Closed Thread
Old 07-28-2010, 12:39 AM   #551
RossRinSD
RossRinSD's Avatar
Re: What did you do to your truck today!
I didn't get much done... I ordered a pop up deck fill to keep working on that blazer tank install. I made a nice little posterboard template so I could make the mount for the filler, and dragged out some sheetmetal I found behind the shed... I was pleased it wasn't all rusty and nasty. Until I figured out why, its .125 Al. Guess I have a choice here. Pick up some sheet metal this week, or pick up a tig welder... The checkbook says sheet metal.
RossRinSD is offline
Old 07-28-2010, 07:04 PM   #552
hotrod100
hotrod100's Avatar
Not much today. Just blacked out the grille.
My build thread.
hotrod100 is offline
Old 07-29-2010, 12:17 AM   #553
07SSSC
07SSSC's Avatar
Started installing my alt and ps brackets off the '86 burb, need to get all thread to make the bracket work with the header. Need to get some decent looking bolts too, hopefully I can have it up and running tomorrow, I really wanna drive it!
'69 Chevy C/10-under reconstruction -- '68 C20 Camper 50th Anniversary-runs, but sorely needs a resto --
'07 Cobalt SS/SC-very fun DD -- '93 Chevy K2500-LQ4/4L80E swap --
'84 Trans Am-awaiting (LS) drivetrain -- '00 Trans Am-road tripper -- '06 Z06-577 WHP beast
07SSSC is offline
Old 07-29-2010, 04:22 AM   #554
dmartin1
dmartin1's Avatar
finished installing a new 355 sbc in the ole 79 k10.
received the new dashmat cover,hooked up the headers and exhaust system on the truck,flexfan and spacer,radiator,fan shroud,alternator and brackets,powersteering assembly,carbuerator,throttle,heater hoses,tranny lines,fuel pump.
and bought some goodies for it at the junkyard.......and to the lucky person above me with that longbed black chevy.......that is a BADA$$ truck!
1969 Shortbed in progress
1982 short step, few suspension and motor upgrades.getting a 468
1978 Shortbed fleet side bonanza fully loaded
1978 k20 Silverado loaded.currently engine-less
1989 k10 suburban 9" lift
65 nova
And more
dmartin1 is offline
Old 07-29-2010, 04:24 AM   #555
dmartin1
dmartin1's Avatar
your truck,to me,is abselutly bada$$.
very very cool! it grabs my eye
65 nova
And more
dmartin1 is offline
Old 07-29-2010, 12:08 PM   #556
hotrod100
hotrod100's Avatar
Thank you for the kind words.
My build thread.
Old 07-29-2010, 12:56 PM   #557
Lippyp
English Chevy Owner
Lippyp's Avatar
Grabbed half an hour and finished off removing the sticky gunk left behind on the side windows when I ripped the tints off, looks much better to me now and a hell of a lot easier to see out of. They seem to be slightly tinted glass anyway so Iguess thats how it left the factory. Hopefully this weekend I'll finally get the damn engine wiring harness apart so I casn fit the new one and refit the fusebox. The its getting close to fire up time.
We also got a shiney new digital SLR (Canon EOS 50D) today so some new pictures will be forthcoming sometime soon. It replaces my old canon film SLR as film and processing is getting way too expensive.
Phil
'67 C10 long fleet.
350/TH350, 4 bbl Carter, K&N, Dual exhaust, loads of stuff coming soon
2001 S10 Blazer Daily Driver, bone stock 4 door 4x4 with manual transmission
Lippyp is offline
Old 07-29-2010, 10:54 PM   #558
project 67 sub
project 67 sub's Avatar
still nothing its been parked in the street since sunday, but i did get my new to me tach for it on monday that i bought on the 17th. will probably be redoing my gage cluster again here real soon for the final time
project 67 sub is offline
Old 07-30-2010, 12:41 AM   #559
RossRinSD
RossRinSD's Avatar
This time is never the 'final time'...
Old 07-30-2010, 12:50 AM   #560
tantrumpipeline
Master Procrastinator
tantrumpipeline's Avatar
Spent my 10th wasted day/night aimlessly searching rural yards and junkyards trying to find a cab with only floor/cab corner/rocker issues but a good window frame and roof, why can't I live in Arizona?!
