Old 10-29-2011, 10:36 AM   #526
68GMCCustom
Truck and auto performance nut
68GMCCustom's Avatar
Re: 1969 Short Wide
is that a Painless Circuit Boss Mike? If so....be careful with that rubber top/seal. Nothing but resistance/friction to hold them in place and somehow mine fell off during a test run. Luckily they sell replacements, I think at $7 ea.
Otherwise I think they are a great alternative to a new complete harness....have all my new power circuits on one too!
Kurt -
'68 GMC short step - NIB '09 LY6 6.0L crate motor w/mods, NIB '12 crate 4L85e w/billet 3k stall Circle D, 3.73 posi 12 bolt, DynaTech f-swap headers, 3/4 drop, handling mods, etc. - my toy
'72 Chevy LWB C-10 Highlander - 350/350 ps/pb/tilt/ac - not original but close
'06 Chevy TrailBlazerSS - LS2/4L70e - little black hot rod SUV - my DD
'18 Kia Sorento - wife's econo-driver
'95 Chevy S10 - reg cab shortbed, LS, 4.3, auto...
my '68's powertrain and chassis build -links broken
A surprise phase - carb to efi -links broken
68GMCCustom is offline   Reply With Quote
Old 10-29-2011, 01:15 PM   #527
mcbassin
Still Learning
mcbassin's Avatar
Re: 1969 Short Wide
Originally Posted by 68 TT View Post
Nice progress. I made my own stand alone harness on an LT1 swap I did to my old 67 Chevelle. That was an experience and a half but it worked in the end and saved me a pretty good amount of money. I think it was worth the effort and I understood the systems better afterward too.
Thanks, It is definetly a huge learning experience. Wiring is my single weakest point when doing a restoration.
Kurt,
Actually, I used the list of parts and suppliers HERE. I added 4 more circuits recommended by USMCchevy.
mcbassin is offline   Reply With Quote
Old 10-29-2011, 04:05 PM   #528
gringoloco
A guy with a truck
gringoloco's Avatar
Re: 1969 Short Wide
Care to expand upon your fuse block wiring method?
-Chris
Instagram _elgringoloco_
'70 Short-Wide How to: Ruin a perfectly good C10
‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd
'72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD)
'72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD)
'05 Yukon Daily Driven (not so stock) Yukon (SOLD)
‘07 Yukon Denali (daily)
Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy
gringoloco is offline   Reply With Quote
Old 10-29-2011, 04:37 PM   #529
mcbassin
Still Learning
mcbassin's Avatar
Re: 1969 Short Wide
Sure, No problem. I used THIS from lt1swap.com and combined the diagram from Ben HERE
The lt1swap.com uses 3 fuses for all the circuits. I think Ben (usmcchevy) design his diagram after the oem fuse setup. All I did was copy what these guys did.
Old 10-29-2011, 10:11 PM   #530
usmcchevy
Has more rust than truck...
usmcchevy's Avatar
Re: 1969 Short Wide
I really need to type that diagram out
Nice work BTW!
1972 Custom/10 SWB, 4.8/4l80e
Build thread
LSx Swap FAQ index
usmcchevy is offline   Reply With Quote
Old 10-29-2011, 10:19 PM   #531
68GMCCustom
Re: 1969 Short Wide
looks like I could have gone with a cheaper solution!
Kurt -
Old 10-29-2011, 10:44 PM   #532
gringoloco
A guy with a truck
gringoloco's Avatar
Re: 1969 Short Wide
Sweet. Good plan- fused like stock. That's one of the downsides to the lt1 swap guide. This way is much better for troubleshooting should the need arise...
Nice work BTW!
Haha- yeah, but it gets the point across as is...
-Chris
Old 10-30-2011, 12:16 PM   #533
mcbassin
Still Learning
mcbassin's Avatar
Re: 1969 Short Wide
Nice work BTW!
Thanks again! and BTW, That diagram is way more readable for me than the factory diagrams.
Old 10-30-2011, 12:22 PM   #534
screaminchevypickup
Laid Back
screaminchevypickup's Avatar
Re: 1969 Short Wide
Looks good mike!! Keep up the good work..
72 chevy swb
Direct dealers for..
Vintage Air, Porterbuilt, Billet Specialties,Budnik wheels ,eddie motorsports, raceline wheels, intro wheels, Dakota Digital, precision, unisteer, Trimparts, and many many more... Laid Back Recreations.. Full restoration shop and full paint and body..
Kyle
http://67-72chevytrucks.com/vboard/s...d.php?t=574629
screaminchevypickup is offline   Reply With Quote
Old 11-06-2011, 09:59 PM   #535
mcbassin
Still Learning
mcbassin's Avatar
Re: 1969 Short Wide
Thanks Kyle.
