View Poll Results: If you had the option, which of these grills would you use?
Original 66 painted grill 1 20.00%
64-66 C60 painted grill 2 40.00%
an original aluminum grill that needs to be restored 2 40.00%
the repo aluminum grill that is now available 0 0%
Voters: 5. You may not vote on this poll
Old 11-15-2014, 05:07 AM   #551
pdxhall
pdxhall's Avatar
Re: pdx-sanity66
Originally Posted by duallyjams View Post
Every trip that the we go on my lovely bride has the same comment sooooooo there just happen to be a car show the same time that we are here
That's one thing that's on the bucket list. Get in some shows in different parts of the country along with many other things. Believe me, we've got plenty to keep us busy for a while.
Originally Posted by Modges'66 View Post
Wow!
The column support & the tank mounting look great!
Also, it is pretty great that you are so close to retirement...Unless something major changes, I won't even be able to think about it for another 20 years or so! Congrats!
Thanks. I really appreciate that because I'm a real fan of your work.
As far as the retirement. Hang in there, it goes faster than you would think. Enjoy your youth.
Originally Posted by 66Z71 View Post
Love the exhaust idea.
Thanks. I hope it works out the way I want it to.
Sanity'66
http://67-72chevytrucks.com/vboard/s...d.php?t=515110
Long bed, Fleetside, Small back window
I've Done So Much, With So Little, For So Long, That Now I Can Do Anything With Nothing.
pdxhall is offline   Reply With Quote
Old 11-15-2014, 05:53 PM   #552
Modges'66
Modges'66's Avatar
Location: Grand Rapids, Michigan, otherwise known as Beer City U.S.A.
Re: pdx-sanity66
Ha-Ha!
Funny, but I am not as young as you probably think that I am!
I have a 25 year old son who just took a job as a graphic designer in Portland a few months ago...50 is 50, no matter how you stack it!
Modges'66 is offline   Reply With Quote
Old 11-17-2014, 12:28 AM   #553
TJ's Chevy
Post Whore
TJ's Chevy's Avatar
Re: pdx-sanity66
Progress!
1966 Chevy C10 "Project Two Tone" http://67-72chevytrucks.com/vboard/s...d.php?t=596643
1964 GMC "Crustine" semi-build:http://67-72chevytrucks.com/vboard/s...d.php?t=665056
My youtube channel. Username "Military Chevy": https://www.youtube.com/channel/UC_h...fzpcUXyK_5-uiw
TJ's Chevy is offline   Reply With Quote
Old 11-17-2014, 03:13 AM   #554
pdxhall
pdxhall's Avatar
Re: pdx-sanity66
Ha-Ha!
AAHH, to be 50 again! Actually I would have guessed in the 40s. I've still got some years on you but you're catching up.
Originally Posted by TJ's Chevy View Post
Progress!
Yeah, things have been moving along pretty well but this cold weather is slowing me down a bit. I had to crank up the heaters in the garage this last weekend so I could get some painting done.
As soon as I get the paint for the tank and get it sprayed, it will be ready for final install in the frame, install the sender, and make up the fuel line from the filter to the tank. I repainted the rear frame rails where the tank sits and painted the brackets. I also got the bracket for the steering column painted and a few coats of primer on the emergency brake handle.
I also started fabbing up the steering intermediate shaft and started disassembly of the column to install new bearings and clean things up a bit.
Sanity'66
Old 12-09-2014, 10:07 AM   #555
pdxhall
pdxhall's Avatar
Re: pdx-sanity66
Well, I managed to screw around and found my thread on page 4 which means
I've been working on Sanity when I can but I haven't updated in awhile.
Here's a few pics just to show I haven't been a total slacker
I've been waiting to get my fuel tank painted so in the meantime I have been smoothing up the kick panels a little bit before starting on seam sealing. They're almost there. I also got the hole cut for my floor shifter.
I've also been working on rebuilding my tilt column. I am changing the upper and lower bearings and I tightened the lower column bolts with some Loctite.
I was glad I tore it down even though it felt fine and was tight because the bearings were worn and the bolts were starting to loosen. Everything is cleaned up, greased where needed, and in the process of reassembly and then paint. I've also got new tilt and turn signal levers and a new flasher switch to go on.
And last but not least, Santa sent an early Christmas present.
Sanity'66
Old 12-09-2014, 11:15 AM   #556
Twisted78SS
Wide n'Low
Twisted78SS's Avatar
Re: pdx-sanity66
Nice!
got a column i want to tackle one of these days, sounds like it needs about the same treatment.. thanks for the reminder.
