12-06-2010, 12:14 PM | #526 |
VA72C10
Re: Project: Recycle
As stated, it looks awesome! If this is "practice"..... I really can't wait to see the 67
Looking for a 67-72 swb or blazer project in or around VA. |
12-06-2010, 09:21 PM | #527 |
Rollin' Old Skool
very nice...that's the same idea i had/have for my wheel & tire plans unless something changes...keep up the nice work!
12-07-2010, 01:33 AM | #528 |
Well, I got the rear Bilsteins delivered today so I though I would do a quick trial fit to make sure there were no suprises. Suprise! They need to be modified.
The lower mounting stud on 'generic' shocks is typically separate from the shock. The stud mounts to the frame or bracket & is secured w/a nut. The shock bushing slides over the shaft of the stud & is secured to the stud w/another nut (just like the front shocks). On Bilsteins, the stud is press-fit into the bushing & is one piece w/the shock. The only way to secure the lower end of the shock is to mount the stud/shock combo in place & tighten the nut from the back of the mount. Not a problem w/standard lower coil spring shock mounts but it IS a problem w/the Porterbuilt lower shock mount as there's very little room to access the nut. With PB's set-up, you have enough room to put a wrench on the nut to keep it from spinning & you simply tighten the stud from the front side..... It works well when the stud & bushing is 2 pieces. Sooo..... I cut the stud apart to press it out of the shock eye & bushing. The fit was so tight, it wouldn't press the stud out, it pressed the entire bushing & stud out as a unit. I then had to press the stud out of the bushing. 1st pic.... Bilstein stud vs. generic shock stud 2nd pic... Bilstein stud cut apart to press out of bushing 3rd pic.... Bilstein shock stud & bushing
12-07-2010, 01:46 AM | #529 |
So I go to try & squeeze the bushing back into the shock eye..... that was like putting a square peg into a round hole. It squished/squirmed one way or the other vs. into the hole. On to Plan B.
Plan B. I figured would just require getting a typical 2pc bushing w/a sleeve (each half of the bushing slips in place from the opposite side of the shock eye & a sleeve is pressed in place). I got all the dimensions from the bushing & shock eye to start my net search. Hhmm.... it seems what I need is not exactly a common size. In fact, nothing seems to be available in a 2pc. So, now I'm contemplating my options. I might try to freeze the supplied bushings & cut them in half (effectively making my own split bushing); or I did find a 1pc poly bushing from Prothane w/similar dimensions that I could do the same (cut it in half making it a 2pc bushing). I guess I should know by now, it's never simple....
12-07-2010, 02:05 AM | #530 |
hmmmm use wash up liquid to grease the bushing and clamp the lot intoo a vice with a couple of big ratchet sockets to push the bushing in far enough and tighten , or do the same thing with a piece of treaded rod stuck through the whole setup fitted with some nuts and washers ( this might actually work better )
they put the thing in there before so it should fit
i got a job again and having fun at it too idea's for the trucks and the order of things to do are taking shape and get closer to being realized , a few more months and i be able to start building for real i complete 2 of the trucks intoo running fashion one custom and one basicly stock the thirth will be sacrificed for parts |
12-07-2010, 09:52 AM | #531 | |
We have deep freezers @ work. I'm going to try the same process today after freezing the bushings @ -60°.
12-07-2010, 10:06 AM | #532 |
Under Construction
awesome work Scoti!
Heath subscribe to the board here: http://67-72chevytrucks.com/vboard/payments.php http://67-72chevytrucks.com/vboard/s...d.php?t=157669 FAQ how to's 1956 Chevy Apache 1967 C10 SWB FleetSide (under construction) 1969 K10 SWB FleetSide (Future Build) 1972 C10 SWB Stepside (Future Build) 56 chevy truck : http://www.cardomain.com/ride/2955823/1 67 truck build: http://www.67-72chevytrucks.com/vboard/showthread.php?t=281357/1 69 k10: http://67-72chevytrucks.com/vboard/s...d.php?t=389470 |
12-08-2010, 11:28 AM | #533 |
Freezing the bushings didn't help so last night I cut one in half. That allowed me to get the bushing pressed back into the shock eye but there's no way even a .500" bolt is going to pass through w/o forcing one of the bushing 'halfs' out.
I need to order the mufflers from Summit today so I'll order some poly shock bushings, cut them in half, & use them (the poly bushings have a larger dia bolt hole). Last night, my buddy Matt stopped by the shop to see the chassis. He said it looked better in person than in the pics so that made me a happy camper.
12-09-2010, 12:30 PM | #534 |
I ordered some Prothane (poly) shock bushings & mufflers. Once I get the bushings, I'll cut them up to use in the shocks. I'm just hoping they're not going to be noisy.
67SWB-B.B.RetroRod 64SWB-Recycle 89CCDually-Driver/Tow Truck 99CCSWB Driver All Fleetsides @rattlecankustoms in IG Building a small, high rpm engine with the perfect bore, stroke and rod ratio is very impressive. It's like a highly skilled Morrocan sword fighter with a Damascus Steel Scimitar..... Cubic inches is like Indiana Jones with a cheap pistol. Last edited by SCOTI; 12-09-2010 at 01:18 PM. |
12-09-2010, 12:36 PM | #535 |
Happy to be here
You ordered the bushing mufflers, but forgot the muffler bearings...