Old 11-06-2011, 10:07 PM   #536
mcbassin
Still Learning
mcbassin's Avatar
Re: 1969 Short Wide
Small update. I made a few parts to help mount my fuel supply line. I'm hoping there won't be any issues with this route I took. If there is well.....just have to change it I guess
Then I cut up the two piece driveshaft so I could get a one piece made. Got it made last week, it fits perfect. (thanks Scott62!)
Spacer and angle mount for the fuel line:
Cut up my two piece driveshaft:
Using it to measure the new length:
Old 11-06-2011, 10:19 PM   #537
mcbassin
Still Learning
mcbassin's Avatar
Re: 1969 Short Wide
Then used a heavy duty drill and a 4" dia. hole saw to cut holes for the exhaust to pass through. I used Ben's(usmcchevy) method to keep the saw from walking off. It still takes some holding on to it tight.
Got my new mufflers in and should have my pipes in tomorrow. I will be building the exhaust next week. My plan is to get this thing to the point of running before I get to the new cab......more on that in the near future.
Old 11-06-2011, 10:24 PM   #538
screaminchevypickup
Laid Back
Re: 1969 Short Wide
looks good!!!!
72 chevy swb
Kyle
Old 11-06-2011, 11:16 PM   #539
RocketKing
RocketKing's Avatar
Re: 1969 Short Wide
Excellent work Mike!
Rex
RocketKing is offline   Reply With Quote
Old 11-06-2011, 11:46 PM   #540
mcbassin
Still Learning
mcbassin's Avatar
Re: 1969 Short Wide
looks good!!!!
Thanks for the props and checking in on the build
Thanks Rex. I'm only about a year behind you at the pace I'm going.
Old 11-07-2011, 12:24 AM   #541
scotts62
One day...
scotts62's Avatar
Re: 1969 Short Wide
Very cool! Looking good!
Scott
93 crew cab build
Project 62
Old 11-07-2011, 08:58 AM   #542
gringoloco
A guy with a truck
gringoloco's Avatar
Re: 1969 Short Wide
Good progress and attention to detail Any concerns with the fuel line running close to the exhaust? Vapor lock sucks...
-Chris
Old 11-07-2011, 09:41 AM   #543
mcbassin
Still Learning
mcbassin's Avatar
Re: 1969 Short Wide
Thanks Scott!
Thanks. Yes I have concerns about it but I have it as far away as I can get it without going a different route. My other plan is to add a heat shield or wrap the line with some heat tape. I really don't think it will be an issue but we'll see.
Old 11-07-2011, 10:40 AM   #544
JohnC
JohnC's Avatar
Re: 1969 Short Wide
Looking good Mike!
JohnC is offline   Reply With Quote
Old 11-07-2011, 12:34 PM   #545
Zoomin
Man of Mini-Talents
Zoomin's Avatar
Re: 1969 Short Wide
Lots of great ideas there, Mike. It's really cool to see how you fab that stuff up.
Zoomin is offline   Reply With Quote
Old 11-07-2011, 01:11 PM   #546
mcbassin
Still Learning
mcbassin's Avatar
Re: 1969 Short Wide
Originally Posted by JohnC View Post
Looking good Mike!
Thanks John!
Thanks Steve. I'm as cheap as they come bro. Some of it is to save a few bucks.....Some of it is just to see if I can ya know
Old 11-07-2011, 02:15 PM   #547
mcbassin
Still Learning
mcbassin's Avatar
Re: 1969 Short Wide
I went in search of some LS1 manifold connector flange and drop down collectors at local salvages and online with no luck. So I stopped by a local scrap metal yard and picked up some 3/8 steel plates for $11- 2 plates.
Then made a quick model of the flanges. After that ran them on the CNC mill.
More fabrication:
3/8 plate setup on the manual to drill the holes
Holes drilled
Solid model:
Set up on the CNC mill:
Finished product:
Old 11-07-2011, 02:40 PM   #548
screaminchevypickup
Laid Back
Re: 1969 Short Wide
Your the man mike!!! Your good with those machines!!!
72 chevy swb
Kyle
Old 11-07-2011, 03:45 PM   #549
gringoloco
A guy with a truck
gringoloco's Avatar
Re: 1969 Short Wide
I need a job in a machine shop- or at least a good friend with one... Those are nice
-Chris
Old 11-07-2011, 08:52 PM   #550
68 Four on the Floor
68 Four on the Floor's Avatar
Re: 1969 Short Wide
You need to stop making these sweet custom parts and showing off or need to start selling them lol. Looking good Mike! My package arrived today. Looks sweet thanks alot!
68 Four on the Floor is offline   Reply With Quote
