Closed Thread
Old 08-31-2017, 08:37 PM   #5751
mobymikeguide
Re: What did you do to your truck today? Chapter II
Snapped a head bolt torqueing heads on 5.3, modified z bar mount to work on saginaw 3 speed with ls engine, this mount must be for a bellhousing that has eqaul length ears, mine did not so i had lengthen the lower bolt hole, mig on stainless isnt pretty but it proved to be strong
mobymikeguide is offline
Old 09-01-2017, 09:15 AM   #5752
BugzC10
BugzC10's Avatar
Hooked up my cluster temp guage...other ports in the heads where taken up with electric fan thermal switch and mechanical temp guage. Just wanted it to work.
1970 C10 Short Stepper with 71/72 front clip.
BugzC10 is offline
Old 09-01-2017, 09:14 PM   #5753
mobymikeguide
Put intake on motor, pulled gas tank dumped old gas out, found half of an old keyed cap inside the tank lol
Old 09-01-2017, 09:21 PM   #5754
VWNate1
VWNate1's Avatar
Thumbs up Fuel Tank Surprises
I have found many a dead mouse and rocks inside old fuel tanks along with rusty bailing wire, coat hangers, tools and God alone knows what all else .
-Nate
Geezer
'49 3100 235 W/ Muncie SM420 SOLD
'69 C/10 shortbed sidemount survivor 250 L6 W/ 350TH
VWNate1 is offline
Old 09-01-2017, 10:45 PM   #5755
mud.man.rj
mud.man.rj's Avatar
Would have wondered what that noise was w a low tank.
Mudman.
1987 Green n Green machine.
5.0 4spd std.
7" lift w 35's.
mud.man.rj is offline
Old 09-02-2017, 12:46 AM   #5756
VWNate1
VWNate1's Avatar
Post Re: What did you do to your truck today? Chapter II
I've been in more than a few old work rigs where a handful of 3/8" ball bearings wouldn't be heard rolling 'round in the tank .
-Nate
Geezer
VWNate1 is offline
Old 09-02-2017, 01:46 AM   #5757
magwakeenercew2jh
RAT1968 '68 Cab/'71 Parts
magwakeenercew2jh's Avatar
Mudman.
Oh, Mud!!!
You just reminded me of replacing my tank behind the seat. I had it reworked and put it back there because
I didn't want an under the bed tank for a few (not all so good) reasons.
As a solo builder, solo worker, I think it was the worst part of the whole frame up job.....
M17
Coarsegold, CA
RAT's shiny now.
But always a rat.
magwakeenercew2jh is offline
Old 09-02-2017, 02:04 PM   #5758
mud.man.rj
mud.man.rj's Avatar
Oh I love my under bed tank, no fuel sloshing when it is under 1/2 and no smell at all, plus kinda funny when I fill mine, the spout is inside an Danger explosives red box, makes a lot of people wonder what's up w the box, works for me and finally a bit more of in cab room for stereo parts that i never use cause I love the big block and 3" exh, makes my heart beat faster and I smile a lot.
Mudman.
5.0 4spd std.
7" lift w 35's.
Old 09-02-2017, 04:32 PM   #5759
ThePunisher67
Junior Member
I have not got to work on my truck in over 2 weeks but I have bought a lot of stuff. The Home AC went out then my shower started leaking 4k down the drain i would have loved to put it all in my truck
ThePunisher67 is offline
Old 09-02-2017, 04:59 PM   #5760
bill3rail
bill3rail's Avatar
Swapped out the Ignition lock cylinder.
I also installed a new rearview mirror after I had to fixed bad manufacturing on it.
Have a few more minor things to install.
1970 C10 8' Fleetside, L6 250, 3 on the Tree.
The most basic of pickup trucks!
bill3rail is offline
Old 09-02-2017, 11:47 PM   #5761
NoStopN
NoStopN's Avatar
Been feeling guilty about not driving it for a couple of weeks. So, we went for a little stroll. I need to do tune up on it bad.
1969 GMC 2500. 250 I6, 4-speed w/ granny low
NoStopN is offline
Old 09-03-2017, 12:14 PM   #5762
toolboxchev
I put a tune on my rig this week. New adjustable vac advance, cleaned and lubed the distributor properly and new lighter weights so I do not have to rely on the mechanical advance!
Boy I must have gained 100 horsepower! All kidding aside been on hotrodders.com and followed up with some of the tech articles those boys put on, Its good stuff!
toolboxchev is offline
Old 09-03-2017, 06:45 PM   #5763
Andy4639
Old member
Andy4639's Avatar
Talking Re: What did you do to your truck today? Chapter II
I finally installed the 2 under hood light that I got about a year ago after the other one quit working.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver
Seeing the USA in a 71
Upstate SC GM Truck Club
2013,14 and 2016 Hot Rod Pour Tour
http://upstategmtrucks.com/
Get out and drive the truck this summer and have some fun!
