#526 |
Re: 85 burb meets 6.0 lq4
On the tcc i have it only locking up in 4th gear. It has no vaccum switch or any factory stuff. Just power, switch, solinoid, and 4th gear psi sensor. That is what i figured. I will get a tach soon and see what rpm it is really doing when it hits lockup.
I also am happy with exhaust for now. Still little anyouing but it is not as bad as it was.
82 c10 5.3/4l60 84 c20 5.3/sm465 85 chevy k10 suburban LQ4/4l60 91 chevy c10 suburban Lsa 5.3/4l60 2017 Silverado whipple 5.3 1964 Vw beetle 1974 vw beetle |
#527 |
Oh ya. I will getting wideband soon i think. I can only run one but if i do everything even the other side should be close.
Thanks yall for your info and input.
#528 |
Still plays with trucks
I used the Flowmaster mandrel bent tail pipes on my 81 K20 and they fit great.
http://www.summitracing.com/parts/FLO-15803/ The rest of the system I built with a few mandrel U-bends and some lengths of straight pipe and a pair of 50-series Flowmaster mufflers. I had under $400 into the whole system and it looked, worked & sounded great. I assembled it all in my parking space at my old apartment and used a rented oxy-acetylene welder to put it all together just like the muffler shops did before they got MIG welders. I even used a hand held jig saw to cut the tubing to size. No fancy chop saws needed.
miSSed opportunity - ground up creation of an AWD 1994 454 SS that never was http://67-72chevytrucks.com/vboard/s...d.php?t=795577 69 C10 shortbed stepside 400 small block - built like what a super sport truck could have been 69 K20 lwb TBI 350 4L60E NP208 14-bolt Dana-44 w/disc 68 Camaro SS / RS 500hp 439 inch roller cam big block 4L80E 79 Malibu TPI 350 4L60 w/ Z28 steering & sway bars |
#529 |
Well figured i would get good breaks now that i have a good motor. Went out and got everything for the rears and rotors for the front. Have to take calipers off and match them up at store. Not looking forward to doing all this work. Also found water leak on my motor. Looks to be comming off of heater hose. Way to cold to fix it now. I am sure it seals up when it warms up. Also ordered all new brake cables for e brake so whiny babys dont give me crap about it this year during inspection time. Got cables from lmc.
#530 |
Truck and auto performance nut
ah.....see how it just starts to spiral into upgrading one thing or the other?
Kurt - '68 GMC short step - NIB '09 LY6 6.0L crate motor w/mods, NIB '12 crate 4L85e w/billet 3k stall Circle D, 3.73 posi 12 bolt, DynaTech f-swap headers, 3/4 drop, handling mods, etc. - my toy '72 Chevy LWB C-10 Highlander - 350/350 ps/pb/tilt/ac - not original but close '06 Chevy TrailBlazerSS - LS2/4L70e - little black hot rod SUV - my DD '18 Kia Sorento - wife's econo-driver '95 Chevy S10 - reg cab shortbed, LS, 4.3, auto... my '68's powertrain and chassis build -links broken A surprise phase - carb to efi -links broken |
#531 |
Also just ordered tach, few carb parts, trying to order dang uego thing buy summit is out of them. May have to find other store that sells them. I acctually blame you 68gmcustom cause you ordered 2. That second one was supposed to be mine.....JK
82 c10 5.3/4l60 84 c20 5.3/sm465 85 chevy k10 suburban LQ4/4l60 91 chevy c10 suburban Lsa 5.3/4l60 2017 Silverado whipple 5.3 1964 Vw beetle 1974 vw beetle Last edited by 85burb; 02-03-2011 at 08:16 PM. |
#532 |
Nice burban. You will be very happy with the ls powerplant.
Not to burst your buble, but my 84 burban 6.0\4l80e swap has been running since summer 2009. I beat you! Just kidding... Im from the panhandle, next time I drive down to the DFW we need to meet up and inspect burbans, meybe even race! |
#533 | |
#534 | |
#535 |
#536 |
Well just put in my order for my uego. Cant wait tell it gets here....
#537 |
fuel injected. I tried to make a project thread when I registered last year, but my username wouldnt let me post... I'll post some pics or make a build thread sometime in the next few days. Mine is a two wheel drive with longtubes and a custom tune.
#538 |
I see. What headers did you use?
#539 |
I used fbody headers. I picked some ceramic pacesetters for 100$! had to hammer a dent or two to clear the control arms, but overall they fit sweet. the driver side collector comes close to the frame rail, but the exhaust guy did had no problem getting it to work.
#540 |
I tryed dang fbody headers for the longest time. No way to make them work on my 4x4. BRPhotrods has a set of midlenghts that they have in a test truck that is 4x4 right now. If they work i will save my money to get some. Guy says on a 6.0 they added 38 rwhp. That is a bunch. But they are pricey too.
#541 |
I guess i forgot to post final pic befor cleaning up wireing. Got to drive him in snow today. Loads of fun. That is all i have to say...fun
#542 |
Second Chance Program
Theres some pics finally! Looks sweet in there!!! Glad that you seem to be pretty happy with it.
#543 |
^^who I am^^ what I say>
That looks damn good. Are you still in the Tyler area? P.S. I know of a very good exhaust shop that can fix you up right for a very good price. Every vehicle I have ever owned I have taken to him, and the work is always excellent, professionally welded, and exactly how I want it.
How are you liking the carb setup?
70 chevy LWB 350/TH350 Barn find (AKA the 70) http://www.67-72chevytrucks.com/vboa...d.php?t=406364 East Tx Squares Last edited by grayharville; 02-04-2011 at 02:39 PM. |
#544 | |
#545 |
Yes really happy with it. Now to dial sucker in.........could take some doing there......
#546 |
So this is the timing curve i am thinking of starting with. If yall have any input let me know. I can have up to 6 dots to curve the line. The low side is 12 degrees the high is 32
82 c10 5.3/4l60 84 c20 5.3/sm465 85 chevy k10 suburban LQ4/4l60 91 chevy c10 suburban Lsa 5.3/4l60 2017 Silverado whipple 5.3 1964 Vw beetle 1974 vw beetle Last edited by 85burb; 02-05-2011 at 02:38 AM. |
#547 |
Can you adjust for load? My spark map looks like a spreadsheet with manifold pressure on the y axis and rpm on the x axis. Value in the cell is the advance.
-Marcus 1991 V3500 L29 454 4L80E NP205 D60/14 Bolt 4.56's 1984 K30 292 TH400 NP205 D60/14 Bolt 4.56's flat bed 7'6" Meyer Plow 2022 Silverado 3500 L8T Project Daily Driver Project Heavy Hauler Project Plow Truck |
#548 |
I know what you mean about bein broke, it sucks! I like the idea of a modern motor with an old school carb setup, I bet that turns some heads for sure. what kind of MPG are you getting?
70 chevy LWB 350/TH350 Barn find (AKA the 70) http://www.67-72chevytrucks.com/vboa...d.php?t=406364 East Tx Squares |
#549 |
LSX addict
looks SICK man! hope to see it around. be careful out on these roads!! it seems like everyone wants to go slide around in their 2wd's. ive almost been hit countless times.
-1982 C10 SWB GMC Sierra [undergoing 6.0/4L80E swap with mild restoration] |
#550 |
Yes it has a vaccum graph but it is in a unit of mesurment i dont under stand. DO you have one of these boxes?
