08-28-2016, 12:20 PM | #551 |
Re: Bride of Young Frankenstein - 1957 Buick Super
Got it, thanks!
build threads: 86 Suburban 88 Jeep 6.0 swap 49 Chevy truck 54 Chevy wagon 86 Suburban lowered 4/6 54 Chevy wagon 49 Chevy/s10 mix 88 Jeep Wrangler rockcrawler |
08-28-2016, 05:13 PM | #552 |
Chevy Enthusiast
Wow looks awesome! That eastwood internal frame coating stuff looks pretty cool.
Tony 1985 GMC K2500 restoration Project: Rust, White & Blue 1989 Chevy R3500 CC Cummins & 4X4 swap some day... 1989 Burb (D60, 14BFF, 12V, NV4500, NP205, 37" tires in progress) |
09-23-2016, 10:57 PM | #553 |
Lucky Teter at the wheel
I disassembled the Jaguar IRS partially to wire wheel it, sand, and paint chassis black. Now I'm just watching paint dry. I've ordered new Bilstein Shocks all around, new rotors, brake hoses, calipers, and pads. I'll still need to run new braake hard lines on the frame - later. Planning on attacking the IFS in the morning.
Drew YOUNG FRANKENSTEIN (Finished with MAJOR Surgery - IT'S ALIVE!!!) The Bride is currently under the knife!
09-23-2016, 11:01 PM | #554 |
Looking great ,glad to see more progress ,staying tuned .
09-24-2016, 12:15 AM | #555 |
I forgot to add that I had blasted most of these parts in the blast cabinet first! Love that machine!!!
09-24-2016, 09:17 AM | #556 |
Parts always look so much better with fresh coats of paint...Jim
my build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=459839 Jimbo's long bed step build:http://67-72chevytrucks.com/vboard/s...t=464626<br /> |
09-24-2016, 04:37 PM | #557 |
Just a little mid-Saturday update. Should have the other 3 pieces cut out soon and then work on a back plate and top plate. Upper shock mount used to connect to the Jaguar XJ-S unibody. I've seen some guys weld the mount to the frame, but it gets really big and bulky and might be in the way of the engine or some accessory?
09-24-2016, 09:07 PM | #558 |
Traced the other 3 off of the first one and poof..... Bat ears are all welded in. Now for the hat with shock mount hole and a back to strengthen it.
09-25-2016, 12:16 AM | #559 |
Saturday Night picture time! Got the hats fitting and welded them in.
Then the doorbell rang at 7pm on a Saturday.....Brown Santa??? What are you doing here so late? Whatever, I'll take it!
09-25-2016, 01:11 AM | #560 |
A guy with a truck
Ooh, forgot about this one. Watching now...
-Chris Instagram _elgringoloco_ '70 Short-Wide How to: Ruin a perfectly good C10 ‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd '72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD) '72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD) '05 Yukon Daily Driven (not so stock) Yukon (SOLD) ‘07 Yukon Denali (daily) Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy |
09-25-2016, 12:18 PM | #561 |
Wow.. Okay gotta say first thing I see when I get over here is Jaguar and that certainly wasn't what I was expecting but boy do I ever trust your choices in rear end setups ever since Frankenstein. Looking great man!
Project NewType 1972 Chevy C/10 Cheyenne Super ( Daily Driven Showtruck ) http://67-72chevytrucks.com/vboard/s...d.php?t=507903 Project Great Grandpa's Legacy 1973 Chevy C/10 Cheyenne ( Current daily driver collecting big time parts ) http://67-72chevytrucks.com/vboard/s...89#post7084289 - Dylan (209)-985-7721 |
09-25-2016, 05:07 PM | #562 |
Crazy thought
Horizontal push rod suspension |
09-25-2016, 11:46 PM | #563 |
OK, I made the curved backs and welded them in solid, then with the rowlock sanding/grinding wheel I smoothed out all the welds and polished them up for paint. Now I need to tear down the rest and clean it up.
09-26-2016, 07:10 PM | #564 |
6>8 Plugless........
Nice work Drew.
Ryan 1972 Chevy Longhorn K30 Cheyenne Super, 359 Inline 6 cylinder, Auto Trans, Tilt, Diesel Tach/Vach, Buckets, Rare Rear 4-link and air ride option Build Thread 1972 GMC Sierra Grande Longhorn 4x4 1972 Chevy Cheyenne Super K20 Long Step side tilt, tach, tow hooks, AC, 350 4 speed 1972 C10 Suburban Custom Deluxe 1969 Chevy milk truck 1971 Camaro RS 5.3 BTR STG3 Cam Super T10 1940 Ford 354 Hemi 46RH Ford 9" on air ride huge project Tired of spark plugs? Check this out. |
09-26-2016, 10:38 PM | #565 |
subscribed
72 GMC highlander nicknamed by my then 6-year-old brother "stripes" http://67-72chevytrucks.com/vboard/s....php?p=7378180 Check out my Youtube channel @Chad's Fab |
09-26-2016, 11:14 PM | #566 |
File this under: How to build a Jaguar IRS coil over shock.
Use some leftover Jag rear disc brake rotors, if you have strong enough all thread that is long enough you can skip the clamp method portion. My coil spring remover bolts weren't long enough so I improvised the first few inches with the clamps. Most spring removers won't fit in such tight quarters, so it is easier just squeezing the whole assembly. The Jag coil overs have the coolest little half ring binding retainers that hold the spring on.
09-26-2016, 11:15 PM | #567 |
The rest of the story.....
09-27-2016, 06:48 AM | #568 |
A320 Pilot/USAF Retired
Nicely done!
JJ My 1957 build: http://67-72chevytrucks.com/vboard/s...d.php?t=334552 http://www.trifive.com/forums/showthread.php?t=22037 Instagram - Chuckdriver57 |
09-27-2016, 10:47 AM | #569 |
That's pretty cleaver. Makes me wonder if that would work with a typical strut/spring assembly. Nice work!
-Duane C/10 Club Texas member 1971 Chevy C10 "Brutus" SWB Fleetside 2016 6.0L (L96) 6L90E (driver/project) 1965 Pontiac GTO "Royal Goat" 400/TH400 w/AC (my baby) |
09-27-2016, 08:56 PM | #570 |
Milestone reached!!! Rear Jag IRS suspension is installed and finished in 1957 Roadmaster frame.
I need a beer.
09-27-2016, 08:56 PM | #571 |
Much better than a spring to the face!
09-27-2016, 11:50 PM | #572 |
Oh, and I left the Jaguar sticker on there just for fun. Also the rear brake pads say Jaguar on them, hopefully they will peep out of the rims.
09-28-2016, 01:08 AM | #573 |
A guy with a truck
Super sanitary, as always. Nice
09-28-2016, 08:16 AM | #574 |
Still Learning
Very nice work Drew. Your spring compressor looks like something I would come up with.
Love to see resourceful ideas. |
09-28-2016, 10:25 AM | #575 |
These are they types of mods that I love. It looks like it could have been factory! Nothing appears to be an afterthought. Nice work Drew!
