#526 |
![]() Join Date: Jul 2015
Re: Starting my engine build
Born Again, and looking quite well I may add.
#527 |
#528 |
Is it safe to pressure wash in the motor well?
#529 |
Hard to believe it used to look like this
#530 |
I'm also wondering about new energy suspension body mounts. I was under the truck today and they all look like squished cracked donuts, bulging out the sides from being so old. Definitely going with energy suspension motor and transmission mounts, and possibly replacing bushings on the major parts of the suspension.
I know I'm adding a lot of work but the more I look at the engine and compare to the motor well and wiring, the more I wanna do this right and be thorough |
#531 |
A little advice? Concentrate your energy on getting that engine back in and running first or it will go on forever.
Mike. Swamp Rat build thread : http://67-72chevytrucks.com/vboard/s...d.php?t=595019 72 3/4T 4X4 4" BDS Lift 33" BFG's |
#532 |
I agree totally, I was just thinking that if there are things to do while the motor is out that would become a real PIA when it's back in, get those while the gettin is good
#533 |
Anybody pressure wash without issues? All the grease and built up oil would be much easier with a pressure washer
#534 |
#535 |
I see no reason why you couldn't power was the engine compartment. You have the Tranny out right? if not, just try not to get water in there, plus watch around your electrical connections. degrease it well, and spay away!
#536 |
Well it took 2 hours to build all the MSD wires but I think the nicer look is worth the time. Waiting on de-greaser to soak in and then pressure washing.
#537 |
Pic
#538 |
Do you guys shave this extra RTV off or just leave it?
#539 | ||
"I ain't nobody, dork."
If you have headers... those wires will not work. You will need 90 degree boots to clear headers.
But they look killer though! ![]() I have always built my plug wires while the engine is in the rig. Lots of stuff that will or could be in the way while figuring out the best route of plug wires. Gary
'cuz chicks dig scars... My 1972 GMC 1500 Super Custom (Creeping Death) "long term" build thread. The Rebuild of Creeping Death after the wreck Quote:
#540 |
I would leave the RTV on the intake, up to you i guess.
I agree with Gary on the 90 degree boots so guess you could bolt the headers up temporarily and see how they will work.
#541 |
Well there goes 100 bucks and 2 hours
#542 |
![]() Join Date: Feb 2010
Location: Falls City, Nebraska "100 Miles From Nowhere"
Not necessarily... http://www.jegs.com/i/MSD-Ignition/1...rentProductId=
Michael of the clan Hill, "Two Seventy Two's" 71 1-ton Dually 350 4-Speed 71 C/50 Grain Truck, 350 Split-Axle 4-Speed 02 3/4 ton Express 14 Indian Chief Vintage 1952 Ford 8N, "Only Ford Allowed On The Property" ![]() "Be American, Buy American" ![]() Last edited by Ironangel; 02-25-2016 at 02:54 AM. |
#543 |
60-66 Nut
![]() ![]() Join Date: Mar 2007
Wait until you get the headers bolted up and see if maybe some of the straight plug boots will work. Then just change the ones that definitely need a 90.
#544 |
I have some appointments at the VA today but hoping to get the motor well wrapped up by tonight. I pressure washed yesterday evening and was amazed at just how much crud came out and off the truck. After a little masking it'll be ready for some paint.
New motor mounts and a transmission mount will be here today. It looks like I could be firing this thing up pretty soon. For the first startup I'll have some zddp break-in oil, and I need to get a tachometer so I can manage the RPM's during cam break-in. Technically I could start the truck after I get the new motor mounts and drop the motor in, and I suppose that's the shortest route to a start up. Without getting to absorbed into other projects just yet, I think it'd be wise to go ahead and get a stall converter now and be done with it. There's been a lot of controversy over what stall to run and who makes a good converter, and I can't say that I know what to go with yet, but I'd like to get one now so I can drive it after break-in and not fight the brakes and all that fun stuff. |
#545 |
Pic
#546 |
![]() Join Date: Dec 2013
I'm wondering now if you see why many of us suggested pulling the engine from the start ? You end up with a much better result for your effort and money and it looks better than if you paid someone to just drop parts in .How many small things did you find that really needed to be addressed ? It looks great and you should be proud of the work you've done ! And I don't give away compliments often ! That's why they call me Grumpy old man .
![]() Now get it dialed in and running so you can move onto the suspension and brakes to make it safe to unleash those new found horses . ![]() Did you get the right trans mount yet ?
![]() 1967 Factory short bed - Old school '71 - 350 / 4bolt / 487 heads / Edelbrock C3BX Muncie M-22 4 speed / Hurst Comp plus Factory 12 bolt posi 3.73 / 255-70-15 Smoothed firewall / Factory cowl induction Power disc brakes / power steering / 3.5-5" drop |
#547 |
A little time saving trick when you start masking: For hoses, lines and those little things you want to keep paint off of, pull out the aluminum foil and wrap the small stuff with it. Much easier than paper and/or tape. And, easy to remove as well.
#548 | |
![]() ![]() Prothane mounts should be here today for motor and trans, and I got a oem crossmember too ![]() |
#549 |
I apologize for the redundancy here guys but I want to clarify because I'm buying parts. The truck has a th400, so do I need to change the transmission crossmember to one like the peice in the picture? And when I get a trans mount, will the parts work for a th400 when the drop down bars on the online catalogs don't specifically say TH400, they only ask the engine size for application
#550 |
Parts
