10-02-2017, 08:49 PM | #5826 |
laying low
Re: What did you do to your truck today? Chapter II
And just in time to put it away for the winter too.
Boog 69 Chevy stepside, 358/T350, 4.11 posi, 4.5/4 drop, rallys, poboy driver primer is finer 91 Chevy sportside, Tahoe, Yukon & GMC Crewcab All GM..'nuff said. I stand for the flag and kneel at the cross |
10-04-2017, 11:55 AM | #5827 |
Installed a vacuum reservoir to help the brakes. It didn't seem to help. The brakes have been poor since the 402 with a big cam was installed, compared to the stock 350. Push the pedal hard and takes too long to slow down. Stock vacuum gauge shows 12hg on deceleration but it waivers a lot with throttle position. I hoped the vacuum gauge would be more stable at more then 10hg with this reservoir, but maybe the gauge pickup is on the motor side, not the brake side. I have an expensive Hella electric vacuum pump but was hoping to avoid installing it as a solution.
1972 Cheyenne Super SWB PS, PB, Tach, A/C, Tilt. Drivetrain: Built 402BB, TCI Streetfighter 700R4, 2,500 stall, Eaton posi, 3.73. Suspension/Chassis: ECE 4.5/6.5 drop, CPP nitrogen shocks, CPP front and rear sway bar, CPP cross members. Exhaust: 3" exhaust with x-pipe, Spintech 3000 mufflers, Hooker ceramic coated headers. Best 1/4 mile time: TBD. |
10-04-2017, 12:42 PM | #5828 | |
1970 C10 Short Stepper with 71/72 front clip. |
10-04-2017, 05:32 PM | #5829 |
Vacuum Assist Brakes
Firstly, you need to have a check valve between the engine and the resivoir, since you're never reading above 12" clearly there's a low vacuum issue .
The gauge also needs to be on the booster side of the check valve . Shouldn't need to add a vacuum pump once everything is properly plumbed up .
-Nate Geezer '49 3100 235 W/ Muncie SM420 SOLD '69 C/10 shortbed sidemount survivor 250 L6 W/ 350TH |
10-04-2017, 05:56 PM | #5830 |
Re: Vacuum Assist Brakes
X 2
10-04-2017, 06:04 PM | #5831 |
The black plastic cap in the second photo is the 1 way valve. The hose connected to it is from the engine. I blew into it before the install and confirmed the valve worked.
I followed these instructions http://www.jegs.com/InstallationInstructions/200/270/270-99590-1.pdf Posted via Mobile Device Last edited by Ekliptix; 10-04-2017 at 06:10 PM. |
10-04-2017, 06:22 PM | #5832 |
Got something done today. Removed both battery cables and cleaned those up a bit.
Used Dremel Tool to remove paint and epoxy primer from other ground point on core support. Ordered two battery clamps from O'Reilly's Auto. Checked prices on battery cable (4 gauge) at NAPA and Advance Auto. |
10-04-2017, 06:48 PM | #5833 |
I did the best thing you can do to your truck today......
I drove it! |
10-04-2017, 07:17 PM | #5834 |
10-05-2017, 10:16 AM | #5835 |
Made some money for a fleet side bed for my K/10 short, by helping a friend with his 70 4x4 BLAZER. Didn't do all this in a day, but it felt good and I am happy with results. New ring gear spacer, bolts Loctite and torqued, shimmed. I know the spacer is not the hot setup but will up grade this winter. New axles, bearings, seals, complete rear brakes and gear oil. Beach ride test run soon! THANKS for all the information and help found here. I believe you can teach a old dog new tricks! Nothin special but here are a few pics. My friend in pic helping with C clips.
10-05-2017, 06:15 PM | #5836 |
Worked on interior a bit . Finally have a radio
10-05-2017, 07:08 PM | #5837 |
I picked up my new battery clamps and then I went to NAPA and they cut new cables for me. I also bought the eyelets, solder, and heat shrinking wrap for the ends. I removed three brackets from Evaporust, rinsed, and hit with rust converter. I then put my last to brackets into Evaporust soak.
10-06-2017, 07:24 AM | #5838 |
getting ready to do something I was hoping not to have to do. the reman 700r4 I just put in (maybe 80 miles on it ) has to come out and go back to the seller. hasn't worked right since I put it in. and yes the TV cable was adjusted correctly. driving down the road at 60 mph, it will shift down to 3rd and never shift back. doesn't shift to 1st when I come to a stop. just not right. Oh Well.
10-06-2017, 11:19 PM | #5839 |
Adding this.....because of this....
JMC1965 1967 C20 LWB
10-07-2017, 07:59 AM | #5840 |
Moderator
mmm...is this an auto truck? If it is, I hope you checked that the vacuum modulator on the trans for oil leaks...I have seen a blown modulator suck trans oil straight into an engine, resulting in loads of smoke...just like your pic....
Hope I am wrong...but... |
10-07-2017, 08:39 AM | #5841 |
checked everything...oil fowled plug #8....pulled engine....I'm guessing the PO built himself from a short block. when tearing apart the torque of bolts was all over the map....china wall gasket would have failed soon anyway (inconsistent depth & width).
So....always looking for an excuse for more shiny things....bought an ATK HP32C. Going to pull the carb and re-install my FITech from old motor Left to right....2,4,6,8. 8 had all the oil on it. Based on 4 & 6 something else was going on also
10-07-2017, 08:45 AM | #5842 | |
Moderator
Have fun mate...and you are right...nothing nicer than something new and shiny...glad to see you went Vortec....nice engine! |
10-07-2017, 08:51 AM | #5843 |
thanks for the tip on the modulator...will poke around on that too.
yeah....vortec and hydraulic roller cam....looking forward to a little more power
10-07-2017, 10:50 AM | #5844 |
Which crate engine did you buy?
10-07-2017, 12:43 PM | #5845 |
Well after a year of having my truck just sitting in the driveway, finally made some progress on it, changed the brake lines, installed Boyds fuel cell, and got The Circle D stall installed, unfortunately after looking at the oil dipstick noticed water in the oil. So now I got to see where its coming from. Got to back to work, so hoping to back at it Wednesday.
10-07-2017, 06:26 PM | #5846 |
With the help of the forum, I found and installed a set of trash guards under the cowl. Let those leaves start falling!
10-07-2017, 06:38 PM | #5847 |
10-07-2017, 07:03 PM | #5848 |
I wanted to see if I can get the battery and temp gauges working, so I dug into the wiring to see what I have and don’t have.
Discovered that my dash harness has the wiring for the battery gauge, but the engine harness does not. Not a surprise since the truck is made up from 67, 68 and 70 parts. Can I add the 2 wires to the block on the engine side of the firewall or do I have to run them separately? The wire for the temp gauge runs into the engine bay, but was disconnected when a PO added the under dash gauges. I should be able to hook that up once I get the correct temp sensor. These discovery missions seem small, but they are all important as I continue to make the truck better. |
10-07-2017, 08:06 PM | #5849 |
Found my intake leak on the 350. Sounds sooo much better. These gaskets seem so cheap.
10-07-2017, 09:23 PM | #5850 |
Moderator
