01-11-2017, 12:27 PM | #526 |
Re: S10 Swap how to
put a level on your rocker and see where you are at. the front of the s10 frame drops a little so leveling your mounts won't level your cab. I make my mounts out of 4x4 tubing once I get the height I'm after I then weld the extra supports on the mounts that sit on top of frame. Most the cab mount designs on here incorporate the extra support that sits on top of frame. Problem with that is, you have no adjustability up or down.
51' 99toLife finished 2011,355 sbc,5speed, patina, redoing whole truck, inter, bags, etc http://67-72chevytrucks.com/vboard/s...d.php?t=382481 49Hardtimes s/10 susp- bagged, vortec sbc, 5 speed, patina, sold http://67-72chevytrucks.com/vboard/s...d.php?t=594874 VIDEOS https://youtu.be/E8zHhjgS_lA https://youtu.be/E8zHhjgS_lA Geronimo 54' LS engine, static drop IFS, Client build, just about done http://67-72chevytrucks.com/vboard/s...62#post7399162 52' 3100 Slowly in progress, will be painted two toned, have 235 with a t-5, lowered OG frame Other projects, 49' farmuse 3100, killer Patina, will be slammed, LS engine, full done interior up next! www.coffeeandcustoms.com |
01-11-2017, 09:56 PM | #527 | |
Re: S10 Swap how to
I don't think you're going to want your cab raked on your frame. That two inches to tall and the back of the cab will end up being 6 inches to tall at the back of the bed. Personally, I think the floor of the cab should sit level with the frame. Hopefully you just have the mounts tacked on. I'd cut them and and adjust. |
01-11-2017, 10:27 PM | #528 | |
Re: S10 Swap how to
The front mount is placed 2 in. behind the oval hole on the frame, I can thank Bartman for that: https://www.youtube.com/watch?v=cdgYy5YtW8k. The center to center distance between the front and rear mounts on mine is 36-1/4 in. I'm running 2 in. drop spindles on the front and 2 in. drop blocks in the back (started with 3 in. blocks but ended up with 2 in. blocks). That puts my running boards nearly level with a slight rake, about 1/2 in. to the rear. The front bumper sits 5-1/2 in. from the ground. Having driven it around I think that it is as low as I would want to go with a static drop. With these swaps, getting the cab placed properly is critical. Once you know you've got the cab where you want it, getting the front clip, bed, and running boards in place is easy since they are placed off the cab. There is no need to shell out $1,000+ for a conversion kit that really doesn't get you that far when this will get you the same distance for $100 or so in materials. Downloadable PDFs which are a bit clearer are available at the following links: https://drive.google.com/file/d/0B29...ew?usp=sharing https://drive.google.com/file/d/0B29...ew?usp=sharing From the top of the frame to the bottom of the cab floor support measures 4 in. I ran an 11 GA 2x1 rectangular tubing between the two rear cab mounts and bolted to the bottom of the floor. Of course more pics are in my build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=664837 Last edited by HUSSEY; 01-11-2017 at 10:44 PM. |
01-11-2017, 11:11 PM | #529 |
Re: S10 Swap how to
Thanks for the replies guys. Will have my cab leveled on the rocker and make the final judgement.
01-12-2017, 01:20 PM | #530 |
Re: S10 Swap how to
hussey, great blueprints and pics. you make it too easy for some guys! I 100% agree with taking a little bit of time and material and making your mounts. No need to shell out money for a kit. Unless it is completely adjustable and well under 1k I think its a waste.
