Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current Classic GM Trucks Classifieds > The 1960-1966 Chevrolet & GMC Pickups Parts Board
Old 08-13-2015, 12:07 AM   #551
HSRACER
HSRACER's Avatar
Re: Power Steering Adapter Plates
I have a complete front cross member and power steering set up for a small block out of a 1971 truck. What will I need to purchase from you to make it all work?
It is going in a 1966 c10. Thanks. Also would like to put power brakes on it as well since the front end is a 5 lug disc setup. Thanks
HSRACER
Slammed 53 5 window
Blown/Bagged 54 Pickup
Patinaed 67 LS stepside
Supercharged 67 Nova
Bagged 69 Suburban Turbo'ed 5.3 LS
HSRACER is offline   Reply With Quote
Old 08-13-2015, 01:41 AM   #552
Captainfab
60-66 Nut
You will need a steering box adapter plate. If you are going to keep the original steering column, you may need the tube and flange if you do not have a drill press and a welder to reuse the original flange. Then a booster bracket, but to use a '71-'72 booster you will have to elongate the holes slightly. This is why the '71-'72 boosters are not on the list of compatible boosters. Will you need the standard booster bracket, or the one with the hydraulic clutch conversion? And in bare steel or satin black powder coat?
Old 08-13-2015, 05:12 AM   #553
northern 85
northern 85's Avatar
Can i get a shipped price on a adapter plate for a 64 c10,thanks 04937
northern 85 is offline   Reply With Quote
Old 08-13-2015, 11:11 PM   #554
Captainfab
60-66 Nut
If you need just the steering box adapter plate the price is the same as in post #1 of this for sale thread........$60.00 shipped. If you also need the tube and flange the total is $81.65.
I will also send you a PM.
Old 08-14-2015, 03:27 PM   #555
Mikecc6
Captain
Would you please send ordering info for steering box adapter plate, tube and flange?
Mike
Mikecc6 is offline   Reply With Quote
Old 08-14-2015, 11:30 PM   #556
Captainfab
60-66 Nut
I'll send you a PM with ordering and payment info.
Originally Posted by Mikecc6 View Post
Captain
Mike
Old 08-15-2015, 11:44 AM   #557
Mikecc6
Got PM. Sent payment via PayPal.
Old 08-17-2015, 12:17 AM   #558
Captainfab
60-66 Nut
Payment received. I will ship your order tomorrow (Monday).
Old 08-19-2015, 01:11 AM   #559
rudyyloverboiii
Captain fab, u don't happen to have a ps pulley lying around that u don't need do ya?
rudyyloverboiii is offline   Reply With Quote
Old 08-19-2015, 11:45 PM   #560
Captainfab
60-66 Nut
A pulley for the pump or the crank? For what engine? If a V8 does it have a short water pump or long?
Old 08-20-2015, 02:40 PM   #561
rudyyloverboiii
For the pump. I got it off a 78 dont remember the block I took it off or water pump. Maybe a small block. then it leaked so bought a pump from summit n tried to reuse my pulley but I bent it
Old 08-20-2015, 11:07 PM   #562
Captainfab
60-66 Nut
OK, so you need a power steering pump pulley for a small block with a long water pump? Does your pump shaft have a keyway and a nut on the end or is it a press fit?
Old 08-21-2015, 12:34 AM   #563
rudyyloverboiii
It's pressed in
Old 08-21-2015, 12:55 AM   #564
Captainfab
60-66 Nut
I'll look and see if I might have one.
Old 08-27-2015, 10:30 AM   #565
Jimal
Jimal's Avatar
I've read enough. PM sent.
Jimal is offline   Reply With Quote
Old 08-28-2015, 01:52 AM   #566
Captainfab
60-66 Nut
PM replied to
Old 09-05-2015, 09:23 PM   #567
wcstory
wcstory's Avatar
Just finished a PS swap on my 1966 GMC w/ 305 v6 using Captn's brackets.
I ordered a rebuilt 1978 steering box online from AutoZone, free shipping and 20% off. The core return was to a local store so no shipping.
On the template that comes with the kit I cut out the holes marked existing. Taped the template to the frame and center punched the new hole locations.
I was going to weld a collapsible shaft in but the one I had was too long.
After I had the gear and shaft all mounted I tack welded the plate to the frame, removed the box and welded it up solid. I used the old holes as plug welds. OK, yes I'm a bit compulsive.
wcstory is offline   Reply With Quote
Old 09-18-2015, 02:54 PM   #568
OldChevy61
OldChevy61's Avatar
Capt. Any update on a 62 kit. Also would it be best to wait until the cab is back on to make sure everything is lineing up. I'm on bare frame right now,about ready to put co trol arms and steering back in.
OldChevy61 is offline   Reply With Quote
Old 09-18-2015, 11:46 PM   #569
Captainfab
60-66 Nut
Sorry but no I do not have an update on the '60-'62 steering box adapter plate. Despite all my efforts for the past few years, working 80 hrs a week every week, every month and not being able to keep up, I just do not have any idea when I may be able to get to it. All I have to offer is what you have recently seen in a couple other threads. I have not installed a steering box onto a '60-'62 frame, so there are no installation instructions nor a template.
Yes I would advise to have your cab in place so as to have a reference as to the position of the steering column.
Old 09-19-2015, 11:54 AM   #570
OldChevy61
OldChevy61's Avatar
Thank you sir.
Old 09-29-2015, 12:07 AM   #571
Barba Negro
Interested in mount for my 68 k10. Thanks
Barba Negro is offline   Reply With Quote
Old 09-29-2015, 01:13 AM   #572
Captainfab
60-66 Nut
I replied to your PM.
Old 10-09-2015, 10:08 AM   #573
62 short step
62 short step's Avatar
John,
Send me your payment info for a plate please for a 66. Shipping to 70739.
Thanks!
www.louisianaclassictruckclub.com
1965 c-10
86 chevy c/k 20
62 short step is offline   Reply With Quote
Old 10-09-2015, 11:11 PM   #574
Captainfab
60-66 Nut
PM sent Jeremy......
Originally Posted by 62 short step View Post
John,
Thanks!
Old 11-01-2015, 11:22 AM   #575
HSRACER
HSRACER's Avatar
So I know I need a power steering spacer bracket and a power brake booster bracket. I would like the booster bracket in black powder coat finish.
The other question I still have though is can I use a steering column out of a 67-72 in the 64 truck when I am converting to your spacer. I have everything from a donor truck. I am still not sure if I will have to cut the shaft and flange or just use the entire donor column?
If I still need to cut the flange I guess I will need one of your flange kits as well. I am ready to paypal you for what ever the total price is. Thanks for your help!
HSRACER
Slammed 53 5 window