My Buildhttp://67-72chevytrucks.com/vboard/s...d.php?t=395506
20 Duramax tow pig
68 2wd short stepper project
77 2wd short fleet beater
52 short project
tantrumpipeline is offline
Old 07-30-2010, 03:20 AM   #561
dmartin1
dmartin1's Avatar
i got the engine running today,and get the hood and front tires back on and drove it,cleaned the bed and cab out,ready for all new rubber and seals i got to go on it.
tomorrow will be new windshield and steering column.
coinsidence or did you see my junkyard post? haha
65 nova
And more
dmartin1 is offline
Old 07-30-2010, 09:51 AM   #562
07SSSC
07SSSC's Avatar
Finally got my alt and ps pump installed last night, had to grind on the hole on the water for the ps bracket but finally got it all installed and lined up fairly well. Only took 3 weeks to get it all sorted out and installed. What a pain.
07SSSC is offline
Old 07-30-2010, 04:06 PM   #563
67chevy1series
67chevy1series's Avatar
i primered my floor from the seam up into the inner firewall behind the dash looks awsome
67chevy1series is offline
Old 07-30-2010, 04:55 PM   #564
Hottrucks
Redefining LowBudget
Hottrucks's Avatar
I timed the new 500 caddy in my truck plan to wash out the bay after I pulled the valve cover to listen better for a tick that I thought was a valve turned out to be the dips stick hitting the crank??
All I can say ic check my build for what I did last weeknd!!! and 5oo Caddies rock!!
1970 C10 CST fleetside 472 ....big dreams little cash...
SunShine Syndicate..
Mikes Sandwich Fair Run OCT 8th 2011
Hottrucks is offline
Old 07-30-2010, 06:22 PM   #565
tantrumpipeline
actually a coincidence, hahaha, but i did find a 67 grain truckwith a good cab and the salvage guy must figured it was made out of gold cause he wants way too much, story of my life
20 Duramax tow pig
52 short project
Old 07-30-2010, 09:44 PM   #566
willys72fleetside
willys72fleetside's Avatar
Trying to finish sanding the inside of my cab so that I can primer and paint. Then comes the question for a color choice.
A USED TRUCK IS A LOVED TRUCK!
willys72fleetside is offline
Old 07-30-2010, 10:14 PM   #567
project 67 sub
haha so true lol.
Old 07-30-2010, 10:22 PM   #568
GR8-68
GR8-68's Avatar
my new wheels came yesterday ordered the POR-15 today so should be making some progress soon
GR8-68 is offline
Old 07-31-2010, 04:08 AM   #569
OhioDan
OhioDan's Avatar
Talking Re: What did you do to your truck today!
Bought new oil and filter, took it on it's second road trip (7mi.) since finishing rebuild. Runs great.
LIFE AIN'T EASY WHEN YER FAT AND GREASY!
GMC= Got More Class!
1970 GMC LWB, Fleetside, 350/4spd, Flowmaster "40's", 2002 GMC 16" Rallies, cowl hood,and added a bunch of options that weren't there when I started.
OhioDan is offline
Old 07-31-2010, 07:22 AM   #570
prairewolf
if the storage shed owner is around I will get 67 out and see if the Stabil worked. I am also going to check dot manufacture yr date on tires. .... if they are too old they are going on a 68 Ford Custum 500 derby car.
life is interesting and good.
eat,work,spend,sleep,repeat.
prairewolf is offline
Old 07-31-2010, 03:03 PM   #571
redmonster
redmonster's Avatar
Finally put in the new window regulators. waiting on the window channel rubs to put on.. picks of the new hamster should be up tomorrow along with the window regs.
redmonster is offline
Old 07-31-2010, 05:00 PM   #572
Thealien
Thealien's Avatar
washed, waxed, drove!!!
Thealien is offline
Old 07-31-2010, 05:29 PM   #573
GMCjunkie
Dude...I'm a CHICK
GMCjunkie's Avatar
Changed the starter!! that and removed some of the grease and yuck from the underside of my truck and deposited it on ME!
"The unexamined life is not worth living" -Socrates
'71 GMC Suburban 4x4
GMCjunkie is offline
Old 07-31-2010, 06:42 PM   #574
vectorit
What?
vectorit's Avatar
Drove out for a morning cruise, and got a nice breakfast.
Afterward cleaned up the oil mess my T221 has been making, tomorrow I plan to R&R the tail shaft seal.
Chris
1968 K20 Suburban
1972 K10 LWB PU
vectorit is offline
Old 07-31-2010, 07:01 PM   #575
Jwill41
Jwill41's Avatar
installed alarm in the suburban.
http://www.picturetrail.com/jwill41
67 1/2 ton GMC short step side
68 1/2 ton Chevy long fleet side
72 1/2 ton Chevy Suburban
99 1/2 ton Chevy Suburban
founder (and only member) of the primer/clearcoat club
Jwill41 is offline
Closed Thread