01-13-2017, 10:18 AM | #531 |
Re: S10 Swap how to
You got that right!
when I was putting the floors etc. back in "Orangepeel" I damn near made everything from mounts,braces,floor pans etc. because I could, rather than buy it. Just remember it's "only time" It's cheaper than paying a Grand for mounts that you can build yourself plus the satisfaction of making them! Nice job BTW!! Mark..
http://67-72chevytrucks.com/vboard/s...d.php?t=645774 Project Orangepeel 52 A.D. http://67-72chevytrucks.com/vboard/s...d.php?t=653337 John's LS 49 dodge http://67-72chevytrucks.com/vboard/s...d.php?t=655780 Blake's 67 GMC LS stepside http://67-72chevytrucks.com/vboard/s...d.php?t=690527 Reed 78 FJ40 Rebuild http://67-72chevytrucks.com/vboard/s...d.php?t=733259 Barger's 78 FJ40 |
01-13-2017, 12:34 PM | #532 |
Re: S10 Swap how to
Edited by Forum Staff
Just cleaning up unnecessary comments.
51' 99toLife finished 2011,355 sbc,5speed, patina, redoing whole truck, inter, bags, etc http://67-72chevytrucks.com/vboard/s...d.php?t=382481 49Hardtimes s/10 susp- bagged, vortec sbc, 5 speed, patina, sold http://67-72chevytrucks.com/vboard/s...d.php?t=594874 VIDEOS https://youtu.be/E8zHhjgS_lA https://youtu.be/E8zHhjgS_lA Geronimo 54' LS engine, static drop IFS, Client build, just about done http://67-72chevytrucks.com/vboard/s...62#post7399162 52' 3100 Slowly in progress, will be painted two toned, have 235 with a t-5, lowered OG frame Other projects, 49' farmuse 3100, killer Patina, will be slammed, LS engine, full done interior up next! www.coffeeandcustoms.com Last edited by 63 & 64 Bowties; 01-15-2017 at 05:32 PM. |
01-13-2017, 04:46 PM | #533 |
Re: S10 Swap how to
mounting the body is only about 15% of the work. the 85% left takes determination and critical thinking. these are very easy to start and very hard to finish!
the mass of men live lives of quiet desperation if there is a problem, I can have it. new project WAYNE http://67-72chevytrucks.com/vboard/s...d.php?t=844393 Last edited by joedoh; 01-15-2017 at 08:04 PM. |
01-13-2017, 07:43 PM | #534 |
Re: S10 Swap how to
Just cleaning up unnecessary comments. Last edited by 63 & 64 Bowties; 01-15-2017 at 05:32 PM. |
01-14-2017, 09:38 AM | #535 |
Re: S10 Swap how to
Question...I've got a 48 I'm building. When I bought the cab the previous owner cut the whole floor out. I just got the cab sandblasted and about ready to start putting new cab corners and rockers on it. Toeboard is shot, so I'll replace that with 18 gauge sheetmetal. Still looking for an S-10 for my project, but I've got a 5.3 ls that I built for one of my other vehicles but decided I'm going to put it in this truck instead. Hoping to find a late 80s model S-10 so I can use the 700r4 transmission. I want to build my own floor, but does anyone know with this setup if I need a transmission hump in the floor? I'd like to keep it as flat as possible. Just want to know if I should wait to do the floor until I've got my frame and motor/transmission in place or if I can go ahead and build the cab so it's done.
01-14-2017, 11:41 AM | #536 | |
Re: S10 Swap how to
there are so many different ways to set up the engine/trans mounts and body mounts that I would at least wait to build the tunnel. a good example is husseys truck, the mounts on his truck and mine were roughly the same height but he needed a much larger trans tunnel than I did.
