Old 11-25-2017, 12:26 AM   #526
sdwolff98
Turning Wrenches Daily
Re: 1964 GMC 3/4 ton build :D
Also have the rear cab and speaker panels about as done as I can get them lol turning out quite nicely! Just have to pull he driver side one back off and drill the holes for the crossovers to be mounted in there but other wise quite happy with it!
Sean
Work! Play! Work work work! Money to play with. 64 GMC, 66 burb 4x4, and now 64 1ton money pits......ahhh life is good. Upcoming move back to Texas Dallas bound we are this september!!!
1964 GMC I1500 2wd (my baby) 8.1 allison 6 spd conversion Aka Smurf http://67-72chevytrucks.com/vboard/s...d.php?t=438342
2016 Ram Big Horn 4WD parts hauler
2010 Chevy HHR wife new car after the circled problem blew up!!!
1981 Ram D150 /6 auto Wife's sunday driver
Living outside Gladewater Texas now working in Longview at the hospital there
future project toys:
1966 Chevy K14 carryall aka Smurfette future project 283/auto overdrive http://67-72chevytrucks.com/vboard/s...d.php?t=551867
sdwolff98 is offline   Reply With Quote
Old 11-25-2017, 12:29 AM   #527
sdwolff98
Also got the terrain console mounted back in to finish the electrical wiring connectors n such. Found out going to have to lift the back of the console 3/4 of an inch to allow the console lid to open near fully :/ grrr always something lol. Will order some aluminum bar and fix that problem very soon. Also will begetting a 2016 Camaro center vent assembly in for experimenting with for a set of center vents it may or may now work but going to give it a shot lol.
Sean
Old 11-29-2017, 01:08 PM   #528
sdwolff98
started a long thought of project last night. coming along very nicley using 3/16th inch abs paneling to make the setup. Will make templates for it here after I have all the panels completed and installed. So far so good will be working on it more tomorrow and Saturday.
Sean
Captainfab yep using a heat gun for the bends and folds doesn't take a whole lotta heat to get things bent!
Old 12-02-2017, 01:02 PM   #529
sdwolff98
well got the glove box completed and rough shaped quite happy with how it turned out. If I make any more it will go much easier since I now know the mistakes that can happen making them rotflmao!!!! That and a better plastic bending setup then two pieces of lumber lol
But since most people won't be looking up under the dash I call this project done. Once the paint is complete can finish installing the AC vent hoses then put this up inside piece by piece. One of the mistakes is its the factory size and being made out of the abs does not install except in pieces lol. oh well happy with it plenty of clearance in the back for the vent hoses etc so its all good.
Just have tot ake it apart and clean up all the scribing lines with a lil paint remover and all done
Sean
Old 12-17-2017, 05:33 PM   #530
sdwolff98
Put a deposit down with a custom radiator inter cooler builder up here locally and he has started on this project. he has gotten off to a good start. The radiator is going to be inset into the new core support and 27 inches tank to tank. nice thing is 10 an trans cooler fittings!
Sean
Old 12-18-2017, 01:01 AM   #531
Captainfab
60-66 Nut
That's going to be nice
Old 12-18-2017, 01:03 AM   #532
sdwolff98
Yeah captainfab he did most of that in one evening lol.
Sean
Old 12-28-2017, 03:03 PM   #533
sdwolff98
he is making progress rapidly.... for securement going with a set of rivet nuts that can be tack welded to help keep them from breaking loose and rotating just waiting on them and the install tool to come in now. Radiator is gonna be very nice 27x19 with electric fan shroud as ya can see. Other projects are in the stalled stage waiting for body work to be done.... playing with led lighting has been fun but getting frustrated by inconsistent diodes right now. got another led lighting project in the works using one of the copper led circuits boards. More to come on that later
Sean
Old 12-29-2017, 12:23 AM   #534
Captainfab
60-66 Nut
The radiator support is looking good
When installed correctly, rivnuts should not spin.
Old 12-29-2017, 12:26 AM   #535
sdwolff98
Captainfab,
Lol not gonna take any chances murphy loves tormenting me pretty consistently of late. Got a breather tho my wife exercised and blessed the garage rotflmao!!!!! 3 months so far can continue to hope
Sean
Old 12-29-2017, 05:16 PM   #536
sdwolff98
ok a few more pictures from last night placement check and test fit really getting excited seeing this come together. This guy definitely worth hiring listens to his customer triple checks everything and them a couple more times to boot!
