02-15-2009, 06:37 PM | #576 |
Re: 68 K-10 SWB build thread - project Money Pit...pics galore!
well, maybe i'll get some work done on this tomorrow... gov employee day off ya know...
Decided to try the electrolosis rust removal on my new water pump, probably just have to buy another, this thing rusted on the inside in two months of being removed... Then I picked up on of these 3M discs for the grinder ($14!) but it takes paint off pretty nice. Figured I would try to strip the tailgate I have vs. blasting.... Also picked up a new tip for the Miller...I love going to AIRGAS, started talking with the manager about trucks and learned that he had a 68 back in the day... Good news is that mama agreed to get the truck painted once I get promoted. COuld be this summer or within the next two years!!!!! at least it's a start..
The Garage: 1968 K-10 SWB - "Project Money Pit" 1996 Z-71 - "huntin rig" 1969 C-10 LWB (SOLD) "Project flip that truck or else" 1993 Passport, F@rd 1-ton (SOLD)"Project Cousin Eddie" My Garage Build "The 1,000 footer" Last edited by msgross; 02-15-2009 at 06:38 PM. |
02-15-2009, 08:14 PM | #577 |
very nice, i use those bristle pads at work on the old cars, work good, but expensive!
James 1968 GMC "HAVOC" 1986 GMC "Frank" J.J.R.H. Design & Consulting My 68`Rebuild "HAVOC": http://67-72chevytrucks.com/vboard/s...d.php?t=316300 A 58' chev build thread: http://www.67-72chevytrucks.com/vboa...d.php?t=311238 1969 Camaro Pro Touring http://67-72chevytrucks.com/vboard/s...61#post3513361 Swiss Cheese: http://67-72chevytrucks.com/vboard/s...d.php?t=384390 Adjustable Trailing Arm How-To: http://67-72chevytrucks.com/vboard/s...d.php?t=321100 1968 Ford Farm Truck: http://67-72chevytrucks.com/vboard/s...=1#post6555587 |
02-15-2009, 08:16 PM | #578 |
how long do they last?
The Garage: 1968 K-10 SWB - "Project Money Pit" 1996 Z-71 - "huntin rig" 1969 C-10 LWB (SOLD) "Project flip that truck or else" 1993 Passport, F@rd 1-ton (SOLD)"Project Cousin Eddie" My Garage Build "The 1,000 footer" |
02-15-2009, 10:15 PM | #579 |
I put my corvette crank pulley on and it looks pretty close. It could use another 1/8" spacer in between the two...
02-15-2009, 10:17 PM | #580 |
I'm also trying to figure out the correct spacing and height of this rocker... any help?
02-15-2009, 10:22 PM | #581 | |
R
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 |
02-15-2009, 10:25 PM | #582 |
LET'S GO RACIN'
You can pick up spacer's for the crank pulley's, in case you didn't know. I can get you a measurement tomorrow off of mine. Mine sat right on top of the inner and fit pretty snug. I did have to take a board to the lip so it would have the right spacing. Clamped the outer rocker in place then put screws in to check fit.
Daren 04 Chevy Extend cab 2500HD 6.0 Liter 4x4 71 CHEVY 3/4 4X4 402 BB, th400/np205, dana44/eaton ho52 w/4:10-TOY Rip El Jay RIP BOBBO'S MOM |
02-15-2009, 10:25 PM | #583 |
that would mean it needs to come up... i don't think it can since my gap is as tight as it can go... overall I think the floor is a little high so I need to fix it with the rocker.
02-15-2009, 10:29 PM | #584 | |
with everything that was missing on my cab i'm lucky that it all lines up this close... the is my first time if you can't tell..
02-15-2009, 10:36 PM | #585 |
LET'S GO RACIN'
Figured you did. I'm with you on that one. Taking it one part at a time. I'm glad i didn't have to put a full floor in like you did. I would have to say the outer rocker has to be the easiest part so far. Famous last words. Good luck with yours. Daren
02-16-2009, 07:47 AM | #586 |
Use some zip screws to pull the rocker down to the floor flush, gotta sit tight so you can weld it. Generally you have to play with the A post to allow the front portion of the rocker to come down, looks like the gap is tight on the front of the door, hard to see.
The gap between the floor and the rocker looks pretty strait, that height will not change as the rocker has to sit tight against the floor Got any pics of the front with the door closed?
Semper Fi...Uncle Sam, you da man All parts offered to help are free, unless otherwise noted Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training SAFETY FIRST AS usual, off topic They say your mind goes second, can't remember the first Jim |
02-16-2009, 10:01 AM | #587 |
I need to remeasure the A-pillar, like you said, I think it's a little high. That or the BFH can adjust it..
02-16-2009, 10:22 AM | #588 | |
Here's my angle Congrat. on your promotion, are you a full bird?
02-16-2009, 12:50 PM | #589 |
that's quite the angle, shows that I have to room to play with. How's the weatherstrip mate up with your door?
02-16-2009, 01:44 PM | #590 |
how did the electrolosis work out? did it free up you water pump. i was wondering if that works good?
"The way it is" truck build http://67-72chevytrucks.com/vboard/s...d.php?t=359200 |
02-16-2009, 04:24 PM | #591 |
Tight on the fit to the door, seals nice
02-16-2009, 06:21 PM | #592 | |
i'm still gonna go buy another water pump since they are only $25. It worked pretty well, i'd try it on small items that a wire wheel couldn't get into... I should have let you TIG my gas tank delete in... what a mess. All was going well and then I blew a hole, which grew and grew. I should have tacked it in from the back... then filled in the groove. I THINK I saved it but who knows. It will need some mud, I just hope it doesn't crack in a year or two from a week spot or something...
02-16-2009, 06:29 PM | #593 |
they can last up to an hour but if you are hitting edges or sharp things expect a third of the life.
02-16-2009, 07:08 PM | #594 | |
02-16-2009, 07:09 PM | #595 |
thanks.. i doubt I will buy another since it is going down pretty quickly..
Today I decided to ruin a perfectly good hole. I have this patch from Infinity rides and wanted to burn something... Well, I should have done more research. All was going well until the first hole opened up... then it was downhill form there. That led to more and more and finally I had to go to the backside to thicken up the metal that I had ground away from the front. I should have tacked the in from the back then ran a small bead in the gap to fill it in on the front. Hindsight being 20/20 I think the will work. it's gonna need a little mud and sanding and the back is ugly has heck...that's for sure
02-16-2009, 09:03 PM | #596 |
hey where did you get that gas tank filler piece i know you said something about infinity rides, but a google search got me no where
02-16-2009, 09:23 PM | #597 | |
http://67-72chevytrucks.com/vboard/s...d.php?t=247681 he is on Ebay too...
02-16-2009, 10:33 PM | #598 |
LET'S GO RACIN'
I measured my original cab and the gap looks to be just shy of 3/8 of an inch. I plan to do the gas tank hole too, looks like you had fun with yours. Good luck with your progress.
Daren 04 Chevy Extend cab 2500HD 6.0 Liter 4x4 71 CHEVY 3/4 4X4 402 BB, th400/np205, dana44/eaton ho52 w/4:10-TOY Rip El Jay RIP BOBBO'S MOM Last edited by 88JRFAN; 02-17-2009 at 12:23 AM. |
02-16-2009, 11:44 PM | #599 |
cool, thanks for the information...
02-17-2009, 08:23 AM | #600 |
Restoring a 68 SWB
Looking good man. I need to burn my gas tank delete in too.
My Build Thread: Lucy - My 1968 SWB - Shop Truck Style North Nashville Concrete Contractor |
