Old 12-01-2016, 01:32 PM   #551
jdb_us1
Re: 1991 V3500 Project Heavy Hauler
Took a few days to read through the entire thread, very nice work, that thing should be rock solid by the time you are all said and done. Any idea on total costs to this point?My CC build is based on the premise that I would rather spend $20k over the life of the project than to shell it out all at once on a newer truck. By the time all is said and done you are left with a reliable, good looking truck that you know the intimate workings of. Awesome job.
jdb_us1 is offline   Reply With Quote
Old 12-01-2016, 02:53 PM   #552
MTCK
MTCK's Avatar
Thanks I appreciate the compliments. Same premise here. New truck is 50k. My dad got his '13 in '15 with about 15k miles on it for 30k, which is a good deal, but I can't work on it and not exactly what I want. Oh and it gets 10-12 mpg too.
I have 15-20 in it now. 5-7 of that was rebuilding and installing the new motor. I replaced a lot of parts that I didn't necessarily "need" but wanted like new reliability. AC was a couple grand, stereo, tires, springs, all the interior work. It adds up quickly. Initial purchase of the truck was the cheapest part at $3500 and that was with a solid trans transfer case running gear and completely rust free body.
Before it is "done" I need to address the paint and suspension. Working on putting that budget together now for CFO approval. Best advise I can give is make a realistic budget and timeline, add 20% to each and plug away. Good luck with your project.
-Marcus
1991 V3500 L29 454 4L80E NP205 D60/14 Bolt 4.56's
1984 K30 292 TH400 NP205 D60/14 Bolt 4.56's flat bed 7'6" Meyer Plow
2022 Silverado 3500 L8T
Project Daily Driver
Project Plow Truck
MTCK is offline   Reply With Quote
Old 12-03-2016, 12:01 PM   #553
ryanroo
ryanroo's Avatar
I always tell people to double the amount they plan to spend and triple the time. 20% seems so optimistic!
72 K20 12v build
72 K20 "parts truck"
ryanroo is offline   Reply With Quote
Old 12-03-2016, 01:34 PM   #554
MTCK
MTCK's Avatar
Hahaha that's a lot safer bet! I guess it depends on the level of detail you start with. I usually try to make a parts and fluids list down to the hardware before I embankment on something major. If I was working off my favorite bar napkin, double the money would be low!
-Marcus
Project Plow Truck
Old 12-03-2016, 02:38 PM   #555
'63GENIII
'63GENIII's Avatar
So true on both accounts. I do my worst planning when a bar napkin is involved.
I like the "CFO Approval". LOL, I have to cook the books once in a while and she always catches me. Mine is like the IRS!
Chris
'63 k15 long step
Vortec 7.4 - L29 Blackbear tune, Five 0 Motorsports injectors, Chris Straub Cam, NV4500, divorced 205
52" front and 63" rear spring swap
D44 / 14bff - disc axles
Milemarker 9K and 10.5K hydraulic winches
63" & B52 Spring Install http://67-72chevytrucks.com/vboard/s...ng+swap+thread
NV4500 Reverse Build Thread http://67-72chevytrucks.com/vboard/s...=reverse+build
L29 - 7.4 Vortec Build http://67-72chevytrucks.com/vboard/s...&highlight=L29
'63GENIII is offline   Reply With Quote
Old 12-03-2016, 03:17 PM   #556
MTCK
MTCK's Avatar
This is never going to make it through audit! Hahahaha
-Marcus
Project Plow Truck
Old 12-10-2016, 11:23 PM   #557
MTCK
MTCK's Avatar
Grinding out the winterization install this weekend. Radiator is back for another leak repair, 195 thermostat is back in, both trickle chargers installed, circulating heater installed and all the 110v power run. Trains and oil pan heaters were installed previously and are now wired. Hope I don't trip the breaker... Oil pressure sending unit is leaking again so I need to tackle that and maybe clean up the wiring for the driving light and install my dog and backup lights. We will see how motivated I am and how much of a pass I can get.
-Marcus
Project Plow Truck
Old 12-10-2016, 11:53 PM   #558
'63GENIII
'63GENIII's Avatar
Sounds like you're busy Marcus! Forgive my ignorance but what's a circulating heater! Is it something to do with the block heater?
