Old 02-03-2015, 12:41 AM   #526
oldman3
oldman3's Avatar
Re: 49' Patina bagged in PA
99, tell your friend it took you hours to drill all those "lightening holes" ...Jim
oldman3 is offline   Reply With Quote
Old 02-10-2015, 12:33 AM   #527
99 to Life
99 to Life's Avatar
2-9 Still chipping away, So first thing is first. Got my Accuair VU4 manifold wired up to my AVS controller, got everything plumbed, though still have some leaks to address. I have compressors wired up but I still have to finish the interior wiring of them. In the pic you can see how I have them ran into a fuse block, then into a stinger relay, then into the cab. I have a kill switch for that 8g wire and I also will have a toggle kill switch that will control the relay/pressure switch so I can turn it off or on as I please.
I finally took radiator out to final mount my fan. Instead of using the zip ties, I got some #2 all thread and then some bolts. I hope it works out, its tight but I'm gonna be pissed if there ever becomes movement and the metal rubbing through the radiator, I don't foresee that but its a worst case deal. Question, just realized today and this is why I have the fan bolted on. Say if died. Can I just unbolt the motor and change that without taking the whole fan out?? seems like I could and I went through all the work for nothing!
So another time consuming deal is placing all my gauges. As of right now I'm worrying about my air pressure gauges. I'm think I'm just going to make a little bitty console right by the seat that will house the front and back pressure gauges, then there will be two cup holders and a spot to keep the controller. I'll then have another consol up under the dash that will house all my engine gauges, temp, oil, vacuum, volts, air/fuel and I have to find a spot for my fuel gauge. Radio will be hidden behind speaker grille on dash.
https://www.youtube.com/watch?v=Gc-c...ature=youtu.be
51' 99toLife finished 2011,355 sbc,5speed, patina, redoing whole truck, inter, bags, etc
http://67-72chevytrucks.com/vboard/s...d.php?t=382481
49Hardtimes s/10 susp- bagged, vortec sbc, 5 speed, patina, sold
http://67-72chevytrucks.com/vboard/s...d.php?t=594874
VIDEOS https://youtu.be/E8zHhjgS_lA
Geronimo 54' LS engine, static drop IFS, Client build, just about done
http://67-72chevytrucks.com/vboard/s...62#post7399162
52' 3100 Slowly in progress, will be painted two toned, have 235 with a t-5, lowered OG frame
Other projects, 49' farmuse 3100, killer Patina, will be slammed, LS engine, full done interior up next!
www.coffeeandcustoms.com
99 to Life is offline   Reply With Quote
Old 02-10-2015, 08:42 AM   #528
chev3600
chev3600's Avatar
Looks good. Not sure how you would detach the fan blade from the motor without pulling it. It's either pressed on or has a clip/ nut.
1949/1954 with LS swap-yeah!
http://s260.photobucket.com/albums/i...0/AD%20trucks/jumbled mess of unorganized photos
chev3600 is offline   Reply With Quote
Old 02-10-2015, 09:14 AM   #529
Advanced Design
Advanced Design's Avatar
Great progress 99. Really good video too. Thanks for sharing!
Advanced Design is offline   Reply With Quote
Old 02-10-2015, 10:30 AM   #530
oldman3
oldman3's Avatar
Sweet video...Jim
Old 02-10-2015, 10:06 PM   #531
47 Fasttoys
47 Fasttoys's Avatar
Very nice 99, I must ask do you have some kind of foam or isolation between the plastic shroud and the radiator? I have found that plastic is really abrasive against aluminum and the radiator will expand as it comes up to temperature. Love the air ride system, it's on my may do list.
