Old 03-30-2014, 08:35 PM   #551
JRANGER
JRANGER's Avatar
Re: 1967 Mustang Coupe Build (Electra)
Figured out my choke isnt working right....It stays barely open. Never disengages..and runs my idle high .I think the electronic choke might be broke. I manually opened it up and the car died lol. Turned up the idle screw and it was fine. BLAH!!!!!!!! Damn you choke It was a great day for a short drive though
JRANGER is offline   Reply With Quote
Old 03-30-2014, 09:47 PM   #552
Rusbuilt
Rusbuilt's Avatar
Console is looking good bro!
Rusbuilt is offline   Reply With Quote
Old 03-30-2014, 11:35 PM   #553
JRANGER
JRANGER's Avatar
Thanks man
Old 04-01-2014, 12:59 AM   #554
67ChevyRedneck
67ChevyRedneck's Avatar
I hope all my VMF thread's will return when they're done screwing with the site?
Make sure the ground is good. You're supposed to be able to snap the throttle a time or two to disengage it.
Jesse James
1967 C10 SWB Stepside: 350/700R4/3.73
1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc
1968 Pontiac Firebird: Project Fire Chicken!
2015 Silverado Double Cab 5.3L Z71
2001 Jeep Wrangler Sport 4.0L 5spd
2020 Chevrolet Equinox Premium 2.0L Turbo
2011 Mustang V6 ~ Wife's ride
American Born, Country by the Grace of God
1967 CST Shop Truck Rebuild!
My 1967 C-10 Build Thread
My Vintage Air A/C Install
Project "On a Dime"
Trying my hand at Home Renovation!
1965 Mustang Modifications!
67ChevyRedneck is offline   Reply With Quote
Old 04-01-2014, 03:03 AM   #555
Kerry P
I hope we don’t have to wait for every registered member to swear that they hate Vipers.
Kerry P is offline   Reply With Quote
Old 04-01-2014, 08:32 AM   #556
67ChevyRedneck
I'm shocked people have already made 7 pages worth of threads. There was only about 8 threads last night.
I'm actually surprised they did "Viper". I would have done Camaro to really piss people off. I mean, if you're going to do it, do it right!
Jesse James
Project "On a Dime"
Old 04-01-2014, 09:00 AM   #557
JRANGER
JRANGER's Avatar
lol, yeah i dunno its an April fools joke but im having withdraws. But i posted a crap ton of MEMEs in every thread i could last night
Ill double check that....I didnt look at it real hard as I was their for soccer. Thanks
Old 04-08-2014, 10:39 PM   #558
JRANGER
JRANGER's Avatar
Ok and back to work.
Rebuilt my short shifter as welding a bolt didnt work. This time, I grinded it down, hit it with heat, and used a 4 way lug wrench and a lug nut to make threads.
Then i got to work on the console front. Sanded the sides and added bondo. Then sanded some more.
I then test fit it and marked where i wanted to cut excess off the sides. I also drilled some holes to connect to the miata console. Still trying to decide what i want to do on the front of it.
Old 04-09-2014, 10:33 PM   #559
Dieselwrencher
6>8 Plugless........
Dieselwrencher's Avatar
Nice work!
Ryan
1972 Chevy Longhorn K30 Cheyenne Super, 359 Inline 6 cylinder, Auto Trans, Tilt, Diesel Tach/Vach, Buckets, Rare Rear 4-link and air ride option Build Thread
1972 GMC Sierra Grande Longhorn 4x4
1972 Chevy Cheyenne Super K20 Long Step side tilt, tach, tow hooks, AC, 350 4 speed
1972 C10 Suburban Custom Deluxe
1969 Chevy milk truck
1971 Camaro RS 5.3 BTR STG3 Cam Super T10
1940 Ford 354 Hemi 46RH Ford 9" on air ride huge project
Tired of spark plugs? Check this out.
Dieselwrencher is offline   Reply With Quote
Old 04-10-2014, 10:32 AM   #560
JRANGER
JRANGER's Avatar
Originally Posted by Dieselwrencher View Post
Nice work!
Thanks! Slowly but surely it will come together. I just need to stop being lazy and get the fenders off and start working on the cowl
Old 04-19-2014, 01:48 PM   #561
JRANGER
JRANGER's Avatar
Drove the stang to boxing this morning and it was idling high as always. Got home and choke was still closed. So like 67chevyredneck said i checked the ground. It was ground to the valve cover and looked gunked up. So I cut it off and attached it back to the screw on the carb where I always seen them attached. So far its idling how it should and the choke is open. So ill check it again when its cold.
Old 04-19-2014, 05:06 PM   #562
67ChevyRedneck
Feels good to drive it, don't it? I put over 200 miles on mine yesterday.
