#526 |
![]() Join Date: Mar 2011
Re: Project "Popeye"
Can't wait to see the parts and assembly begin...Jim
my build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=459839 Jimbo's long bed step build:http://67-72chevytrucks.com/vboard/s...t=464626<br /> |
#527 |
congrats can't wait to see the end result
51' 99toLife finished 2011,355 sbc,5speed, patina, redoing whole truck, inter, bags, etc http://67-72chevytrucks.com/vboard/s...d.php?t=382481 49Hardtimes s/10 susp- bagged, vortec sbc, 5 speed, patina, sold http://67-72chevytrucks.com/vboard/s...d.php?t=594874 VIDEOS https://youtu.be/E8zHhjgS_lA https://youtu.be/E8zHhjgS_lA Geronimo 54' LS engine, static drop IFS, Client build, just about done http://67-72chevytrucks.com/vboard/s...62#post7399162 52' 3100 Slowly in progress, will be painted two toned, have 235 with a t-5, lowered OG frame Other projects, 49' farmuse 3100, killer Patina, will be slammed, LS engine, full done interior up next! www.coffeeandcustoms.com |
#528 |
just read the whole thread took nearly 2 days. very nice!! i am envious of your ability to maintain a clean work area. my place is not so tidy. i would love to find one of these to do would even give my 68 for one as nice as you started with.
#529 | |
![]() Join Date: Jul 2006
![]() So I took care of a little project in preparation for the fuel system/tank installation. I wanted to sound deaden and insulate the back of the cab so I took care of that and insulated the roof. Peel and Seal and foil-faced bubble wrap type insulation from Lowe's were used. I heated the Peel and Seal after applying it with a heat gun then rolled it with a seam roller to make sure it's stuck on for good. The insulation was adhered using 3M Super 77 spray adhesive. All in all a quick, cheap and easy project that should yield a good return. I will probably do more of the floor and some or all of the firewall at a later time.
'20 Silverado Trail Boss ~ '17 Tahoe ~ '79 K15 Sierra Grande ~ '76 Blazer 2wd ~ '71 Cheyenne swb ~ '55 Pontiac Safari ~'50 3100 bagged ~ '80 Wife ~ Late model kids
#530 |
does the peel and seal have strong odor? Like tar...
Also where did you find at Lowes Looks great Btw... Mark
http://67-72chevytrucks.com/vboard/s...d.php?t=645774 Project Orangepeel 52 A.D. http://67-72chevytrucks.com/vboard/s...d.php?t=653337 John's LS 49 dodge http://67-72chevytrucks.com/vboard/s...d.php?t=655780 Blake's 67 GMC LS stepside http://67-72chevytrucks.com/vboard/s...d.php?t=690527 Reed 78 FJ40 Rebuild http://67-72chevytrucks.com/vboard/s...d.php?t=733259 Barger's 78 FJ40 |
#531 |
No odor, that's more likely with products having a higher asphaltic contect. It's found in the roofing section.
#532 |
looks good, I'v heard of guys going that route with the deadners. I've searched for a quite a bit on the subject. I've even got the weights from fatmat on the different ones they use for ex. The odor ones come from what most companies use which is the mastic compound, some are just gonna be worse than others.
The one I'm leaning toward and is more money though is the butyl-rubber. Its said to be the best dampening material, some guys sell 50 and 70mil thick. I'v found 50sq ft of the butyl for $75 50mil thick, not made in china do you know how many sq ft you got and how much its was?
#533 |
Agree on the butyl rubber materials...definitely better options out there than peel and seal. I bought two rolls 25'x6" for about $16/each and the insulation for about $24, plus some foil tape for a couple bucks.
#534 |
The Peal and seal is where the flashing is at Lowe's. I like to never found it.
#535 |
Thank's guys for the info..
Mark...
#536 |
99 where did you find that deal?
#537 |
![]() Join Date: Aug 2012
Any updates Leevon? You're so close....and like you said we're like fat kids and cake...
Can't speak for everyone but i'd take a solid bet there's a few of us that want to see Popeye on the road! |
#538 |
Just went thru your build because I plan to accomplish a very similar setup and you were doing great! What's the story on popeye these days?
1951 3100 Patina "Under Construction" ![]() Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=636116 87 V30 1 ton Mud Truck |
#539 |
Sadly I am still dragging this build out and Popeye is not running yet, however he is not far from being done. What you can see in the pictures are a shortened and completely rebuilt '69-71 non-tilt steering column, brand new glass and rubber, new headlight buckets and guts, and new pin striping. The "Jessica Marie" lettering with angel's wings on the tailgate is a tribute to my sister who passed away in 2010 after I started this build.
#540 |
Popeye is looking good! Not that far to go, get that sucker done!
#541 |
awesome, luv this truck, nice tribute. I remember when you posted that years ago. Very sad.
#542 |
67-72 parts collector,…
![]() Join Date: Nov 2002
Looks great!
#543 |
Thanks for the update!!
#544 |
That tribute looks great!
#545 |
Love the pin striping!
Build Thread: 1958 GMC Memorial Build |
#546 | |
#547 |
It worked out well. I did move the hole in the floor down about 4" and to the driver's side about 3". I thought the column would be fine as-is but once I dis-assembled it for shortening I realized it needed upper and lower bearings and the cancelling cam/harness connection. The shaft, inner and outer tube were all cut and shortened 2". I also had to create my own bearing retainer on the end of the lower bearing. But it all worked out well, shifts and turns very nice.
#548 |
Glad to see the update, truck looks great...Jim
#549 |
PROJECT 7DEUCE
![]() Join Date: Dec 2002
Looks good bud
GO BIG GREEN ![]() MEMBER #6377 72 k-5 daily driver 6'' lift 35'' 350-350-205 slowly getting rust free. Project "7DEUCE" check out my build http://67-72chevytrucks.com/vboard/s...d.php?t=267665 Tim Powell..R.I.P EastSideLowlife..... R.I.P.. |
#550 |
SAVING ONE TRUCK AT A TIME
![]() Join Date: Feb 2010
Looking good. Keep at it.
53-suburban (99% done) 40-pick up (99.9% done) 12-cc lb dually D-max (dd) 61-crew cab D-max "PAY LESS FOR WHAT YOU NEED PAY MORE FOR WHAT YOU WANT" 53 BURBAN BARN FIND:http://67-72chevytrucks.com/vboard/s...d.php?t=404091 1940 PROJECT MOON SHINE:http://67-72chevytrucks.com/vboard/s...d.php?t=551088 1961 CREW MAX: http://67-72chevytrucks.com/vboard/s....php?p=6957999 |
