Closed Thread
Old 07-09-2012, 03:49 PM   #5951
3r!c84
Badass
3r!c84's Avatar
Re: How about some pics of '73-'87 Short Beds
Originally Posted by OhYeah!!! View Post
thanks !!!!!
yes, they are from a third gen camaro
no they were purchased at a local wheel shop
they were built by a local upholstery shop !!!!
hey have you been to any shows around south fl? abacoa the first sat of every month is pretty big. so is the one at the costcos every sat southern and 441
Think outside the box?
-84c10 (1stcar)→My Build
-00 Saturn 5spd
drop a gear and disappear!
1/4:13:90
3r!c84 is offline
Old 07-09-2012, 07:17 PM   #5952
bbbc10
Diggin The SquareLife
found this truck on ebay!
bbbc10 is offline
Old 07-09-2012, 07:45 PM   #5953
ccreddell
ccreddell's Avatar
Got a link?
ccreddell is offline
Old 07-09-2012, 08:17 PM   #5954
1977cheyenne_C10
1977cheyenne_C10's Avatar
HERES THE LINK
http://cgi.ebay.com/ebaymotors/Chevr...ht_1657wt_1006
1977cheyenne_C10 is offline
Old 07-09-2012, 08:36 PM   #5955
Gordonr1973
Home Built '87
Gordonr1973's Avatar
Originally Posted by 85sierraclassic View Post
is that a factory color then or from somthing else looks good btw
It is an old factory color....I think it was on Buicks and Camaros.
Gordon
1998 White Chev ext cab 2WD (Summer Project) http://67-72chevytrucks.com/vboard/s...d.php?t=408424
1987 Chev Silverado SWB (Winter Project Rebuild) http://67-72chevytrucks.com/vboard/s...d.php?t=424833
Truck Club http://67-72chevytrucks.com/vboard/s...d.php?t=466969
Gordonr1973 is offline
Old 07-10-2012, 01:32 AM   #5956
Franki Frank
Clean truck.
Franki Frank is offline
Old 07-10-2012, 03:21 AM   #5957
walka
walka is offline
Old 07-10-2012, 01:35 PM   #5958
WDH87
Originally Posted by bigsj View Post
Welcome to the forum very nice truck..
Thanks! I have added air shocks to the back to give it a little rake now...
WDH87 is offline
Old 07-10-2012, 02:08 PM   #5959
Franki Frank
anyone know where i can get a 2 4 dropkit what brand should i buy for my spindels
Old 07-10-2012, 05:02 PM   #5960
made2drag
made2drag's Avatar
Originally Posted by brakenit View Post
Thanks, it's the nicest square I've ever owned. I was lucky to have been at the right place at the right time to get it.
It was on the drivers side inner fender.
It says:
161L 61 DOESKIN TAN SOLID
Some pictures I took yesterday while test driving after I finished adjusting the steering box. It was scary sloppy for a 54k mile truck but 10 minutes with a 5/8" wrench and 3/16" allen wrench took care of it. Should have a mess of parts showing up this week to get it back to a reliable driver. For now I'm just going to clean it up and lower it. I should make a fun summer cruiser until I decide what direction to go with it.
this may be a dumb question, but how did you adj your steering box? mine alittle loose too. love your truck, looks like a good solid one to start with
made2drag is offline
Old 07-11-2012, 04:29 PM   #5961
STOUTE
here's the picture of my wifes 87 c10.
STOUTE is offline
Old 07-12-2012, 09:44 AM   #5962
brakenit
Active Member
It's not too bad. Jack the truck up to get the wheels in the air, center the wheels, loosen the lock nut on the set screw on the top of the steering box, tighten the set screw until it bottoms out and then back it out a 1/4 turn and re-tighten the lock nut.
There's a long and drawn out process to set the steering box the technically correct way but this is a way I was shown a long time ago. I've been told it may cause the box to wear slightly faster but to me it doesn't matter since this truck won't get driven very often so it will still last a long time and I will most likely completely change the suspension/steering after a few years.
