05-09-2020, 09:51 PM | #526 |
Re: A '54 named Busty
And room for a console or hand brake.
One seat looks taller but assume they are just mocked up. |
05-09-2020, 10:04 PM | #527 |
Post Whore
05-10-2020, 07:08 AM | #528 |
Post Whore
=== Turning Point ===
OK guys I wanted to say this because I think we have reached a significant mile stone, what I mean by that is that I have stripped down, uninstalled, taken apart as much as I was going to take apart on this build and it's onwards and upwards from here. Honestly I have gone even further than I have planned for Phase I of the project, but this being my third truck I learned grind once cry once, plus this was never planned to be a "frame off" restoration, so I am right where I need to be, and excited to start putting clean, painted, shinny [ahem] (semi flat) bits back on. Appreciate you all visiting, following along, advising, parts supplying, providing feedback and humor, this forum Rocks (thank you moderators) |
05-10-2020, 10:11 AM | #529 |
Way to go Greg....Nice save on the "54". Went to a good home!....you have made a ton of progress in a short amount of time. This will be a cool ride with or without Pebble beach golf pants. I like your newer seats better....thats an odd cutout in the bench, plans for 3pt belts?.I used power seats from a 93 Caprice in my 71. And 3pt belts from a 90's pickup.....using parts I have......what other glamourous interior plans?....Ed.
http://67-72chevytrucks.com/vboard/s...d.php?t=635605 |
05-10-2020, 10:47 AM | #530 | |
Post Whore
05-10-2020, 10:49 AM | #531 |
Post Whore
don't get me started on the sick sense of humor of the Auto Meter designer folks, but here is a mini rant:
They have an entry level (pronounced: affordable) line called Auto Gauge. Problem being they don't offer 2 5/8" Oil and Water electronic gauges, yes I found that out after already procuring their handsum 45° sweep Volt and Fuel gauges, oh well I'm just gonna have to buy another truck to put those into, I mean it would be a shame to let them sit on a shelf. And there is no way I am pulling up to Peggy Sues house with mechanical gauges, know what I'm sayin'. I am pretty sure had they offered those two in electronic form, they would not make any money on their more expensive lines as everyone including myself would just run these smart Auto Gauges (agree to disagree, ha ha) |
05-10-2020, 10:50 AM | #532 |
Post Whore
So then I decided on the Sport Comp gauges (yes with that stupid gray bezel) which by the way they will paint black for you at $25 extra per gauge, arghhhh Again I bought a couple of these only to find out the dash has reinforcement rings behind the cluster that I don't want to cut into so two of the 2 5/8" gauges won't fit along with the Speedo or Tach in each 6" opening. I just want to weld in the big 6" holes and cut holes in the filler panels only, so that you can still sorta reverse this process if you are so inclined down the road and not butcher any of the supporting bracketry behind the scenes.
05-10-2020, 10:52 AM | #533 |
Post Whore
On to the Z Series, these are sexy little darlings since they are black on black the way the General intended. The reason I passed on them the first time around is because they do not come in 2 5/8" (see Auto Meter sick humor comment above) So we step down to the 2 1/16" size for the Oil, Fuel, Water, and Volts quartet. [Note To Self: may wanna order a new set of bifocals.] Yes already started buying these too, hope these will work.
OBSERVATION: Trying to put together a set of matching Auto Meter gauges is like trying to find a fourth matching 70s mag wheel for your three legged dog, you know what I'm talking about!!! Last edited by Gregski; 05-10-2020 at 11:06 AM. |
05-10-2020, 11:01 AM | #534 |
Liking the seats, what are they out of.
I'm still thinking gauges, so looking forward to your solution.
8man-aka Robert 1948 on a S10 Frame, small block with a carb 1954 Cab, 53 Front and Bed, 50 Doors, S10 Frame, Power TBD Build thread: "]http://67-72chevytrucks.com/vboard/showthread.php?t=746899&highlight=wife%27s+48[/URL] [/URL]http://67-72chevytrucks.com/vboard/showthread.php?t=840204 |
05-10-2020, 11:09 AM | #535 | |
Post Whore
05-10-2020, 11:15 AM | #536 |
Now I see why the seats didn't look like 60/40, and there was some room between them. Interesting idea. I like it.
05-10-2020, 11:11 PM | #537 |
Post Whore
so I knocked out da wife with some hazel nut cheese cake and snuck off to the garage to shmeer some black paint on that rear shock crossmember finally
boy it is a major PITA to paint something like this on the truck and oh boy was my insane masking off job JUSTIFIED, there was a ton of overspray on all the white garbage bags (nothing worse than getting black paint on junk mufflers you literally pulled out of your friend's trash, ha ha) Last edited by Gregski; 05-11-2020 at 09:44 PM. |
05-10-2020, 11:14 PM | #538 |
Post Whore
scrubbed, washed, rinsed, and baking soda water neutralized the phosphoric acid which totally did its job over night
Fun Level: -2 not looking forward to welding up the 97 holes in the floor and firewall tomorrow! Last edited by Gregski; 05-10-2020 at 11:20 PM. |
05-10-2020, 11:18 PM | #539 |
Post Whore
yup, masked off just the ceiling and applicated some of that red rusty metal primer on it - covered well and turned out great
05-10-2020, 11:47 PM | #540 |
Post Whore
I remember when I redesigned my IH dash, the difficulty I had finding gauges that I could use...my fuel gauge is the oddball to the water/oil/volts....
05-10-2020, 11:52 PM | #541 |
Next time use black garbage bags for black paint, red bags for red, green for green etc. What you dont know wont kill you.......
05-11-2020, 12:14 AM | #542 |
Post Whore
05-11-2020, 12:15 AM | #543 |
Post Whore
05-11-2020, 08:09 AM | #544 |
The black crossmember looks good, and the ceiling was worth all the work.
05-11-2020, 09:51 PM | #545 |
Post Whore
today I set out to do something on the list, but first I just had to take care of something ever since I installed them, ie those Durango lower rear shock plates/brackets
the way they were installed I didn't even have 3" worth of clearance, and there was absolutely no give in the rear suspension given the redneck industry standard jump on the rear bumper test Last edited by Gregski; 05-12-2020 at 03:10 AM. |
05-11-2020, 09:52 PM | #546 |
Post Whore
so three leafs came off on each side - yes the 1/2" nuts snapped right off whilst gently twisted with the 18" cheater bar (threads on the remaining studs were wire wheeled clean and new grade 9 nuts applicated back on with lock washers)
05-11-2020, 09:55 PM | #547 |
Post Whore
may not be much of a difference, only 1" but we'll take it - there's some sort of line that you need to stay above I forget what it is called, I think it's so that when you get a flat tire you don't bottom out - also I realize those studs/bolts stick out but they are still not the lowest point, it's still the shock mount area
05-11-2020, 10:00 PM | #548 |
Post Whore
then it was time to install brand new GM 3RL/S44 aka 1344 series U joints in the Camaro? 57 1/2" drive shaft and replace the TH350 yoke with the bit larger TH400
I sacrificed my large C clamp to make it a U Joint presser outter inner jobbie Last edited by Gregski; 05-12-2020 at 03:17 AM. |
05-11-2020, 10:01 PM | #549 |
Post Whore
a few cuss words later, and job done (asked for MOOG 234s got these NAPA generics, oh well)
05-11-2020, 10:05 PM | #550 |
Post Whore
then I plugged the 3 holes behind the bench seat under what would have been the fuel tank
here I am using a washer to cut out a perfect round patch |
