#526 |
6>8 Plugless........
![]() Join Date: Sep 2007
Re: ** YOUNG FRANKENSTEIN** The truck Chevrolet should have built.
The bed is looking great!
Ryan 1972 Chevy Longhorn K30 Cheyenne Super, 359 Inline 6 cylinder, Auto Trans, Tilt, Diesel Tach/Vach, Buckets, Rare Rear 4-link and air ride option Build Thread 1972 GMC Sierra Grande Longhorn 4x4 1972 Chevy Cheyenne Super K20 Long Step side tilt, tach, tow hooks, AC, 350 4 speed 1972 C10 Suburban Custom Deluxe 1969 Chevy milk truck 1971 Camaro RS 5.3 BTR STG3 Cam Super T10 1940 Ford 354 Hemi 46RH Ford 9" on air ride huge project Tired of spark plugs? Check this out. |
#527 |
#528 |
Lucky Teter at the wheel
Got my tailgate and cowl panel in primer so they won't rust. Look at that tailgate, it is bare - no bondo work yet. So fine!
Drew YOUNG FRANKENSTEIN (Finished with MAJOR Surgery - IT'S ALIVE!!!) The Bride is currently under the knife!
#529 |
That is a super nice tail gate! Are you going to cringe when you have to drill holes for the trim?
#530 |
ryan thats a good one! man that tailgate is clean!!!!! 68 tail gate......
#531 |
VA72C10
![]() Join Date: Mar 2008
Super nice gate!!!
Looking for a 67-72 swb or blazer project in or around VA. ![]() |
#532 |
Started on the gas tank install.
Earlier when I was mocking up the bed, I noticed I would need to lower the gas tank one inch in the front. I wasn't sure how to accomplish this until I started in on it tonight. I went out to another parts truck and cut the strap bracket off and welded it to the bottom of my existing one. A little paint later and one side is taken care of. The other side bolts the strap to the frame. I couldn't find a bolt long enough to extend an extra inch so I cut the head off, cranked the heat up on the welder, and welded a 1 inch bolt to it. Having a welder can make anybody a genius. I used a 1.5 inch thick rubber body biscuit as a spacer between the gas tank and the frame and a half inch rubber spacer on the side of the frame to get the gas tank off of my rearmost cab mount. Still have room for my filler neck to clear the frame rail. Whew !
#533 |
Next was the charcoal canister and some little electronic gizmo connected to it.
The canister mounted to the hoop shaped driveshaft carrier bearing mount that I chopped off long ago. I went back and cut the mounting tab off of the hoop, made a few modifications to it, and welded it to my new driveshaft carrier bearing mount. The gizmo used to mount to a frame/bed mount that I also chopped off. Hmmmm, now where can I mount this little sucker? How about that new extra long bolt I just made. I cut the little mount tab, flipped it around 90 degrees and welded it back together, then ran a nut down my long bolt, slipped on my newly modified mount tab and put another nut on top of that.
#534 |
VA72C10
Nice work! Looks almost like factory
Looking for a 67-72 swb or blazer project in or around VA. ![]() Last edited by VA72C10; 02-09-2011 at 02:59 AM. |
#535 |
I know I'm a little late, but how did that Eastwood's soda blaster work for you? I'm thinking about getting that combo sand/soda blaster they have, but am not sure if I would get the results I'm after
69 C10 SWB -- Left to me by a loving father. Finishing the build we never got the chance to do together |
#536 |
It worked great. I have used it twice now, but the first time I didn't have enough air compressor. Now I have a very large 220 Ingersol Rand and it worked great. The thin original paint came off so fast it was ridiculous. The bed that had original paint and a roll on bedliner was a lot slower. I used 2.0 cutting abrasive, a very powdery sand. Never tried soda.
#537 |
AIR RIDE
It is snowing again in Memphis and that means the whole town shuts down. What that means for us is more time to work on our patient! I hung the driveshaft to see how much room I have to mount all of the Air suspension mechanicals. Not much, but I have it figured out. I started making brackets to mount the compressor, valve body and air tank. Daughter wanted to watch an old James Bond movie, so we are done tonight.
#538 |
Junk Yartist
If it makes you feel any better, I have been working in the garage for 30-45 minutes, and then go in and warm my hands up in the kitchen sink!
Somewhere on your truck you need to put a piece of tape that says "Abby"... maybe your ECM.
-Jeremy YOU ONLY FAIL IF YOU STOP TRYING 70 Crew Cab Build Link 70 GMC Suburban 4X4 build thread 95 Yukon Daily Driver Rebuilding an NP205 |
#539 |
Nice work!
#540 | |
Abbie Normal...... and the ensuing tirade. Hysterical. I'll get my youngest on that, she'll come up with something good we can stick on there.
#541 |
VA72C10
Nice. Going to be a cool bus
#542 |
We worked on Gnande's Olds 98 today trying to get it through inspection. replaced the battery, headlight switch, and flasher unit. Now it starts, has lights, and turn signals. Maybe we can get a tag for him tomorrow! He was grinning ear to ear.
We undercoated the bed and cab bottoms with Eastwood products and I think we are ready for the rain.
#543 |
VA72C10
That should be nice and durable now!!!
#544 |
I fabed up all of the mounts for the air systems and welded them onto the carrier crossmember and the ABS bracket. The tank squeezed in there and fits like a glove. The compressor is just shy of hanging below the frame. We also cleaned up the transmission and will paint it later.
#545 | ||||||||||||
#546 |
Still Learning
Nice work as Always Drew! You keep us inspired.
#547 |
SUPERscrapMAN
WOw this truck is too nice. I think you should give it to me so you aren't tempted to be prideful or anything like that.
Christine 1987 Chevy S10 2.8l 5 speed 600k miles! still chugging along - wifes ride Old Smokey 1990 Chevy K1500 Suburban 6.2L Diesel - Banks sidewinder The WarBeast 1994 Chevy Suburban K1500 - Semi retired at 400K miles The BLueOx 1994 Chevy Suburban. K2500 454 Used on a daily basis. ![]() ![]() |
#548 |
Would you take it off my hands? I'd be so grateful.
#549 |
Bought my quarter inch plate today to start on the rear suspension 4 link. Also going to start to pull the engine from the donor truck.
#550 |
Progress looks great BTW
67- 72 Parts collecter Last edited by classicchev; 02-12-2011 at 11:54 PM. |