the mass of men live lives of quiet desperation if there is a problem, I can have it. new project WAYNE http://67-72chevytrucks.com/vboard/s...d.php?t=844393 |
01-14-2017, 11:54 AM | #537 | |
Re: S10 Swap how to
01-14-2017, 01:16 PM | #538 |
Re: S10 Swap how to
01-15-2017, 12:00 PM | #539 |
Re: S10 Swap how to
Just cleaning up unnecessary comments. Last edited by 63 & 64 Bowties; 01-15-2017 at 05:33 PM. |
01-15-2017, 03:31 PM | #540 | |
Re: S10 Swap how to
My point, if you want to buy a kit, go buy it and build your truck with pride. Just don't confuse this thread in anyway of being a kit. Clay |
01-15-2017, 04:02 PM | #541 |
Re: S10 Swap how to
Hello;
Thanks Clay 54; If you need information to build a truch then use that information. If you just want a kit truck then just have someone build you one out of kit on line. Most or us on this blog enjoy working with our hand to build something we can call our own. T-P Auto Tim |
01-15-2017, 04:27 PM | #542 |
Re: S10 Swap how to
51' 99toLife finished 2011,355 sbc,5speed, patina, redoing whole truck, inter, bags, etc http://67-72chevytrucks.com/vboard/s...d.php?t=382481 49Hardtimes s/10 susp- bagged, vortec sbc, 5 speed, patina, sold http://67-72chevytrucks.com/vboard/s...d.php?t=594874 VIDEOS https://youtu.be/E8zHhjgS_lA https://youtu.be/E8zHhjgS_lA Geronimo 54' LS engine, static drop IFS, Client build, just about done http://67-72chevytrucks.com/vboard/s...62#post7399162 52' 3100 Slowly in progress, will be painted two toned, have 235 with a t-5, lowered OG frame Other projects, 49' farmuse 3100, killer Patina, will be slammed, LS engine, full done interior up next! www.coffeeandcustoms.com Last edited by 63 & 64 Bowties; 01-15-2017 at 05:33 PM. |
01-15-2017, 05:00 PM | #543 |
Re: S10 Swap how to
01-15-2017, 05:34 PM | #544 |
and a few others
Re: S10 Swap how to
Please, let's don't ruin this excellent thread with bickering.
Now, back to the builds, okay?
Bill US Army Vet -193rd Infantry BlueRidgeMuscleCars.com “The greatness of a nation and its moral progress can be judged by the way its animals are treated” Gandhi |
01-15-2017, 07:48 PM | #545 |
Re: S10 Swap how to
Got my cab situated, level rockers/cab floor seems perfect. Thanks for the help guys.
For those using a 5.3 vortec in your build, any suggestions for headers? I'm currently leaning towards stock f body headers that don't have either egr or air injection ports. Motor sits perfectly in this chassis without much modification to the floor of the cab. Would like to know before I start buying multiple headers. thanks guys |
01-15-2017, 08:09 PM | #546 | |
Re: S10 Swap how to
01-16-2017, 10:20 AM | #547 |
Re: S10 Swap how to
I have used the Speedway LS block hugger headers on 3 diff. builds and work great # 9300114 $200
Mark
01-16-2017, 09:55 PM | #548 |
Re: S10 Swap how to
I'm so glad I found this thread and you've done such a kick ass job posting everything. I just picked up a 98 2wd s-10 for my 55'. I wanna go the route of a 350 with a 700r4. Is this a possible configuration? I'm definitely green behind the ears when it comes to this. So any constructive criticism is encouraged. Thanks again for your hard work!
01-16-2017, 10:17 PM | #549 | |
Re: S10 Swap how to
www.olesargecustoms.com email: chris@olesargecustoms.com '48 build: http://67-72chevytrucks.com/vboard/s...d.php?t=541904 '33 build: http://67-72chevytrucks.com/vboard/s...=1#post6232888 '49 build: http://67-72chevytrucks.com/vboard/s...=1#post6364475 |
01-16-2017, 10:49 PM | #550 |
Re: S10 Swap how to
CoreyH; I would think twice about using that 700R4, in order to realize the benefits of that 5.3, you will need a 4L60E trans.
Thank you Clay, that is why I made this thread. For the DIY guys. If you want to buy a kit, then by all means by a kit. But, don't come to me when it looks like crap. Wanting me to tell you how to fix it. This thread is for serious builders, who want to build their trucks the right way the 1st time.
