04-03-2018, 10:39 AM | #551 |
Moderator
Re: What did you do to your truck today part IV
I installed them on my 64 before paint and they work like butter, the doors close so easy I have to be careful not to slam them.
04-03-2018, 11:31 AM | #552 |
Now that Spring is close, I hope! I ordered a 63 and 64 Shop Manual so I can have a visual back up. Time to bust butt and get the 64 street ready again.
04-09-2018, 12:10 AM | #553 |
My wife has been working on the paint, I installed the hitch, brake controller, trailer plug, LED taillights and cut a piece of diamond plate for the rear license plate.
1927 Willy's Knight 24,000 original miles, 1958 Impala 283/Powerglide, 1964 C-30 383/4 speed, 1971 Monte Carlo 350/350, 1972 GMC K2500 350/350, 1976 Chev. K10 350/350, 2006 GMC Sierra 2500HD LBZ Duramax/Allison, 2006 Chev. Silverado K3500 LBZ Duramax/Allison |
04-09-2018, 07:32 AM | #554 |
04-10-2018, 01:54 AM | #555 |
Love that green truck!
We have a new Old Man on our ranch. The boss added a '58 One-Ton flatbed. Top speed, fifty going down hill with a stiff tailwind. I wonder how difficult it would be to put a V8 in this thing? |
04-10-2018, 10:20 PM | #556 |
BLAZER THIRTY!!
original bracket, from a 65 I bought a parts truck just for that pump.and pulleys
49 chevy 5 window 20 year project (sold)😟 57 ford fairlane (dad's car never got to it before he passed away R.I.P I LOVE YOU DAD.) 62 GMC 305 V6 custom L/B 72 HIGHLANDER K5 BLAZER 2nd owner 71 K5 MAMMA'S RIDE! 63 GMC 4X4 305 V6 62 GMC SHORT BED SERVICE BODY V6 (STUMPY) 74 GMC CUSTOM 1500 L/B |
04-11-2018, 07:47 AM | #557 |
Thank You Mat, they must have changed the design.
http://s1299.photobucket.com/user/jb...23904108567829 |
04-16-2018, 08:29 AM | #558 |
I got my speedometer working! The set screw came out in the elec/mech converter box that grabs the inner cable. I'm really enjoying the simplicity of this model ('63). I watched a youtube on removing the cluster on a 64 and it seems a lot more complicated since all the switches mount thru the cluster.
I also got my retro radio system installed with exception to the antenna. I couldn't find the cable hole into the cable and the antenna wouldn't fit anyway. Guess what I have to order today? My 'ol frame is a little sore from a couple days of truck yoga |
04-16-2018, 08:40 AM | #559 |
I finally hooked up my speedo last week as well, I still need an adaptor because the speedo is off by 12-13 mpg (truck shows slower than real speed). I have to do the tire/pumpkin calculation and order one. I had to get the truck lifted up so I could connect the cable. No way to bend my arm the way it needed while the truck was on the ground, without breaking something .
04-16-2018, 11:13 AM | #560 |
Getting some welding done.
04-16-2018, 11:39 AM | #561 |
I installed my speaker boxes/cups on Saturday and ran all the cable to behind the seat. Next step is getting the interior done
04-18-2018, 11:02 PM | #562 |
Got the power steering pump and all pulleys and belts installed for my power steering conversion. It seems that the pump pulley is slightly out of alignment though. Do you guys think this will be a problem? Not sure exactly how to get it perfect.
04-19-2018, 11:37 AM | #563 |
Yes I think it will be a problem. At best it will cause the belt to wear out fast at worst it will throw the belt. I don't know how your pump bracket bolts on but you might be able to add spacers between the pump and the bracket or you can put a spacer between the alternator bracket and the block but then you will have to get a spacer to push out the pulley on the water pump.
04-19-2018, 12:25 PM | #564 |
I made a bracket for my fuse box and my fan temp controller and got them mounted. I'm ready for the fun to begin
Sanity'66 http://67-72chevytrucks.com/vboard/s...d.php?t=515110 Long bed, Fleetside, Small back window I've Done So Much, With So Little, For So Long, That Now I Can Do Anything With Nothing. |
04-19-2018, 02:26 PM | #565 | |
04-20-2018, 12:13 AM | #566 | |
But Found Her 25yrs Later!
The ones where they sand out too many random spots just doesn't look right. Some knock fauxtina, but I like the practicality of it.
I lost my 65 - Found it 25 years later: http://67-72chevytrucks.com/vboard/s...d.php?t=426650 66 C20 Service Truck: http://67-72chevytrucks.com/vboard/s...d.php?t=428035 |
04-20-2018, 12:24 AM | #567 |
Post Whore
Seat cover that I had for about 2 years on my 64 GMC was torn up beyond use from daily driving. New one showed up today and I am quite happy with it.
1966 Chevy C10 "Project Two Tone" http://67-72chevytrucks.com/vboard/s...d.php?t=596643 1964 GMC "Crustine" semi-build:http://67-72chevytrucks.com/vboard/s...d.php?t=665056 My youtube channel. Username "Military Chevy": https://www.youtube.com/channel/UC_h...fzpcUXyK_5-uiw |
04-20-2018, 09:37 AM | #568 |
Heavymetl
I had to add Shims (washers) to my power steering bracket to get it to line perfectly. The guys at the parts store said that was very common when you modify things. |
04-20-2018, 09:38 AM | #569 |
pdxhall
Way cool brackets. Would you be interested in making and selling a fuse box bracket? PM me if you are. |
04-20-2018, 01:29 PM | #570 |
Moderator
+1
04-20-2018, 05:01 PM | #571 |
Moderator
Okay I made the clips for my radio delete plate.
04-20-2018, 09:24 PM | #572 |
And you did that this weekend.
04-20-2018, 09:26 PM | #573 |
Thank you Mac. I will be trying that in the very near future. Today I got the old steering box out, and new one drilled and mounted. Big shoutout to Capnfab for making an amazing bracket. Thing is perfectly precise in alignment with power steering box and template worked flawlessly.
04-20-2018, 10:00 PM | #574 |
Moderator
No today in about an hour in my little shop, burned my hand.
04-21-2018, 01:08 PM | #575 |
Hey Vin, do you have any detail on how you went about reducing your steering wheel diameter?
Craigerrr My build thread, CRGRS 66 Winter Build: http://67-72chevytrucks.com/vboard/s...09#post5638709 |
