics... the tbss looks like it actually might work. the goats is way different w/ the inlets pointed more downward.
and i agree the ls swap is way cooler than a gen I 350
"Dennis the Menace"
Old 09-12-2009, 01:49 AM   #547
glock35ipsc
Thanks!! I'll be in the shop until 2:30 - 3:00 tomorrow. Come on out!
If I didn't already have everything together as far as I do now I would try a TBSS compressor. It would be really nice to try one on a short block to check for mounting and alignment and stuff like that.
I got a LOT done tonight! My wife took the kids to Colo Springs to pick up a friends son that will be staying with us this weekend, so I had the joint all to myself!
I got the fuel system basically done. I am just waiting on the tanks to get here, and I can get then in. I am a little worried that I didn't get small enough clamps for the 5/16" return hose. I can twist then on the nipple if I really try. I may hook up one tank on the floor just to see if I have any leaks. That way I can have good access to check everything, and if I find no leaks I can get the bed on sooner.
Made a bracket for the trans cooler lines near the front of the engine.
Got the shift linkage hooked up too. Had to do a little tweaking here and there, but it goes into all gears including 1st.
Got almost all the rest of the wires ran to the engine... oil psi, temp, starter. About all I have to wire under the hood is the power wires for the PCM. I still have to do the cluster and the pedal. The pedal will require some modifications to fit right. I think I might try to weld on the original pedal so it looks correct.
I was able to use the battery cables from the 06. The ground worked as-is, the positive needed shortened. I'll pick up a terminal to solder on tomorrow. Also got a wire ran from the alternator over to the battery.
Tomorrow I'll probably work on the exhaust. If that goes well, I may go ahead and get the radiator support on, then I can splice in the front light harness.
The biggest problem so far is the electric fans. They are for the original radiator, which is wider than the 85's. The fans are just as wide as the 06's radiator. So I'll probably hit some yards next weekend to find some fans.
I'm aiming for trying to fire him up by next Sunday or the following Saturday. I REALLY want to drive him in on our Colorado cruise on the 27th!
Bob
Old 09-12-2009, 03:16 AM   #548
menace121978
Holy crap!!! thats awesome progress for just 1 night alone!!! looks really good buddy... more than 1/2 way home
"Dennis the Menace"
Old 09-12-2009, 08:26 AM   #549
JohnC
JohnC's Avatar
Looks awesome man. I think just for the piece of mind I would go ahead and get tighter clamps for the hose. Just because it doesn't leak now, doesn't mean it won't after having some time on the road. It's coming along nicely.
Old 09-12-2009, 09:41 AM   #550
glock35ipsc
Yeah John, I think I will order smaller clamps. I have an extra box each of the larger and smaller clamps, so I will return those for credit and get a box of the next size smaller. The only FI clamps anyone sells around here is in an assortment pack, so I'll get one so I can put the right size clamps on the tanks at least, then I can install them Wednesday night when they get here. The others will be easy to get to and replace even with the bed on.
Dennis - It's amazing what I can get done when I don't have my two extra "helpers". That was about 5 hours of peaceful work last night.
Bob