Rob
My '47 C.O.E build
47 Fasttoys is offline   Reply With Quote
Old 02-12-2015, 08:39 PM   #532
lower50's
lower50's's Avatar
Very nice job on the truck, that was a ton of work to bring that cab back to life. You will be so happy when you can drive it next spring!! Love the Viair, accuair stuff. Just got my air system going today. I agree with the relays too small of wire. I used a ford style starter solenoid.
http://67-72chevytrucks.com/vboard/s...d.php?t=648459
https://67-72chevytrucks.com/vboard/...d.php?t=769441
1951 MG TD
1967 Jeep CJ5 1.9L TDI 33X13.5X15 Mud Grapplers.
1952 GMC 9700 p/u 7.3L diesel on air, dually
lower50's is offline   Reply With Quote
Old 02-14-2015, 03:11 PM   #533
99 to Life
99 to Life's Avatar
2-14 thanks gentlemen. 47- I don't have any insulator between the two. I did have some rubber grommets on the other side, but they were getting sucked in as I didn't have washers small enough to use. I guess I'll take me chances for now.
-lower50's thanks yes the cab has killed my timing. I have about 150 hrs in it. maybe with doing firewall too, can't recall right now. I do have all my hours logged though. The firewall and back of cab were around 20hrs of work alone. My door bottoms and miscellaneous parts cost me about 40hrs in metal, body and paint. I have over 500hrs in the build so far. not including dash and engine.
So here is a cupholder/ dock I'm working on. I'll have two air gauges in there as well. It will be all metal finished and depending on interior I may leave the metal look or paint it. this isn't the final shifter, and I'll be making a custom boot.
Old 02-14-2015, 03:51 PM   #534
Advanced Design
I like the cup holder. Looks good!
Old 02-14-2015, 07:50 PM   #535
hotrodelrod
hotrodelrod's Avatar
looking good! You have some great ideas. Thanks for sharing.
Rick
hotrodelrod is offline   Reply With Quote
Old 02-14-2015, 09:18 PM   #536
99 to Life
99 to Life's Avatar
thanks guys, I was going to put the air gauges in the cups to hide them, but I didn't wanna have to lean up to look at the pressure. Also would have been cool cause the gauges woulda lit up the cups. I'm thinking on maybe adding some type of light to this, so when you turn on the courtesy lights (that I'm custom rigging) it would display the air ride stuff. I really didn't want anything in that spot but as we all know some areas need to be infringed upon when building custom things.
I'll be working on another console that will be up up under the dash a little more. It will house the Vacuum, Water, Oil, Volts, Air fuel ratio and possibly fuel and tank pressure gauges. I really contemplated making all one console, but I felt it would be a little too much of a bucket seat thing, and also I want to be able to have a 3rd person sit in the truck if I got in a pinch. So there will be some leg room left with having two consoles.
Old 02-17-2015, 12:20 AM   #537
99 to Life
99 to Life's Avatar
2-16 mon, so here is the cupholder/console for the air ride controller and gauges. These are dual needle so these two run all 4 bags. I'll have tank pressure gauge on its own under dash by steering column, along with a toggle switch to control the compressors manually if needed.
Started on my other more hidden console/cluster. I had a much more elaborate idea, but with lack of tools and already over planned hours on this build, I went with a simple effective design. I'll have 5 gauges down below where you'll just be able to see them from the drivers seat. So not too in your face and not too hidden. Vac, Oil, Temp, Volts and Fuel will go there. I'm planning on making a recessed shelf to hold say your phone or things like that. Up top on the console I'll have a usb and another ciglighter outlet. I'll most likely keep my air fuel ratio gauge up there outta site somewhat.
So like most things on this build. I got it ruffed in, just need to go back and button a million things up. I'm gonna paint the bigger console and might leave the cup holder one raw metal. I'm ditching this shifter too.
Old 02-17-2015, 08:06 AM   #538
Advanced Design
That is a neat idea 99. Just lots of details on a build.....and a lotta hours.
Old 02-17-2015, 10:35 AM   #539
lower50's
lower50's's Avatar
Your cup holder/console look great nice use of space!!
1951 MG TD
Old 02-17-2015, 12:40 PM   #540
99 to Life
99 to Life's Avatar
thanks guys, yeah lots of hours that is for sure. Only thing keeping my sanity is the fact that even if I had the truck done, I couldn't drive it outta the garage cause of the 3ft of snow built up in my compound. That and I have to work as fast the things I can afford per month. Catch 22 on all the metal repairs I made to the cab, doors etc. It gave me things to do with not having to spend a ton of money, but... it ate up a ton of hours. More hours I put in, the more I learn so its not a bad thing. Its just hard to imagine doing all the rest of the cars and trucks I have bc I know how long they take to do them right or to my liking.
