04-15-2013, 11:22 PM | #526 | |
I had a V-8
Re: 72 k20 project
1972 K20 Suburban, 5.9L Cummins, Banks Power Pack, NV4500HD, NP205, H.A.D., D60/14FF ARB Link To Build: HERE. |
04-15-2013, 11:31 PM | #527 |
Junk Yartist
Re: 72 k20 project
What are you alluding to?
-Jeremy YOU ONLY FAIL IF YOU STOP TRYING 70 Crew Cab Build Link 70 GMC Suburban 4X4 build thread 95 Yukon Daily Driver Rebuilding an NP205 |
04-15-2013, 11:52 PM | #528 |
Re: 72 k20 project
he's gonna tell everyone he found one for 13$ and laugh at us all
04-16-2013, 03:48 PM | #529 |
6>8 Plugless........
Re: 72 k20 project
I'll sell you my cluster so I can get dakota digitals.
Ryan 1972 Chevy Longhorn K30 Cheyenne Super, 359 Inline 6 cylinder, Auto Trans, Tilt, Diesel Tach/Vach, Buckets, Rare Rear 4-link and air ride option Build Thread 1972 GMC Sierra Grande Longhorn 4x4 1972 Chevy Cheyenne Super K20 Long Step side tilt, tach, tow hooks, AC, 350 4 speed 1972 C10 Suburban Custom Deluxe 1969 Chevy milk truck 1971 Camaro RS 5.3 BTR STG3 Cam Super T10 1940 Ford 354 Hemi 46RH Ford 9" on air ride huge project Tired of spark plugs? Check this out. |
04-16-2013, 11:51 PM | #530 |
Re: 72 k20 project
Popped my injectors out tonight to send them off to the boys at Low Budget Diesel for some bigger nozzles. Thanks to Ryan and Nick
04-18-2013, 10:36 PM | #531 |
Re: 72 k20 project
so, barring any unforseens or a blast of pure genius, this is roughly where the turbos will live. it looks like the secondary will hit the hood in the current position. to cure this, i think i will do what i do best. mercilessly cut stuff apart. if the flange on the industrial manifold(thanks Ryan) were to exit in 45 it would lower the turbo and make it so i could clear the hood with no issue. i do think i may end up running an external gate, since it looks like the actuator has no place to go. more contemplating is certainly in order but at least i can get the primary in there. it does clear the evap housing, and the mount bracket for the big boy looks like it should be relatively simple to make.
04-18-2013, 10:42 PM | #532 |
Chevy Enthusiast
Re: 72 k20 project
Awesome!
Tony 1985 GMC K2500 restoration Project: Rust, White & Blue 1989 Chevy R3500 CC Cummins & 4X4 swap some day... 1989 Burb (D60, 14BFF, 12V, NV4500, NP205, 37" tires in progress) |
04-19-2013, 05:13 PM | #533 | |||||
Re: 72 k20 project
1996 Dodge 2500 Ext Cab Long Bed P24V Cummins Turbo Diesel 5 speed 4x4
"STOCK" ASSEMBLY THREAD |
04-19-2013, 09:29 PM | #535 |
Re: 72 k20 project
Yes sir, few snow storms, a blizzard, and a stop in the middle of BFE, but he made it home a couple minutes before I did last night. Was nice to see the Ford sitting in the driveway.
04-19-2013, 10:08 PM | #536 |
Re: 72 k20 project
BFE? it wasnt that bad! i offered beer and let him wash his hands!
04-19-2013, 10:38 PM | #537 |
Re: 72 k20 project
04-19-2013, 10:48 PM | #538 |
Re: 72 k20 project
I was going off his words, but he did get a great view of the backroads over the mountains in the snow lol
That's probably the first time I have ever heard of him rejecting free beer btw. T3 for the hx35? or that butterfly for the HX55? BTW if u need a gasket let me know, I know where there are a few...
04-20-2013, 12:34 AM | #539 | |
Re: 72 k20 project
those are all T3. i have a plan for the Hx55. hopefully i can make it work. and ill need a gasket or two eventually. |
04-23-2013, 08:09 PM | #540 |
Re: 72 k20 project
He did say the res was definitely BFE. I'll have to grab you a couple gaskets then.
04-23-2013, 09:49 PM | #541 |
Re: 72 k20 project
'preciate it
04-25-2013, 07:58 PM | #542 |
Re: 72 k20 project
Nice work Ryan. Sorry bout that rusty manifold. I know you hate that color.
04-25-2013, 08:17 PM | #543 |
Junk Yartist
Re: 72 k20 project
Isn't that known as Iowa Varnish?
04-25-2013, 08:34 PM | #544 |
Re: 72 k20 project
yeah, it is a little depressing, but hey, i got to cut it into pieces and that always makes me happy!
04-25-2013, 09:39 PM | #545 |
Re: 72 k20 project
had to give the new/old manifold i got from Ryan the ol' ryanroo special. seems i have an issue with stock items and need deep in my being to mutilate them. so i hacked the stock outlet off and welded on my own.
for those interested, i used Lincold electric 55Ni rod. preheat to probably 200-250 degrees (the entire manifold and the flange- pretack) tacked it on and welded. pause for a short peening session after each weld. then i wrapped the whole thing in a blanket and left it be over night. i have faith it will work fine, but the first true test will be the initial heat cycle on the engine with the weight of the turbo(s) on it. the fact that my test and the manifold did not crack right away are good. and ive always had luck with the 55ni rod. yes, i know its ugly. cast makes the puddle a little squirmy, and its not something i do every day on the head turbo position the primary will be up little from here. it is just sitting on the frame right now. |
04-25-2013, 10:06 PM | #546 |
Junk Yartist
Re: 72 k20 project
Couple things, don't you need force and rapid temp change to crack cast? I think your welds will be fine. You went all the way around, it's not like you were repairing a crack that could branch off. Did you just do a single pass?
04-25-2013, 11:10 PM | #547 |
Re: 72 k20 project
single pass mostly. I did a few on the sides where it was a pain to reach. mostly just to make sure I sealed it. cast by itself generally needs a temperature shock or impact to crack. when you weld mild to cast you have two dissimilar metals with different expansion/contraction rates. the mild likes to expand and contract more than the cast and at different rates. that is where the issue with cracking out occurs. that is also why I am not to worried after the initial cool off, but I will be totally convinced after the engine heat cycles a few times
it also is an issue with repairing cracks in cast because the filler has different characteristics than the parent. Posted via Mobile Device |
04-26-2013, 08:28 PM | #548 |
Re: 72 k20 project
It'll be fine. I've made several pieces in the last 5 years that are a mixture of cast and mild welded together with a mig welder. I pre heat the cast red hot, and then burn it in. I haven't had one of the parts crack or break yet. The exhaust manifold I did has been over 2000* several times with no issues.
04-26-2013, 09:17 PM | #549 |
Re: 72 k20 project
The manifold on my 96 has atleast 8-10 hooks of a constant 1750* for over 300 feet with a real sled behind it. No leaks yet....
04-26-2013, 09:25 PM | #550 |
Re: 72 k20 project
Looking good Ryan! That will be a sweet setup.
1980 K10 - 6.2L Diesel/SM465/NP205 Build Thread 1984 K30 CC Dually - "The Tank" 12V Cummins/Nv4500/Np205/D60/D70HD 4" lift & 37's Build Thread 1960 C-60 Dump Truck Make it road worthy! Thread |