Thanks for the compliments on the truck. It will roll out of the garage fairly soon looking a little different. Discount Tire had a pretty decent deal going on so I picked up a set of 17x8, 17x9.5 MB Old Schools with 255/50/17 and 275/50/17 NT450's. I have most all of the stuff to lower it and everything to rebuild the front suspension is on the way.
brakenit is offline
Old 07-12-2012, 05:21 PM   #5963
mgunn69
mgunn69's Avatar
Hey guys, love the site. Figured I would post up my truck. 87 GMC stepside. 383 SBC, and cold air!
87 GMC Cruiser.
mgunn69 is offline
Old 07-12-2012, 06:53 PM   #5964
bustedknuckles
bustedknuckles's Avatar
nice mgunn. any engine/interior shots.
84 GMCummins
91 CCSB Dually
american squarebody association
bustedknuckles is offline
Old 07-13-2012, 08:08 AM   #5965
mgunn69
mgunn69's Avatar
Thanks busted! I don't as of now on my work computer. I will get some up soon.
Trying to decide on wheels and tires. Would like to do the 20x10 and 20x8 deal.
I have a an issue with the chains on the gate. They don't have any plastic on them. What have you stepside guys done in the past? Or should I just order some pastic coated chains?
Thanks and nice rides in here for sure!
Michael
87 GMC Cruiser.
mgunn69 is offline
Old 07-13-2012, 10:00 AM   #5966
fencepost
fencepost's Avatar
Seen folks use seatbelt latches on the inside of the bed and gate. Could go to the local hardware store and possibly get some clear rubber hose that will slide over the chain.
fencepost is offline
Old 07-13-2012, 12:16 PM   #5967
mgunn69
mgunn69's Avatar
Hey thanks. Yea I tried the clear hose, but it is so stiff the chain make a nice loop look. HA. Not really diggin it. The seat belt thing sounds cool.
87 GMC Cruiser.
mgunn69 is offline
Old 07-13-2012, 01:45 PM   #5968
LOW 7FO
LOW 7FO's Avatar
I used the seat belt trick with GM buckles on my first rig. It was really cool actually. When I used chains I just got the kit from LMC. The hose was not too stiff and it allowed the neat coil of the chain. I would recommend it if you want the original appearance.
lowfastnloud
LOW 7FO is offline
Old 07-13-2012, 02:08 PM   #5969
Low84
Low84's Avatar
1978 stepside C10 build: http://67-72chevytrucks.com/vboard/s...d.php?t=468265
Low84 is offline
Old 07-13-2012, 02:11 PM   #5970
mgunn69
mgunn69's Avatar
Thanks man! Yea I think I will check on LMC. Got me a new catalog coming!
87 GMC Cruiser.
mgunn69 is offline
Old 07-16-2012, 05:40 AM   #5971
von guido
von guido's Avatar
i plasti-dipped the chains
officer,we weren't racing.. he was merely pacing me.
von guido is offline
Old 07-16-2012, 07:57 AM   #5972
mgunn69
mgunn69's Avatar
How do you go about doing this? A kit you can buy? Thanks
Michael
87 GMC Cruiser.
mgunn69 is offline
Old 07-17-2012, 11:12 PM   #5973
ShortwideRide
Well here's my first post. Might as well show yall what I got
ShortwideRide is offline
Old 07-18-2012, 12:37 AM   #5974
Gordonr1973
Home Built '87
Let's see some more pics of these black trucks please!
Gordon
Old 07-18-2012, 08:15 AM   #5975
Kainedogg
Kainedogg's Avatar
Yes I do, i will post them soon. Thank you!!
Love your truck Carlos. Easily my favorite on this site. I have a red '83 I am sticking a twin-turbo LQ4 in, and have quite a few questions for you about the aesthetics of your truck, from how its lowered, what type of brackets for the seats and the back bumper. Can't pm you, but I also don't want to clog this thread.
Kainedogg is offline
Closed Thread