It sucks not being able to hear!
LWB trucks rule, if you don't think so measure your SWB!
After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs.
Andy4639 is offline
Old 09-03-2017, 08:14 PM   #5764
AussieinNC
Moderator
AussieinNC's Avatar
You do know these head bolts are TTY Torque Too Yield...meaning they are single use bolts...these should not be re-used or they snap...as you found out...
AussieinNC is offline
Old 09-03-2017, 08:55 PM   #5765
ThePunisher67
Junior Member
I would never use any head Bolt more then 1 time no matter what.
Old 09-03-2017, 10:31 PM   #5766
AussieinNC
Moderator
AussieinNC's Avatar
Makes the use of ARP studs a really good proposition then...
Even a street engine can benefit from a good set of studs...hardened washers and nuts, lube torqued to spec...
Old 09-04-2017, 01:40 PM   #5767
kenn
I just got her running again after the second rebuild in less than a year and am dreading the loud screeching that happens at about 2500RPMs.
After removing valve covers to check rockers then installing and testing again my wife comes into the garage and asks when am I going to fix that dam fan belt.... DOH
kenn is offline
Old 09-04-2017, 01:51 PM   #5768
AussieinNC
Moderator
AussieinNC's Avatar
Remember the golden rule...Happy Wife, Happy Life !!!!!
Old 09-05-2017, 01:56 AM   #5769
toolboxchev
Did a complete coolant flush over a month ago. Still trying to chase a gremlin??? in my gauge as it reads a bit warm.
Put a infrared thermometer all around the system and this is what I came up with.
Thermostat housing 169
Hose Inlet to Radiator 167
Bottom Radiator Driver Side 163
Top Radiator Cap 135
Bottom Out to Water Pump 131
Using 4 core brass/copper, Super Stant 160 Thermostat, Stock Water Pump with cast impeller, Hoses, ect.. Prestone Green with Napa Kool additive.
Not bad for a farm guy. Guess I need to pull that teflon tape off the Sending Unit in the head.
Old 09-05-2017, 10:39 AM   #5770
colgad
colgad's Avatar
Looks good to me!! What was the temp outside? Where was your gauge pointing?
1967 Red, C10 Short Bed 6.0L T5 5 speed
1967 Orange and Black C50 6.2 Detroit Diesel NV4500, 2 Ton Pickup
1972 White, Chevy Blazer 2WD 67 Dog house 5.3 4L65 2016 Power Tour LH
1955 Red-Cream, Chevrolet Nomad, restoration on hold
2004 Black, Corvette Z06 LS6 convertible (Rock solid Fun) 2011/2018 Power Tour
colgad is offline
Old 09-05-2017, 12:38 PM   #5771
NoStopN
NoStopN's Avatar
I forgot that with little/no window trim, water was getting into the doors itself. I noticed this after the last time it rained. So, I cleared out some room in the garage to get the cab under cover. Good thing, it's coming a downpour now.
NoStopN is offline
Old 09-05-2017, 12:39 PM   #5772
NoStopN
NoStopN's Avatar
Dang double post.
NoStopN is offline
Old 09-05-2017, 12:44 PM   #5773
Metaldoc
Metaldoc's Avatar
Mudman.
I moved my tank to the back and put a stereo in it's place. I too listen to the engine more than the stereo. I fill my tank from the factory location beside the drivers door so it looks original.
Metaldoc is offline
Old 09-05-2017, 01:12 PM   #5774
toolboxchev
Gauge was pointing about 2-4 mm over the first line in operating temperature,outside was very humid in the mid 90's. I had just taken it for a run on the freeway. Cooling systems can be a bear sometimes, I still get a little rust after a flush in my coolant reservoir. I should add also that I am using a 16 lb radiator cap which will flow both ways as it should with a reservoir.
The gauge never used to read this way that is why it got me worried. Gen I block with a hot Accel Super Coil HEI and R45ts plugs to burn off any oil blow by.
Old 09-05-2017, 01:31 PM   #5775
OregonNed
OregonNed's Avatar
Getting ready for the Rod Run in Long Beach, WA this coming weekend. With the potential for rain at the coast, I gave the wood bed a coat of crystalline wax ahead of time.
1968 Chevrolet C/10 LWB - 327, TH350 - 4/5 Drop
OregonNed is offline
Closed Thread