Trippin Hazard.. 67 swb,
Gold Member.. 68 Suburban
Air Force Retired
Twisted78SS is offline   Reply With Quote
Old 12-10-2014, 12:26 AM   #557
Oregon 1967 GMC
Oregon 1967 GMC's Avatar
Re: pdx-sanity66
ok, I'm all caught up and a couple questions: I take it you got your motor from Summit? And the tranny from? Just curious because I'm going to switch out my 6 Cylinder and might need more than my turbo 350. I'm sure you checked around and I value your judgment and like your vision. I plan on driving down to San Diego in a couple of weeks to spend Christmas with Mom and Bro's and might stop by CPP and pickup a truck load of disc brakes, spindles, and suspension stuff. Keep up the fire!
Hey man
67 GMC Short Stepside 400 small block, turbo 350. Build thread:http://67-72chevytrucks.com/vboard/s...d.php?t=650603
Oregon 1967 GMC is offline   Reply With Quote
Old 12-10-2014, 09:36 PM   #558
pdxhall
pdxhall's Avatar
Re: pdx-sanity66
Originally Posted by Twisted78SS View Post
Nice!
Thanks, man. It's really kind of a fun job and not very tough. I found a pdf file online that is fantastic resource if you haven't done them before. I think it's from the Jalopy Journal. The guy was doing a Fiero ( I think ) column and it was a little newer the one I'm doing but those GM tilts are almost the same inside for many years. It's got great pictures and instructions.
Yes, the motor came from Summit. They had the best deal and I shopped around a lot before pulling the plug. I got my transmission rebuilt at Transmission Exchange here in Portland. They've been around forever and they were very helpful in helping set up a good heavy duty unit. They are located right on the east side of the river just a couple of blocks north of the Broadway bridge on MLK Blvd. Good luck on the shopping trip and enjoy the Holidays.
Sanity'66
Old 12-10-2014, 10:34 PM   #559
TJ's Chevy
Post Whore
TJ's Chevy's Avatar
Re: pdx-sanity66
Looks good man! Congrats on the present.
Old 12-12-2014, 12:20 AM   #560
Oregon 1967 GMC
Re: pdx-sanity66
awesome, thanks "B"
Hey man
Old 12-20-2014, 09:42 PM   #561
pdxhall
pdxhall's Avatar
Re: pdx-sanity66
I've only got 2 weeks to go and I'm officially RETIRED.
I hope to get some serious work done on Sanity for at least a month or so before we start our traveling adventure.
I got a little done on her this weekend. I finished the assembly of the steering column to the point of getting it painted before the final couple of things such as the levers and then finally the adapter and wheel. I got the epoxy sprayed on it today.
I also got the aluminum paint on my gas tank and will shoot some epoxy matte clear on it next.
Sanity'66
Old 12-21-2014, 09:05 PM   #562
Turtleman
Turtleman's Avatar
Re: pdx-sanity66
Sorry to hear about the Retirement... LOL
Without exception,, everyone I know who goes into retirement never has any time to get anything on their list done... Most want to go back to work to get some time off.. LOL
Congratulations
Turtleman is offline   Reply With Quote
Old 12-24-2014, 03:43 AM   #563
pdxhall
pdxhall's Avatar
Re: pdx-sanity66
Congratulations
Thanks. It's going to be a tough job but I'm going to give it a go. We've got plans to keep us going for quite awhile.
Sanity'66
Old 12-29-2014, 03:07 PM   #564
McMurphy
McMurphy's Avatar
Re: pdx-sanity66
Good to see some progress buddy !!
Those kick panels look way better than mine, so I covered mine with carpet, some.
To me so far Retirement means every day is Saturday.
I have not set an alarm clock yet.
From now on I am going to be the total beneficiary of my efforts, not a slave to them for a pay check.
Every morning I get up and decide between what needs to be done today, and what can I do/get done today....
I dont fuss at traffic any more, the a**holes can have the right of way; I dont care because I dont have to be anywhere at any time.
This may be different for you, but anyone who has worked an On Call job will understand perfectly: I dont carry my phone with me at all times any more. I dont sleep with it, and I have actually set it aside - forgotten for days on end and never missed it.
I do miss the morning routine, and I may dig out my alarm clock for that. I have not been able to establish any sort of morning schedule that is as effective as it used to be.
Congrats and good luck with it, I think it is fun so far.
Hope your Holidays are rocking it man
Michael McMurphy
My 66 Stepside
My 64 Tow Truck
My 66 Tempest
Table Of Contents Added to Page1
McMurphy is offline   Reply With Quote
Old 12-29-2014, 10:46 PM   #565
pdxhall
pdxhall's Avatar
Re: pdx-sanity66
Thanks, Mike. I have been thinking about this all this week. No more commuting, no more alarms unless it's to do something for me, and (since I have been working a graveyard shift) no more day sleeping unless it's to just take a nap. My biggest goal is to convert to become an early riser and take advantage of every day.