I thought my "winterization" was bad... Trying to find and seal a couple of water leaks in the cab. Man, I got it easy compared.
Gotta say, your truck build is one of my favorites.
Chris
'63 k15 long step
Old 12-11-2016, 02:59 AM   #559
MTCK
MTCK's Avatar
Appreciate it! Yours is one of my favorites. You and Larry and Steve with your proper trucks with a pedal left of the brake...
Circulating heater is instead of a block heater. I had two different crappy Chinese block heaters puke out the side of the block this summer so I put a freeze plug in and bought this heater. Bung screws into the bottom drain on the side of the block, then the circulating heater, and it feeds into a "y" in the lower heater hose. 1500 watts vs a block heater that is normally 600-800 and the heater blows hot right when you crank it up.
I'm hoping santa brings me a remote start. If that happens buy oil futures. My Tacoma gets down to 10 mpg in the winter if I hit the button a lot. I can only imagine how bad this could get!
-Marcus
Project Plow Truck
Old 12-23-2016, 03:48 AM   #560
MTCK
MTCK's Avatar
Defrost saga update: 195 degree thermostat helps a lot. It is much more pleasant to drive at sub zero temps. I checked the compressor earlier this winter and it WAS cycling but that was when I pulled it out of the garage and everything was warm. Checked it today after I had been driving a while and it was not cycling. I'm scheduled to get my custom cold front installed next week which will bring the under hood temperatures up considerable. I'm also going to check my refrigerant pressure when it's cold to see if that could be keeping the pressure switch from letting the compressor cycle?
-Marcus
Project Plow Truck
Old 12-23-2016, 04:00 AM   #561
'63GENIII
'63GENIII's Avatar
The cold fronts helped me a lot when Id go back to CO through WYO. Ive seen guys make em out of cardboard, plastic ect. Mine was vinyl, snaps around the outside that secured it to the outside edge of the grill and a zipper in the middle that allowed a small triangle of the grill to be exposed. It covered 75% of the grill and allowed the engine to get up to operating temps quicker and maintain them. This was on a diesel. Without it, since it had the huge radiator the truck would never warm up.
Although the temps we had were only +6 F, the cold fronts really helped during those trips. Changing to the higher t stat was a seasonal occurrence.
Im sure we will see pics of the CF. BTW, how is the circ pump working out?
Chris
'63 k15 long step
Old 12-23-2016, 04:41 AM   #562
MTCK
MTCK's Avatar
What you describe is exactly what I'm having made. Pretty low tech but it makes a huge difference. Pic is of the cold front I had made for my '77 daily driver. I think it was $80 about six years ago and now they are $125.
Circulating heater works great. Heater doesn't blow hot right out of the gate but it doesn't take long. 1500 watts is a lot but so is 7 or 9 gallons of coolant (I can't recall the capacity off the top of my head). Fires up like its +50 out.
If I can just get this defrost working and maybe an auto start it'll be a viable winter driver. I need it to be because it is my kid hauler on days when I'm moving the bambino around.
-Marcus
Project Plow Truck
Old 12-23-2016, 04:41 AM   #563
MTCK
MTCK's Avatar
Whoops here's the picture.
-Marcus
Project Plow Truck
Old 12-23-2016, 07:41 AM   #564
watahyahknow
watahyahknow's Avatar
we usually stick a piece of cartboard between the grille and radiator , youre solution looks nicer though
i got a job again and having fun at it too
idea's for the trucks and the order of things to do are taking shape and get closer to being realized , a few more months and i be able to start building for real
i complete 2 of the trucks intoo running fashion one custom and one basicly stock the thirth will be sacrificed for parts
watahyahknow is offline   Reply With Quote
Old 12-23-2016, 08:35 PM   #565
deejaaa1
your truck is looking great. your attention to detail is amazing.
Black 93 CCLB 3500 6.5 diesel, GV OD, TCI Ez-TCU controlled 4L80E, back on road 10/25/16 after sitting 4 years.
