05-11-2020, 10:06 PM | #551 |
Post Whore
Re: A '54 named Busty
and after those, I weldered up the six holes under the seat, here's one of them
05-12-2020, 01:12 AM | #552 |
Post Whore
Two Week Notice: to have Busty ronnin' and drivin' by my Birthday - May 25th! keep your fingers crossed
Left Ta Do: (as of Sunday May 17th, 2020 Anno Domini)
05-12-2020, 06:41 AM | #553 |
Forward progress good...Surprised your not up yet you've had like 20 min's sleep, what is the wire brush on a stick, homemade?
http://67-72chevytrucks.com/vboard/s...d.php?t=635605 |
05-12-2020, 09:37 AM | #554 |
You do nice work, and quick.
8man-aka Robert 1948 on a S10 Frame, small block with a carb 1954 Cab, 53 Front and Bed, 50 Doors, S10 Frame, Power TBD Build thread: "]http://67-72chevytrucks.com/vboard/showthread.php?t=746899&highlight=wife%27s+48[/URL] [/URL]http://67-72chevytrucks.com/vboard/showthread.php?t=840204 |
05-12-2020, 10:10 AM | #555 | |
Post Whore
hmmm, where? which one? |
05-12-2020, 10:36 AM | #556 |
Post Whore
05-12-2020, 12:00 PM | #557 |
Great progress. You will be up and running by your birthday. You got this!!
05-12-2020, 01:00 PM | #558 |
Post Whore
thanks, fingers crossed
05-12-2020, 07:58 PM | #559 |
Clean work on the patches and welding behind the seat. You're getting a lot done. I hope that you're able to get the truck out and drive it on your birthday. However, for what it's worth, if that doesn't happen, grab a comfortable chair, a cold one, sit there and look at your long-wanted rig, and be happy with your progress. If we weren't under lockdown and I was a little more local, I'd join you. Glad you're so motivated, but don't knock your resistance down by not getting enough sleep. You don't need me to big-brother you, but you're no good to us dead. Keep having fun, getting things done, and I'll hoist a brew to you on your birthday.
05-12-2020, 10:18 PM | #560 |
hope you have a happy bird day behind the wheel
the mass of men live lives of quiet desperation if there is a problem, I can have it. new project WAYNE http://67-72chevytrucks.com/vboard/s...d.php?t=844393 |
05-13-2020, 02:04 AM | #561 | |
Post Whore
05-13-2020, 02:05 AM | #562 |
Post Whore
05-13-2020, 02:10 AM | #563 |
Post Whore
do to the high humidity from the rain yesterday and this morning, I was forced to do something on the list instead of painting the back wall of the cab
so I decidded to install the plastic wood in the bed, for that I needed a jig that would allow me to drill with perfect accuracy and dependability two semi aligned holes in each plank at a time, and repeat that process four times per board for nine boards, that's 473 holes - hee hee patent... destroyed! |
05-13-2020, 02:18 AM | #564 |
Post Whore
the process was mundane but rewarding at the same time as you could quickly see results 8 holes at a time
I only encountered one problem when on the very first board, first one on the passenger side I hit the head of another carriage bolt and broke a drill bit, turns out there was a bolt holding the cross sill to the frame, and all I had to do was remove it and run a longer bolt down through the wood and the sill and the frame, so tomorrow I need to pick up two of such bolts one for each side (I did not make the same bonehead mistake on the driver side, there I removed the bottom bolt first, and sure as god's got sandles, the holes lined up) |
05-13-2020, 02:21 AM | #565 |
Post Whore
I am incredibly pleased with the way it turned out, simple yet effective, can't wait to loan my truck to the first distant relative to have to borrow it to take some junk to the dump
05-13-2020, 02:27 AM | #566 |
Post Whore
here it is from a different angle and with some close ups, the boards are not faded they are just dusty and dirty from the grinding and sanding inside the cab et al
05-13-2020, 08:55 AM | #568 |
Post Whore
05-13-2020, 09:50 AM | #569 |
I believe we took over years ago. Every other state is now an extension of Texxxas!!!
05-13-2020, 09:54 AM | #570 |
Amen brother!
05-13-2020, 10:22 AM | #571 |
looks good
https://67-72chevytrucks.com/vboard/...=797726&page=3http://https://67-72chevytrucks.com/...=797726&page=3 51 Chev 5 window on S10 with SBC 1958 Pontiac Wagon build https://67-72chevytrucks.com/vboard/...d.php?t=849781 |
05-13-2020, 12:44 PM | #572 |
This California girl is stayin in Ca, in-laws are in Grand Prairie so I’ve been to Texas several times. Beautiful country there but the humidity kills. The weather here has spoiled us rotten.
Jan's 53 |
05-13-2020, 03:30 PM | #573 |
You have an awesome build as well. This Texan is learning a lot from you fine folks in California.
05-13-2020, 09:58 PM | #574 |
Post Whore
finally liberated the headlight switch and documented every wire
Thick Red - three way split (Amp Gauge, Ignition, and the third is out the firewall to a two way split on the Engine Firewall side, of which one end goes to starter positive ie battery + and the other to the now defunct voltage regulator)FUN FACT: There is no Headlight fuse in your fuse panel, the headlight switch has a built in circuit breaker! Last edited by Gregski; 05-14-2020 at 01:35 AM. |
05-13-2020, 10:28 PM | #575 |
Post Whore
I also installed the Super Tilt steering column, ha ha