Jesse James
Project "On a Dime"
Old 04-20-2014, 11:21 AM   #563
JRANGER
JRANGER's Avatar
On another episode of "WTF THE PO DID" I discover that the choke isnt working because it is not hooked up to a 12v supply. The PO ran the wire over to the solenoid. While running it didnt even come close to 12v. Last time I checked the choke plate needs a 12v supply when turned on and when off it shouldnt have any. BLAH! Ill fix that soon....That explains a little of why it doesnt work...Hopefully
Old 04-20-2014, 11:26 AM   #564
Rusbuilt
Rusbuilt's Avatar
Bummer! At least that one will be an easy fix!
Old 04-26-2014, 05:28 PM   #565
JRANGER
JRANGER's Avatar
OMFG I hate whoever ****ed this car up so bad!! The sorry sumbia mutha of all that is wrong in this world. Today i decided to take the fenders off. I need to start looking at the suspension, replacing the springs at the least. Well the drivers side fender came off fairly easy and then i got my drivers door lined up better. All was going good. Then.....i find the front top fender bolt has just a nut on it. Then i find the front section that holds the valance from fender to fender has a self tapping bolt in it and the top was shaved almost smooth and then and FU**in then i find what i thought was just some bondo in the gap on the bottom near the rocker panel is a freaking WELD! Not only did it make me mad but i ended up messing up the door paint while cutting it out... I hate the PO or PO to the PO or who ever da **** did this
UGH!!!
So on another note the side is dented in a bit on the drivers side right below to cowl but not too bad. Surprisingly everything is solid looking other then the passenger side about 8" of frame rail right below the battery and well battery tray area. Its prepped and now i need to get some cutting blades so i can shop the side of the cowl off and try a patch
I did drive it this morning before disassembly
Old 04-26-2014, 11:25 PM   #566
67ChevyRedneck
they earned the name "rustang" for a reason.
Jesse James
Project "On a Dime"
Old 04-26-2014, 11:26 PM   #567
JRANGER
JRANGER's Avatar
Our chevy's arent any better but yeah lol
Old 04-27-2014, 04:26 PM   #568
cubber
Nothin' like some PO BS!
=MATTHEW
69 Stepper...Stroked & Bagged GONE BUT NOT FORGOTTEN
2003 Chevrolet Z71 Ext. Cab
1995 Cavalier gas saver!
cubber is offline   Reply With Quote
Old 04-27-2014, 06:12 PM   #569
flashed
From what I have seen you do with this project from the beginning you will have it fixed right in no time .
flashed is offline   Reply With Quote
Old 05-05-2014, 11:20 AM   #570
JRANGER
JRANGER's Avatar
Installed a new choke cap and it seems to be working a lot better but its kinda weird. It opens up but not much until i turn it off and then back on. I may adjust it counter clockwise some more and try that but im only 2 notches from center. Ill get it figured out also ordered a accelerator return bracket for the spring and adjust the rod a little more. Once its open it idles pretty good
Old 05-25-2014, 05:20 PM   #571
JRANGER
JRANGER's Avatar
And now i am a bit pissed...Cut the side of the cowl today and was working and i got the new cowl fitted in...But there is no effing way i can weld the inside edge of get it fit snug....Its just far back and there is not enough room. I would have to replace the whole cowl....So now i just dunno what to do....
I could weld it back together with part of the cowl welded in so it doesnt rattle and then just weld **** the sides so nothing can leak in through the fender gaps but i just dont know. I dont have the skill to do the cowl and it is way more then i can afford to have done. My understanding is its $2k easy to have done...
So i dunno...Im a bit pissy....If i weld the sides it would at least be leak free with a cowl cover
Old 05-25-2014, 07:19 PM   #572
flashed
Is there any way you could use some bonding cement that is used in shops on newer cars ?
Old 05-25-2014, 08:15 PM   #573
JRANGER
JRANGER's Avatar
Its possible but the problem is i cant hold the inside together. Nothing to clamp it down and so on...I did managed to cut it up some more and get it in better. Its in and welded but its just spot welds along the sides and on the back corners mostly. I was able to get a few on the back but not directly behind the cowl hood. It was tricky as hell to do but i still have to get all the seams sealed some how...Not sure how i am going to get that done behind it other then maybe sloshing a can around the circled or maybe using a baster to shoot it in there...
Old 05-25-2014, 08:33 PM   #574
JRANGER
JRANGER's Avatar
and the pics
Old 05-25-2014, 08:45 PM   #575
Rusbuilt
Rusbuilt's Avatar
Thats looks tough bro! I wish I was there to help you bro!