96 ECLB 2500, 6.5 diesel, auto, gone.
Originally Posted by gottattooz View Post
...68 Chevy Shortbed... guy clearcoated..and...threw glitter all over it...like he was feeding chickens!!!...
deejaaa1 is offline   Reply With Quote
Old 12-28-2016, 06:59 PM   #566
MTCK
MTCK's Avatar
Appreciate it! Cold front is on. Will see how much this helps.
-Marcus
Project Plow Truck
Old 12-29-2016, 08:22 PM   #567
MTCK
MTCK's Avatar
Little perspective on where all the water off your boots goes. Down to the gap in the weather strip. Makes sense this is where the rust starts.
-Marcus
Project Plow Truck
Old 12-29-2016, 09:46 PM   #568
watahyahknow
maibe make a small dent in the floor with a drain hole in the deepest part of the bottom
that should at least concentrate the moisture at one point of the floor
could allso silicone the edge of the rubber mat so the water doesnt reach the metal at all
Old 12-29-2016, 09:55 PM   #569
'63GENIII
'63GENIII's Avatar
Just knowing that would give me anxiety given that your truck is virtually rust free. I hate rust.
Ive been using the floor mats that have the 1/2" deep / raised channels that hold water. They grab a lot of water and mud / dirt too. I think that there is a company that makes custom ones that fit a lot of the newer suvs and trucks. They don't make one for mine but may make them for the square bodies?
Chris
'63 k15 long step
Old 03-13-2017, 10:41 PM   #570
MTCK
MTCK's Avatar
I think the drains are actually working exactly how they are supposed to... at any rate I POR15'd the crap out of the whole region and too coated it. I got the vinyl floor covering because I didn't want matts. Hopefully I'm not regretting this approach later.
In other news, TC lockup clutch is slipping under heavy load in OD and I think it is time for a transmission rebuild. Oh and I have parts to install. Can anyone name what is missing?
-Marcus
Project Plow Truck
Old 03-13-2017, 10:46 PM   #571
DirtyLarry
Windy Corner of a Dirty Street
DirtyLarry's Avatar
Since you're doing shocks your missing this....
Two steering box braces? One for my favorite 292 truck too?
DirtyLarry is offline   Reply With Quote
Old 03-13-2017, 10:55 PM   #572
MTCK
MTCK's Avatar
I didn't think the braces worked on one ton trucks?!? Good eye, yes the plow truck is getting a brace. That sucker gets loaded up when I stuff it in a ditch with the plow up... still something big you're missing.
Also, when did ORD stop painting their fabricated parts? Last steering brace and shackle flip I got had a nice hammered finish.
-Marcus
Project Plow Truck
Old 03-13-2017, 11:11 PM   #573
joe231
joe231's Avatar
I don't see a 2wd steering box and crossover steering.
Oh and no FUSH, no rear shackles, and no front lift springs, and...
CHEVY ONLY
Old 03-13-2017, 11:13 PM   #574
Dieselwrencher
6>8 Plugless........
Dieselwrencher's Avatar
New leaf springs?
I'm pretty sure they charge for the powder coating now. That's the impression I got the other night as I was shopping for some parts. Kind of a kick in the wallet IMO.
Ryan
1972 Chevy Longhorn K30 Cheyenne Super, 359 Inline 6 cylinder, Auto Trans, Tilt, Diesel Tach/Vach, Buckets, Rare Rear 4-link and air ride option Build Thread
1972 GMC Sierra Grande Longhorn 4x4
1972 Chevy Cheyenne Super K20 Long Step side tilt, tach, tow hooks, AC, 350 4 speed
1972 C10 Suburban Custom Deluxe
1969 Chevy milk truck
1971 Camaro RS 5.3 BTR STG3 Cam Super T10
1940 Ford 354 Hemi 46RH Ford 9" on air ride huge project
Tired of spark plugs? Check this out.
Dieselwrencher is offline   Reply With Quote
Old 03-13-2017, 11:35 PM   #575
MTCK
MTCK's Avatar
Yeah it can really snowball in a hurry... no crossover steering (not getting bent with this truck to the point of not being able to turn left). Leaf springs for the front are it. They are a few weeks behind the rest of this stuff.
That is kind of a bummer that they don't cost anymore. Rattle can time I guess.
-Marcus
Project Plow Truck