Sanity'66
Old 12-31-2014, 04:40 PM   #566
rusty76
rusty76's Avatar
Re: pdx-sanity66
Congrats on retirement. I looked forward to that day for sure. I like the idea of not having to be somewhere.. I work seven days a week. I ready now....lol. Good thing my job on the weekends is easy. Congrats again.!
http://67-72chevytrucks.com/vboard/s...d.php?t=581873
The low buck build threads. Check'em out!
http://67-72chevytrucks.com/vboard/s...d.php?t=666022
My build thread
Crossmembers CC
rusty76 is offline   Reply With Quote
Old 12-31-2014, 04:50 PM   #567
markeb01
Senior Enthusiast
markeb01's Avatar
Re: pdx-sanity66
I've stuck with the same daily goals as when I was working - Learn something new, make a difference, do something that makes you happy. I'm done ruining my health for a paycheck. I only wish I could have retired twenty years earlier!
Congrats and good luck!!
My Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=444502
Old 01-01-2015, 05:31 PM   #568
pdxhall
pdxhall's Avatar
Re: pdx-sanity66
Thanks Rusty.
[quote=markeb01;6979307]I've stuck with the same daily goals as when I was working - Learn something new, make a difference, do something that makes you happy. I'm done ruining my health for a paycheck. I only wish I could have retired twenty years earlier!
I wish I could have done it earlier also. We've got plenty of things planned for the future, though, so I'm really looking forward to it. The health thing was certainly a big factor in our decision. We want to get out and do some things we've always wanted before we're too old to.
Sanity'66
Old 01-27-2015, 09:44 PM   #569
pdxhall
pdxhall's Avatar
Re: pdx-sanity66
I've been retired for a couple of weeks now and busy trying to get the house ready to sell, packing things into storage, and hauling stuff to donate, recycle, etc. I've also been trying to sneak some truck time in at the same time.
The house went on the market Thursday and sold on Friday. I've got till the end of Feb. to get the truck ready to store and finish moving everything else.
Truck progress:
I got the gas tank mounted for the last time, just need to install the sender and hook up the fuel line and sender wire.
I got the interior floor and firewall seam sealed with SEM 2 part heavy bodied sealer and then put one more coat of epoxy on the kick panels, front floor, and firewall. Next is the Lizard Skin and paint.
I got the distributor, plugs, wires, and carburetor on the engine. I still need to complete the plumbing, throttle, etc.
and I started bead blasting the kick panel vents. One more door to go and then epoxy and paint. The rubber seals are in such good shape I didn't want to mess them up in the blaster so I tried electrical tape to tape them off as I figured it would be a little tougher than trying masking tape. It worked perfect so I've got one more to do.
I'll post some pictures of the work later, the manage attachments link is not working for me right now.
Sanity'66
Old 01-27-2015, 09:50 PM   #570
duallyjams
duallyjams's Avatar
Re: pdx-sanity66
Sold the house in less then 24hrs what the sign say free.
James
63 GMC V6 4speed carryall
65 chevy swb bbw V8 auto
68 K20 327/4 speed, buddy buckets
2002 GMC CC Dually Duramax
64 GMC lwb 3/4 V6 4speed SOLD
66 GMC swb bbw buddy buckets SOLD
IG duallyjams
The only thing that stays the same is constant change!
duallyjams is offline   Reply With Quote
Old 01-27-2015, 09:52 PM   #571
pdxhall
pdxhall's Avatar
Re: pdx-sanity66
It was price competitively with the area but I also wonder now if we should have asked more, but we came out very well on the deal.
Sanity'66
Old 01-27-2015, 10:02 PM   #572
Bomp
Bomp's Avatar
Re: pdx-sanity66
Congrats on selling the house.
Hope to see you at some truck events in between all the gallivanting the country side you'll be doing.
Bomp is offline   Reply With Quote
Old 01-27-2015, 10:06 PM   #573
TJ's Chevy
Post Whore
TJ's Chevy's Avatar
Re: pdx-sanity66
Congrats on selling the house. Truck is looking good as well.
Old 01-28-2015, 04:49 AM   #574
pdxhall
pdxhall's Avatar
Re: pdx-sanity66
Thanks, man. I definitely plan on checking out some shows here and there in our travels and maybe meet up with some members along the way. Even though Sanity will be put on hold (in more ways than the truck, I suppose ) I plan on keeping up on the site. I was hoping to make it to the swap meet this year but I might be gone by then. We'll see.
Thanks, TJ.
Here are the recent pics of Sanity from the previous post.
Sanity'66
Old 01-28-2015, 04:51 AM   #575
pdxhall
pdxhall's Avatar
Re: pdx-sanity66
Here's a couple more.
Sanity'66
