12-15-2018, 04:45 PM | #5801 |
Post Whore
Re: Restoring Rusty
so looking back at my own thread last May I put on the whole brand new Edelbrock Top End (aluminum cylinder heads and aluminum intake) I think the mistake I made was re using my old tin 43 year old valve covers, how can I be so dumb, well I was broke and I thought how crucial are stupid valve covers anyway, well one greasy driveway and oil all over my engine bay I say they are pretty important, so I ordered some brand new tall style ones from Summit (back in June, but didn't install them, neck punch!)
12-15-2018, 04:47 PM | #5802 |
Post Whore
Re: Restoring Rusty
honestly I think the problem may have been the stupid hard rubber gaskets that I got instead of the cork ones, but either way let's install some brand new valve covers, how hard could it be?
oh yeah, also got some of these wide/long [cancer causing, but only in California] valve cover hold downs |
12-15-2018, 06:47 PM | #5803 | |
Re: Restoring Rusty
Talk about a "nanny" state. Politicians there are totally out of control.
Mike 1969 C10 LWB -- owned for 34 years. 350/TH350, 3.08 posi, 1st Gen Vintage Air, AAW wiring harness, 5-lug conversion, 1985 spindles and brakes. 1982 C10 SWB -- sold 1981 C10 Silverado LWB -- sold, but wish I still had it! 1969 C10 (not the current one) that I bought in the early 1980s. Paid $1200; sold for $1500 a few years later. Just a hint at the appreciation that was coming. Retired as a factory automation products salesman. Worked part-time over the years for an engine builder and a classic car repair shop. Member here for 23 years! This is the very first car/truck Internet forum I joined. I still used a dial-up modem back then! |
12-15-2018, 07:20 PM | #5804 |
Post Whore
Re: Restoring Rusty
with the thicker gasket I needed longer bolts
and here's how the short pressure plates compare to the more longer ones (I dig the black ones, most local parts stores carry the chrome ones and in a pack of four, ie two packs needed) |
12-15-2018, 07:26 PM | #5805 |
Post Whore
Re: Restoring Rusty
well even after all the wandanglin' and shandanglin' after careful examination and re examination the Summit brand tall valve covers (be as nice as they were) would not properly mate with these aluminum Edelbrock E Street heads, it kept on feeling like I was hitting metal on metal and my only option was to glue two cork gaskets together but I had another idea...
I used the rusty chrome MOROSO valve covers I got off of Pontiac Mike for a twelve pack (of Taco Bell tacos) he cleaned one up for me with sum steel wool, I guess he thunk I would treat the other one with the same respect, ... Not! I like to goop the valve cover side of the gasket with red bare back buffalo snot to hold the gasket semi in place as we mount it |
12-15-2018, 07:29 PM | #5806 | |
Moderator
Re: Restoring Rusty
The Mr Gasket 6856G valve covers look like 70's hot rod parts... similar to the Micky Thompson valve covers on my last smallblock. There are a lot of those style valve covers out there.
1959 M35A2 LDT465-1D SOLD 1967 Dodge W200 B383, NP420/NP201 SOLD 1969 Dodge Polara 500 B383, A833 SOLD 1972 Ford F250 FE390, NP435/NP205 SOLD 1976 Chevy K20, 6.5L, NV4500/NP208 SOLD 1986 M1008 CUCV SOLD 2000 GMC C2500, TD6.5L, NV4500 2005 Chevy Silverado LS 2500HD 6.0L 4L80E/NP263 2009 Impala SS LS4 V8 RTFM... GM Parts Books, GM Schematics, GM service manuals, and GM training materials...
And please let us know if and how your repairs were successful. Last edited by hatzie; 12-15-2018 at 07:37 PM. |
12-15-2018, 07:33 PM | #5807 |
Post Whore
Re: Restoring Rusty
well Gentlemen and Ladies the circus continues
with the taller valve covers we now had heater hose interference as the hoses were resting on the valve covers and pressing against the hard line fuel rails - presenting us with a dilema of epic proportions we decided to throw money at the problem and blew a ridiculous amount duckets on fittings and hose cutters (to the tune of $90 bucks maybe) the hose cutters we got at Home Depot and oh man worth every penny, the guy at the fittings and hoses specialty shop was super kind and recommended I try a home improvement store instead of an auto parts store for the cutters in order to save some money so I got them for half the price they are technically PVC cutting thingies, so so so nice straight cuts every time |
12-15-2018, 07:34 PM | #5808 | |
Post Whore
Re: Restoring Rusty
12-15-2018, 07:44 PM | #5809 |
Post Whore
Re: Restoring Rusty
and here is the fruit of my labor, I have yet to fire it up to see if it will leak, one disappointment at a time though, ha ha
I am very pleased how it turned out and quite proud of that rubber hose pedistal idea off the alternator bracket, zip tie action at it's finest [Roadkill would be proud] |
12-15-2018, 07:59 PM | #5810 |
Post Whore
Re: Restoring Rusty
as the Dominos were falling and I'm sure you all can relate, you want to change one thing and end up changing 7
I decided to ditch the dual hard carburetor fuel line, for two reasons 1. it defeats the wonderful modular design of the Holley carburetor, more specifically it prevents you from rejetting the carb by only removing the front float/fuel bowl since now the front and rear bowls are joined by this metal aparatus with no give in it 2. in my case the hard line was literally resting / pressing on the 5/16th heater hose line (not sure if that is the supply or the return, I think that's the return line) where it was connected to the fitting going into the intake manifold we are going to run a DIY 3/8th rubber fuel line solution instead with ample bendability Last edited by Gregski; 12-21-2018 at 03:32 PM. |