12-09-2010, 12:43 PM | #536 |
67cheby
Blinker fluid....dont forget it
12-09-2010, 01:19 PM | #537 |
They came w/the flux capacitor . . .....
12-10-2010, 05:17 PM | #538 |
Truck looks great Scoti
55 Chevy original swb (big back window) 61 Chevy bubble top (427-5 speed) 67 Chevy stepside (Krusty) 68 Chevy swb fleet (Lola) 68 Chevy swb fleet 71 Chevy swb fleet ( future PB project) 97 crew cab power stroke 07 SS Trail blazer |
12-10-2010, 09:03 PM | #539 |
Thanks!
Today, I worked on the cab/front clip in anticipation of separating the body from the original chassis. I needed to get the floor cut to allow clearance for the tranny using a high-hump trans tunnel. I got it cut out & 'marked' for the tunnel fastener holes. Since I was in there working, I removed the clutch pedal (plus the attached push-rod linkage), the remaining firewall insulation, heater assembly, various wires, cables, & e-brake hardware. I then removed the batt tray, cables, any 'hacked up' front clip wiring, tagged the 'good' wiring, & removed the master cylinder.
12-10-2010, 10:12 PM | #540 |
Village Idiot....
Go scot go!!!!!
http://www.hubgarage.com/mygarage/n2billet -67 SWB Custom Porterbuilt Front and rear 20/22's Hazel Sold -71 StepSide Porterbuilt Stage 2 with 20/22's Stella Mae Sold |
12-10-2010, 11:39 PM | #541 |
I'm just glad to be here!
I need to get off my duff and catch up on mine...maybe the holidays will do me some good..
Keep it going....
Karl 1965 Chevy Stepside(Grandpa's Old Blue) and (July 2015 Shop Build!)(2020, the Saga Continues) http://67-72chevytrucks.com/vboard/s...d.php?t=372424 The LST Challenge: http://67-72chevytrucks.com/vboard/s...=1#post7812257 Korbin's 1st Square: "Sunburn" http://67-72chevytrucks.com/vboard/s...d.php?t=418618 1985 GMC Sierra: "White Trash", Korbin's 2nd now... http://67-72chevytrucks.com/vboard/s...d.php?t=632305 Henry - 1984 Chevrolet, Owen's 1st Square |
12-11-2010, 12:01 AM | #542 |
Nice job on chassis, looks great !!!!!!!!
My Build http://67-72chevytrucks.com/vboard/s...d.php?t=346597 https://www.facebook.com/pages/198-C...1434001?ref=hl |
12-21-2010, 09:43 PM | #543 |
Village Idiot....
Eleven days.....I know your not sitting on your hands so what's been done?
12-22-2010, 12:18 AM | #544 | |
I've been around the house more so I've been doing small things w/the dually. A much needed brake inspection, some detail cleaning, & then replacing the master cylinder. Then onto cosmetics.... front bumper w/impact strip is gone. Rear hide-away space carrier is gone. 'Urban cowboy' exhaust tips are gone. Today while waiting for the plumbers to arrive @ the house to repair my leaking water main ( line from the meter that supplies the house split), I removed the rear 'work' bumper & swapped the sport bumper in place to determine the hitch requirements. I still have to get x-mas shopping done too. So progress.... just not on the 64.
67SWB-B.B.RetroRod 64SWB-Recycle 89CCDually-Driver/Tow Truck 99CCSWB Driver All Fleetsides @rattlecankustoms in IG Building a small, high rpm engine with the perfect bore, stroke and rod ratio is very impressive. It's like a highly skilled Morrocan sword fighter with a Damascus Steel Scimitar..... Cubic inches is like Indiana Jones with a cheap pistol. Last edited by SCOTI; 12-22-2010 at 12:19 AM. |
12-23-2010, 03:10 AM | #545 |
Scoti,
I just read all 109 pages. Very awsome build so far! I dig what you are doing! A few questions. You are running 78-81 Malibu rear shocks and C-10 front shocks? Did you order them through the local parts house? Thanks! Greg "GT" Tholen |
12-23-2010, 07:27 AM | #546 | |
Watch out for your cornhole !
I'm on the Instagram- @Gearhead_Kevin Last edited by Tx Firefighter; 12-23-2010 at 07:27 AM. |
12-23-2010, 09:52 AM | #547 |
Yes. C-10 fronts & g-body rears. Bilstein does not list a p/n for C-10 rears. Now that Hotchkis has a kit w/'tuned' shocks, a guy might be able to just get some Bilsteins for their C10 that's a direct fit.
12-23-2010, 09:54 AM | #548 | |
67SWB-B.B.RetroRod 64SWB-Recycle 89CCDually-Driver/Tow Truck 99CCSWB Driver All Fleetsides @rattlecankustoms in IG Building a small, high rpm engine with the perfect bore, stroke and rod ratio is very impressive. It's like a highly skilled Morrocan sword fighter with a Damascus Steel Scimitar..... Cubic inches is like Indiana Jones with a cheap pistol. Last edited by SCOTI; 12-23-2010 at 11:04 AM. |
12-23-2010, 09:59 AM | #549 | |
Slots go on anything!
Just for what it's worth, the Craigslist ad when I bought the dually had is listed as a "Cowboy Cadillac". I think I heard dueling banjos when we went to go pick it up.
1974 Jimmy- 5.3/4L80e/NP241 |
12-23-2010, 11:03 AM | #550 |
as long as they dont hand you there beercan and start yeliing hey ya'll watch this , you prolly be ok
