Old 07-22-2021, 08:02 AM   #526
SCOTI
SCOTI's Avatar
Re: New 64 Stepper Project
Nice touch.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 07-22-2021, 08:05 AM   #527
The Rocknrod
Moderator
The Rocknrod's Avatar
Originally Posted by SCOTI View Post
Nice touch.
Thanks Scoti.
Old 07-22-2021, 08:13 AM   #528
Joe Pass
Joe Pass's Avatar
love the striping....
Joe Pass is offline   Reply With Quote
Old 07-22-2021, 11:21 AM   #529
realvc
realvc's Avatar
Pinstriping
Vince
Galatians 6:14
62 SWB stepside, 94 Wrangler, 99 Z71, 99 vette
My Project http://67-72chevytrucks.com/vboard/s...d.php?t=719086
"If it's too loud, you're too old"
realvc is offline   Reply With Quote
Old 07-22-2021, 11:34 AM   #530
The Rocknrod
Moderator
Thanks Joe
Originally Posted by realvc View Post
Pinstriping
Thank you.
Old 07-22-2021, 03:29 PM   #531
cwcarpenter98
cwcarpenter98's Avatar
So, when are you going to wash the truck and give us some full beauty shots? These teasers are killing me
Christian Carpenter
Overdrive wiring here
1981 C10 - Penny 305, th350 --> Soon to be 350, Saginaw 4 speed
1995 Dodge Dakota Sport
Old 07-22-2021, 05:54 PM   #532
The Rocknrod
Moderator
Post 491 has them.
Old 07-22-2021, 10:02 PM   #533
cwcarpenter98
Originally Posted by The Rocknrod View Post
Post 491 has them.
Good point, but I meant with all the pinstriping on it too. Pinstriping or no pinstriping, your truck has turned out great!
Christian Carpenter
Old 07-22-2021, 10:08 PM   #534
The Rocknrod
Moderator
Thank you.
Old 07-29-2021, 09:00 PM   #535
justa dumb hick
justa dumb hick's Avatar
Perfect. Absolutely perfect.
The pinstriping really finishes pulling it all together.
A long trip indeed, I really enjoy seeing them completed. Lotta hours into this one.
Outstanding, Chief!
-JDH
Insomnia is a terrible thing to waste
https://www.youtube.com/watch?v=jWYVs7widI0
(Misanthropic curmudgeon attempts starting old truck in house at 2AM)
justa dumb hick is offline   Reply With Quote
Old 07-29-2021, 09:19 PM   #536
The Rocknrod
Moderator
Thank you
Old 07-29-2021, 10:40 PM   #537
forestb
forestb's Avatar
Not bad for a step side
forestb is offline   Reply With Quote
Old 07-30-2021, 07:07 AM   #538
The Rocknrod
Moderator
Thanks forest.
Old 07-30-2021, 09:23 AM   #539
aggie91
I'm just glad to be here!
aggie91's Avatar
Pinstriping is just enough on this truck. I like the one to separate the white and the red. Nice touch!
Karl
1965 Chevy Stepside(Grandpa's Old Blue) and (July 2015 Shop Build!)(2020, the Saga Continues)
http://67-72chevytrucks.com/vboard/s...d.php?t=372424
The LST Challenge:
http://67-72chevytrucks.com/vboard/s...=1#post7812257
Korbin's 1st Square: "Sunburn"
http://67-72chevytrucks.com/vboard/s...d.php?t=418618
1985 GMC Sierra: "White Trash", Korbin's 2nd now...
http://67-72chevytrucks.com/vboard/s...d.php?t=632305
Henry - 1984 Chevrolet, Owen's 1st Square
aggie91 is offline   Reply With Quote
Old 07-30-2021, 09:35 AM   #540
The Rocknrod
Moderator
Thank you aggie91.
Old 08-10-2021, 03:35 PM   #541
The Rocknrod
Moderator
Drove it into Waco to get a tank of gas, about 15 miles each way. Up and down hills back-roads, stop lights etc. from 25 to 65 MPH.
Came home and used a laser temp meter and found these temps on the engine. I dont know if thats good or bad?
Top of radiator - 120 degrees
Top of Thermostat Housing - 191
Under the Thermo housing - 171
Head between first 2 exhaust ports driver side - 192
Front of head - 191
Block - 191
Temp Gauge reading (Lectric Limited sender for year model gauges):
So what do you think?
Old 08-10-2021, 04:35 PM   #542
SCOTI
SCOTI's Avatar
Front of head - 191
Block - 191
That all looks very acceptable. Head's will be the hottest so those areas @ the 190° range is good.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 08-10-2021, 05:05 PM   #543
The Rocknrod
Moderator
Thanks for your help, wasnt sure.
Old 08-10-2021, 05:20 PM   #544
SCOTI
SCOTI's Avatar
What temp range thermostat are you running?
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 08-10-2021, 05:25 PM   #545
The Rocknrod
Moderator
180
Old 08-10-2021, 05:39 PM   #546
Joe Pass
Joe Pass's Avatar
I have the same exact readings.....I feel better too...lol...
Old 08-10-2021, 07:26 PM   #547
SCOTI
SCOTI's Avatar
180
I would expect around/within 15° of the thermostat opening point.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 08-10-2021, 07:55 PM   #548
The Rocknrod
Moderator
So 11 degrees is good huh?
Old 08-10-2021, 11:31 PM   #549
cwcarpenter98
My 63 gauge runs about that same degree on the sweep with my 180 thermostat and letric limited sender unless I'm running in 95+ weather when I've been going for a few hour At that point it will sit about in the middle. When I had a 195 thermostat in it, the gauge was almost pegged constantly
Christian Carpenter
Old 08-11-2021, 12:26 AM   #550
MT65
Front of head - 191
Block - 191
Those temps look fine, if a person could maintain a temp of 190 degrees, that would be a good fuel burn and easy on the engine, key word is maintain.
Question, is that still an amp gauge, or has it been mod to a volt meter? With what I saw in your engine compartment, I would be using a 100 amp alternator at minimum, if that is an amp gauge, it won’t handle it well….
MT65 is offline   Reply With Quote