12-15-2018, 08:06 PM | #5811 |
Post Whore
Re: Restoring Rusty
this is where we start taking one step forward and two steps back
that hard fuel line was such a P.I.A. that I had to lift the carburetor up in order to get the 5/16th heater hose off the fitting on the intake manifold well as I did that I tore the carburetor gasket, we couldn't have that, so I removed the carb and was rewarded with the ugliest gasket sticability factor I have ever dealt with on a carb, I mean this thing was damp for some reason and came off in dime sized pieces if not smaller, there went 2 hours of my life with a razor blade I will never get back and how about that rusted up passage, not sure what it is for but clogged up like that can't be good |
12-16-2018, 01:53 AM | #5812 |
Post Whore
Re: Restoring Rusty
so a few final updates for the day and it was a busy day, got it about 99% done
I want to share what I learned about carb fittings because I was truly in fittings hell trying to convert from the hard lines back to rubber lines, apparantly you can't just go to the Auto Parts store and get a NPT 3/8th barb fitting and screw it in to your carburetor, oh no I'm sure there are many ways to do this, but I like the way I did it as it eliminated some extra hardware, in particular these inverted 7/8-20 to 5/8-18 intermediate buggers here I show one from the front and the other from the back so you can see how they look |
12-16-2018, 01:59 AM | #5813 |
Post Whore
Re: Restoring Rusty
I found these Mr Gasket Inlet Fittings for a 3/8ths hose with the large 7/8-20 thread which allows them to screw right into the carb bowls without those intermediate buggers from before
and of course I didn't use any tape on those threads, ha ha |
12-19-2018, 10:25 AM | #5814 |
Post Whore
Re: Restoring Rusty
presenting the Roadkill Repair [Starter] Kit
"If you can't find the right tool in this garage Mr Arizona, you don't belong near a car." |
12-19-2018, 02:39 PM | #5815 |
Re: Restoring Rusty
So True!
12-20-2018, 01:28 AM | #5816 |
Post Whore
Re: Restoring Rusty
I am giving this update to my brothers and sisters who found themselves at one point going 55 MPH in reverse like me the last couple of days, man it's been ruff, nothing was going The Greg's way
I got to the point where all I had to do is tighten that last 3/8th inverted flare fitting in the fuel pump and take the truck for a test drive, but and you can already see where this is going but even though I used that two wrench technique to hold the coupling that's welded to the fuel pump while twisting the fitting into it, I still managed to ever so slightly twist the darn thing, which you guessed it caused a massive fuel leak so I was crushed, it was late at night and I decided to walk away.... |
12-20-2018, 01:31 AM | #5817 |
Post Whore
Re: Restoring Rusty
realizing I need to replace the fuel pump anyway I thought why not give an electric one a go, so I went out and got the Mr. Gasket #12S (it being for the 8 bangers)
I mean how hard could it be? being a simple man I opted out for a simple basic two wire gitty up, black wire (ground) goes to the frame, red wire plus 5 AMP fuse goes to the fuse panel key on slot |
12-20-2018, 01:33 AM | #5818 |
Post Whore
Re: Restoring Rusty
X marks the spot
well this is where it went, I need to take a pic with it installed, it got too dark and I already lowered the rig |
12-20-2018, 01:38 AM | #5819 |
Post Whore
Re: Restoring Rusty
"Sometimes God's greatest gifts are unanswered prayers" thank you Garth I couldn't have said it better myself
well not exactly but that leaky fuel pump was a blessing in disguise, since after I pulled it off I saw this... gentlemen/ladies let me be blunt... WE FOUND THE EXHAUST LEAK !!! LOL that's right, a set of stock exhaust manifolds, two sets of headers, and God only knows how many different exhaust gaskets and two/three years later, what I swore sounded like an exhaust leak, clickitty clockin' noise was this darn busted fuel pump rod spring thingie Last edited by Gregski; 12-20-2018 at 01:47 AM. |
12-20-2018, 01:44 AM | #5820 |
Post Whore
Re: Restoring Rusty
TEST DRIVE
Oh my goodness I am now hearing noises rattles and squeaks that I didn't know existed, and I mean it in a good way, I may even be hearing "Road Noise" lol, Honda style, jk
I only driven it around the block and then to the gas station, so I still need to take it on the freeway, and i will report back, but for the time being, thumbs up for that little $40 dollar guy, complements of AutoZone Last edited by Gregski; 12-20-2018 at 01:55 AM. |
12-20-2018, 02:06 PM | #5821 |
Re: Restoring Rusty
I have a similar pump feeding my big block so I think you will be ok.
85 K30 crew cab dually - Project http://67-72chevytrucks.com/vboard/s...d.php?t=694939 87 Wrangler Rock Crawler - Reason for the project http://www.wranglerforum.com/f330/da...ld-122601.html 04 1500 crew cab http://67-72chevytrucks.com/vboard/s...d.php?t=786514 |
12-20-2018, 08:41 PM | #5822 |
Post Whore
Re: Restoring Rusty
12-20-2018, 10:11 PM | #5823 | |
Moderator
Re: Restoring Rusty
And please let us know if and how your repairs were successful. |
12-20-2018, 11:29 PM | #5824 |
Second Chance Program
Re: Restoring Rusty
Still one of my favorite threads.
90 Chevy Suburban 2500 5.3 swap/th400/np241/14bltSF/10blt. 77 C20 crew cab Silverado. 396/th400. In work. |
12-21-2018, 02:05 PM | #5825 |
Re: Restoring Rusty
To be honest Gregski... I don't remember what brand I went with.