Old 02-17-2015, 04:08 PM   #541
IWanna49
IWanna49's Avatar
All that time will build you a good rep for people looking for someone to build for them tho. Nice work on the console. I'm gonna steal a bunchl of your ideas!!
-Greg
'51 3600/s10 swap- in progress
Build thread:
http://67-72chevytrucks.com/vboard/s...d.php?t=641511
IWanna49 is offline   Reply With Quote
Old 02-17-2015, 05:51 PM   #542
99 to Life
99 to Life's Avatar
thanks 49'. its all about balance. You can take whatever ideas of mine you want. I'm considering a type of aftermarket gauge cluster on the next build. I hate the look of most all of them, but I could make my own face plate to keep it more original looking. that way it would save me alot of gauges in that console. Especially since I think the next build I'm doing an LS engine so all the sensors are electronic anyway.
Old 02-17-2015, 06:58 PM   #543
rusty76
rusty76's Avatar
You're doing fine work. I enjoy reading your builds.
http://67-72chevytrucks.com/vboard/s...d.php?t=581873
The low buck build threads. Check'em out!
http://67-72chevytrucks.com/vboard/s...d.php?t=666022
My build thread
Crossmembers CC
rusty76 is offline   Reply With Quote
Old 03-02-2015, 08:51 PM   #544
oldman3
oldman3's Avatar
Hey 99, what's going on, haven't heard from you in awhile, snowed it or what?...Jim
Old 03-03-2015, 12:04 AM   #545
99 to Life
99 to Life's Avatar
3-2 yeah I know I skipped a week on posting cause there weren't much pics. I'll start with this bunch. Finally painted my console thingy and started plumbing in the gauges. Still need my fuel gauge. Money is non existent right now. I added a usb/power port up top just for extra convenience for a phone charger etc. I also added an amber led light on both sides and top of the console which will be controlled by a toggle, so... if I want to really light up the interior I can. I'll also have some behind the seat etc.
I'm reposting the before pic so you can see how much of this console will be seen, basically not much at all. Carpet will come right up to it and I think it will blend in good.
Old 03-03-2015, 12:19 AM   #546
oldman3
oldman3's Avatar
Pics a little dark, but looking good on the console...Jim
Old 03-03-2015, 12:23 AM   #547
99 to Life
99 to Life's Avatar
here is the LED light, not wired up. so I'll get a shot of that next week. Also here is my dock I made for under the dash so I can mount my HUBS for the negative and positive gauge wires. this makes life a ton easier. My friend thinks I'm nuts for wiring each pos and neg gauge wire on its own. I made it this way so you can pull the gauge out and diagnose or change it without disturbing the rest. I also have my Efan relay docked here and a power dist block.
I loomed dang near every wire, even if it was just a single wire. I ran a pos and neg main wire from the dock up through the door pillar and back to the battery, so I know I'll always have a solid ground and plenty of power to the front if I ever need to add anything. I also am labeling every wire I can.
I'v spent some time making custom harnesses for everything too. lotta wires to light up these 5 guages, the 3 bag gauges, air fuel gauge and then the tach and speedo.
Speaking of tach, I'm retrofitting one into the original gauge cluster. It will be very cool and I can't wait to get it done and show everyone. At a glance you'd think it was a stock speedometer.
Old 03-03-2015, 09:14 AM   #548
Advanced Design
Prett trick wiring work 99! Appreciate the update.
Old 03-03-2015, 11:09 AM   #549
reaper71
reaper71's Avatar
Coming along nicely...
reaper71 is offline   Reply With Quote
Old 03-03-2015, 06:40 PM   #550
IWanna49
IWanna49's Avatar
Great attention to detail!
-Greg
Build thread:
49' ad, bagged 49, bagged 49 in pa
