07-18-2011, 08:44 AM | #1 |
Home Built '87
Re: LS1 into a 73 cheyenne
This is going to be the truck with the nicest finish on here!
Gordon 1998 White Chev ext cab 2WD (Summer Project) http://67-72chevytrucks.com/vboard/s...d.php?t=408424 1987 Chev Silverado SWB (Winter Project Rebuild) http://67-72chevytrucks.com/vboard/s...d.php?t=424833 Truck Club http://67-72chevytrucks.com/vboard/s...d.php?t=466969 |
07-24-2011, 12:15 AM | #2 |
I got all my items i was waiting for, i did a quick test fit but didnt have enough time to complete the assembly. I still need tie rod ends and hardware to bolt up the rack and hubs.
07-24-2011, 12:20 AM | #3 |
Dry test fit, good so far I need to grind the spindles having some minor issues. Billet hubs with ARP studs and mogul bearings and timken seals.
07-24-2011, 12:24 AM | #4 |
Rotors and calipers clear the wheel but as i predicted the caliper does not clear the spokes, need to run an adapter.
07-24-2011, 07:24 AM | #5 |
67-72 parts collector,…
Where did you buy the front suspension and Corvette brake set-up?
07-24-2011, 09:56 AM | #6 |
Happy to be here
Sexy set up for sure. Did we miss the details?
07-24-2011, 11:57 AM | #7 |
X2 very nice set up.....
nOtHiNg LiKe ThE gOoD oLe ChEvYs.... |
07-24-2011, 06:00 PM | #8 |
Still plays with trucks
Gorgeous parts.
How much of a spacer are you going to need for the calipers to clear?
miSSed opportunity - ground up creation of an AWD 1994 454 SS that never was http://67-72chevytrucks.com/vboard/s...d.php?t=795577 69 C10 shortbed stepside 400 small block - built like what a super sport truck could have been 69 K20 lwb TBI 350 4L60E NP208 14-bolt Dana-44 w/disc 68 Camaro SS / RS 500hp 439 inch roller cam big block 4L80E 79 Malibu TPI 350 4L60 w/ Z28 steering & sway bars |
08-12-2011, 01:30 AM | #9 |
I managed to tear out the stock suspension including the stock steering column. I am waiting on tie rods and new custom brushed aluminum steering column shift with dash ignition and a ford 3/4 36 splined shaft with 3 bolt type steering wheel. For ignition I will run a push start no key Mega Dial Panel from Biondo on a custom dash gauge panel.
08-12-2011, 01:38 AM | #10 |
Baer tracker adjustable tie rods - on back order for past 2 weeks
brushed aluminum column shift dash ignition Biondo mega dial sample pic set up on a dragster |
08-12-2011, 10:59 AM | #11 | |
Are you going to get the Racepak gauge package too? Big bucks but very cool.
08-12-2011, 10:17 PM | #12 |
Yes I will use the Racepak gauge set up. I will incorporate the original radio as a kicker. After reviewing the sketch the left side lookd empty, might fill it in with a clock gauge, Choppd this one up just for U
08-13-2011, 12:27 AM | #13 |
that pic looks oddly familiar :-D
Joe 1957 Chevy 3100 Stepside |
08-13-2011, 12:52 AM | #14 |
08-13-2011, 11:06 AM | #15 |
Hehe, that's cool, nice to see dashes in different ways. :-)
08-13-2011, 04:16 PM | #16 | |
Maybe the switches can go on the left side below the clock to balance things out then it will leave more room for some nifty audio / video pieces like a monitor or nav system to go in above the stock stereo location.
08-26-2011, 01:08 AM | #17 |
I have to report that I was injured today while trying to install the springs on the hood hinges. Spring broke loose got air and hit me in the fore head above the eye. It took a minute to control the situation. I cleaned up went home early bummed. I realized it was deeper than I thougt so I went to the ER to stich up. I guess it's true when they say " blood sweat and tears" . I'll post sum pics later I'm on the iPhone waiting in the ER
Posted via Mobile Device |
08-29-2011, 12:17 PM | #18 | |
I had a spring compressor break while putting dome heavy rate springs into the front of my Chevelle. It shot the spring right past my ear and put a dent in the block wall ten feet behind me. It probably would have killed me if my head was 6" to the right.
08-26-2011, 02:34 AM | #19 |
damaged goods some stiching required
08-26-2011, 02:38 AM | #20 |
Holy jeez man... Looks like you tried to make yourself a 3rd eye!!
Joking aside... Hope your ok and it heals quick so you can get back on the pickup. Posted via Mobile Device
08-26-2011, 02:40 AM | #21 |
VA72C10
just glad it missed your eye!!! I always hate messing with hood springs.....really any springs
Looking for a 67-72 swb or blazer project in or around VA. |
08-26-2011, 02:42 AM | #22 |
I have had nothing but problems with the hood hinges its just a bad design, springs are to hard in some cases causing hoods to slighly bend. I odered some low tension springs from Jegs. If that doesnt work il $hit can the stock hinge and springs and go with these billet hinges, thing is there for a 72 some modding will be required.
08-26-2011, 10:15 AM | #23 | |
BTW - Love the brakes & wheels man - gonna look KILLER!!!
1977 Chevrolet K30 LWB Crew Cab 497HP Mast Motorsports 6.0L LY6 HO engine GM NV4500 5-speed, Centerforce clutch + NP205 D60 + 14-bolt FF w/ Eaton posi + disc brakes Skyjacker 2.5" full spring lift w/ Nitro shocks Custom paint + interior http://67-72chevytrucks.com/vboard/s...d.php?t=435722 |
08-26-2011, 03:04 PM | #24 | |
Sweet build thread i like youre mudd flinging machine youre building. Bout those hinges I already ordered a set of those billet machined finish for the 72, with some creativity il make them work, but it would be great if some one offered them for the 73-80's. No one in the market offers them not Billet Specialties not Fesler not EMS. With that said make sure they patent the design going to be worth some serious $$
08-26-2011, 05:13 PM | #25 | |
Still Learning
Alex, I tried to do some layout work with your Z-10 logo the other day....not having any luck with the geometry. Any chance you can make a photoshop .dxf file? Just so you know I didn't forget about you. Just haven't figured out how to get the geometry right yet. |
Tags |
73c10, c10, cheyenne, ls1, swap |