Sean
Old 02-03-2018, 02:09 PM   #537
sdwolff98
been working on quite a few projects recently. the core support is coming along slowly got everything mocked up and found my driver side innder fender is pretty badly warped. So after digging around have an OEM unit on the way and see where that gets me lol. Also scrapped the terrain console project just was not working quite like I wanted. So I have started a new console mod project will be posting up pictures of it in the next few days. It fits the cab much better and gives me more room for components and such on the facing panel.
Sean
Old 02-04-2018, 06:13 PM   #538
sdwolff98
Ok here we go promised pics of the new console and how it is shaping up. Going to have to redo the front face panel got my vent hole dimensions off quite a bit so that panel is trashed :/ but otherwise fitting quite nicely. Plenty of space for louvers, trans temp gauge, usb port mounts. The shifter mounting plates I am currently waiting on to come in tomorrow so I can get that cut out and ready.
Sean
Old 02-13-2018, 09:45 PM   #539
sdwolff98
Went back to working on the alignment of the aluminum core support. Builder is drilling the front brace holes tonight then slowly start aligning everything as the front end is slowly put back together The repop driver side fender mounts up pretty nicely just needs some minor trimming in one spot.. will have pics of that later. going to be dropping my original powder coated inner fender back in think I got it straightened out with the aid from a bench vise lol. The one in the pictures has been reworked numerous times in it former lives with a few homemade replacement pieces so not sure I am going to invest anymore then I already have in buying it.......
Sean
Old 02-13-2018, 09:48 PM   #540
sdwolff98
also got the firewall pass through panel installed and hooked into the main harness. got to worrying I may not have good connections throughout this custom setup but then thought well it either does or it does not lol. Ifn I have to will pull it out after everything is assembled and I can test it out I also went back in an reworked the center console connections to fit the new console setup.
Sean
Old 02-13-2018, 09:50 PM   #541
sdwolff98
And last but not least got the parts in and the shift is mounted in the console fits much better then on the terrain console. Face panel is all finished just did not get any pictures of it but definitely have room for everything on it
Sean
Old 02-15-2018, 01:58 AM   #542
Captainfab
60-66 Nut
What is the new console out of? It does look to fit better.
Old 02-15-2018, 02:45 AM   #543
sdwolff98
07 land rover has captain fab yeah fits a ton better
Sean
Old 03-12-2018, 08:16 PM   #544
sdwolff98
Well some more updates. converting the truck to electric e brake system has been an interesting journey but I am waiting on a few more things to come in and work on it some more. I could not get the land rover switch working so I made a filler panel to mount the switches for it in, Also finished the face panel and side panels for the front of the console. Had to do a lil rework on the e brake cable mounts and the pull bar on the factory setup.
Sean
Old 03-12-2018, 08:19 PM   #545
sdwolff98
And back to the aluminum core support got the center mounting bolt holes lined up and drilled :/ only to run into the inner fender nose is hitting one of the radiator mounting bungs grrrrrr... the builder is going to come over and look at it kinda stumped but working at it worked ok once and now we have issues lol. the 4 holes are perfectly measured out and match the factory one so I guess we will see what is going on when he gets by.....
Sean
Old 03-12-2018, 08:24 PM   #546
sdwolff98
Also got the pink bed removed from the frame and flipped over so I can get to all them blasted rusted perimeter bolts lol will be working on getting some of them out this thursday And last thing dear god Welllllllll swap meets are totally horrible EVIL EVIL EVIL places!!!!! Just stopped to look at some pretty brake calipers..... guy comes over says you got a silverado?? I told him no I got a 64 gmc..... he looks at me funny and said them won't fit your truck..... I told him I had a factory Dana 60 with Silverado 2500 rear discs..... his eyes lit up and exclaimed "WELL NOW I HAVE A DEAL FOR YOU!!!!!!" Some cash later I walked out of the swap meet completely broke excepting for gas money lol with a set of brand new silverado 2500 rear stainless steel brake triple piston calipers.... now gonna have to work lotsa overtime to build up my paint funds again lol.....
Sean
Old 03-13-2018, 12:04 AM   #547
Captainfab
60-66 Nut
Are those calipers GM or aftermarket?
Old 03-13-2018, 12:10 AM   #548
sdwolff98
Captainfab stainless steel brakes company triple piston s already checked they fit the rear disc brackets I adapted to my factory Dana 60 proportioning valve is off the sane year truck
Sean
Old 03-13-2018, 12:13 AM   #549
Captainfab
60-66 Nut
I didn't realize that anyone made aftermarket brake parts for the 2500's. If they're SSBC, I'm sure they are a bit more than $300 new.
Old 03-13-2018, 12:21 AM   #550
sdwolff98
Captainfab ooohhhh yeah a grand for a new set from summit like these I got just happened to be at right place and time.
Sean
