Old 08-26-2011, 03:07 PM   #576
smokedat
smokedat's Avatar
Re: LS1 into a 73 cheyenne
My4by2 those digital renderings of youre trucks are awsome were can I get one made???
smokedat is offline   Reply With Quote
Old 08-26-2011, 03:16 PM   #577
smokedat
smokedat's Avatar
I found these pics there out of a blazer built by the guys from Fesler. I called and asked a few questions they used a hinge from a mercedes benz.
Old 08-26-2011, 05:13 PM   #578
mcbassin
Still Learning
mcbassin's Avatar
Originally Posted by my4by2 View Post
If you'd care to hold out for a bit, I may know of a better option for you on the hood hinge issue!!! I am having a shop out in Tennessee custom fabricate me some billet hood hinges for my '77 (so they'd fit all 73-80's). They're using the stock hinge for reference & sure once they've made my set & have the CNC programming done the cost would more similar to other parts out there already (so I am absorbing the design cost basically...). Check out my thread from time-to-time as I will post updates on them once they get rolling.
Just out of curiosity, what is the design work going to cost you? If you don't mind? I am very interested in building some of these (I have cnc machines too). I bet the full hinge assembly is high$$ too. shoot me a pm if you don't want to post it here.
Alex,
I tried to do some layout work with your Z-10 logo the other day....not having any luck with the geometry. Any chance you can make a photoshop .dxf file? Just so you know I didn't forget about you. Just haven't figured out how to get the geometry right yet.
mcbassin is offline   Reply With Quote
Old 08-26-2011, 05:18 PM   #579
Jonboy
Slots go on anything!
That cut looks brutal, Alex. Hope it heals fast!
1974 Jimmy- 5.3/4L80e/NP241
Old 08-27-2011, 08:48 PM   #580
smokedat
smokedat's Avatar
front components are installed. I am now in the process of setting the height. its 4" of the ground in the front
Old 08-27-2011, 08:53 PM   #581
smokedat
smokedat's Avatar
i was planing on using the inner fender tubs but after installing them they cover all the goods so i was debating weather or not to install them. I wanted some protection from debri flinging into the painted fire wall and engine so i cut the fenders up to where the tire meets. The bling bling is still exposed and i have some protection
Old 08-27-2011, 08:54 PM   #582
smokedat
smokedat's Avatar
close up of the stopping power
Old 08-27-2011, 08:57 PM   #583
my4by2
my4by2's Avatar
Looking good man! Can't wait to see this one finished!!!
Brakes are KILLER too!
1977 Chevrolet K30 LWB Crew Cab
497HP Mast Motorsports 6.0L LY6 HO engine
GM NV4500 5-speed, Centerforce clutch + NP205
D60 + 14-bolt FF w/ Eaton posi + disc brakes
Skyjacker 2.5" full spring lift w/ Nitro shocks
Custom paint + interior
http://67-72chevytrucks.com/vboard/s...d.php?t=435722
my4by2 is offline   Reply With Quote
Old 08-27-2011, 08:58 PM   #584
smokedat
smokedat's Avatar
Still waiting on the column i will have to redo the fire wall were the column protrudes from fire wall. to install the swivel ball, I did get the other steering items
Old 08-27-2011, 09:03 PM   #585
my4by2
my4by2's Avatar
Got my steering column coming in from ididit too! That steering wheel is pretty unique man - should look sweet!
Old 08-28-2011, 12:49 AM   #586
juiceman650
juiceman650's Avatar
Build is coming along awesome man. Haha, I like how you don't let a spring to the face slow you down. That takes some cajones my friend.
juiceman650 is offline   Reply With Quote
Old 08-29-2011, 12:17 PM   #587
68 TT
Still plays with trucks
68 TT's Avatar
Originally Posted by smokedat View Post
I have to report that I was injured today while trying to install the springs on the hood hinges. Spring broke loose got air and hit me in the fore head above the eye. It took a minute to control the situation. I cleaned up went home early bummed. I realized it was deeper than I thougt so I went to the ER to stich up. I guess it's true when they say " blood sweat and tears" . I'll post sum pics later I'm on the iPhone waiting in the ER
Ouch. Glad it missed your eye and you are OK.
I had a spring compressor break while putting dome heavy rate springs into the front of my Chevelle. It shot the spring right past my ear and put a dent in the block wall ten feet behind me. It probably would have killed me if my head was 6" to the right.
miSSed opportunity - ground up creation of an AWD 1994 454 SS that never was http://67-72chevytrucks.com/vboard/s...d.php?t=795577
69 C10 shortbed stepside 400 small block - built like what a super sport truck could have been
69 K20 lwb TBI 350 4L60E NP208 14-bolt Dana-44 w/disc
68 Camaro SS / RS 500hp 439 inch roller cam big block 4L80E
79 Malibu TPI 350 4L60 w/ Z28 steering & sway bars
68 TT is offline   Reply With Quote
Old 08-29-2011, 12:28 PM   #588
68 TT
68 TT's Avatar
Nice idea for the front tubs.
I would weld a piece of 1/4" round rod to the edge to stiffen it up and make it less of a knuckle buster.
Old 08-29-2011, 05:48 PM   #589
R&K's71
very nice build. Great bodywork cant wait to see some color
R&K's71 is offline   Reply With Quote
Old 08-30-2011, 06:54 AM   #590
73gmc454
73gmc454's Avatar
Lookin good , I agree run the 1/4" round on the inner ,
my build 77 gmc shortbed big block, http://67-72chevytrucks.com/vboard/s...d.php?t=438237
73gmc454 is offline   Reply With Quote
Old 09-01-2011, 08:01 PM   #591
smokedat
smokedat's Avatar
got this bad boy in today. SnapOn racejack set
Old 09-01-2011, 11:46 PM   #592
smokedat
smokedat's Avatar
Hinges came in and at a glance it seems that the retro fit may be possible, geometry is similar tho I noticed that the new billet hinges when fully extended sit higher. Quality and finish are superb I will start this operation tomorow hopefully its done by the weekend but with cruise night in town this Friday I will loose a days work.
Old 09-01-2011, 11:50 PM   #593
smokedat
smokedat's Avatar
I also had a change of plans of how the radiator will mount so i broke off and sanded smooth with sergical precission the angles i had tigd. I was nervous about the possibility of damaging this expensive unit but it all workd out well
Old 09-01-2011, 11:55 PM   #594
smokedat
smokedat's Avatar
I will hide the mounting brakets to the radiator so it gives the apearance its suspended by magic. something like this pic.
by the way still waiting on the steering column to arrive
Old 09-02-2011, 01:31 AM   #595
kvn1011
Kvn1011
kvn1011's Avatar
lookin good bro! im never dissapointed when i visit your thread
kvn1011 is offline   Reply With Quote
Old 09-03-2011, 11:08 AM   #596
68 TT
68 TT's Avatar
Nice job removing the brackets.
Make sure you use some rubber isolators of some kind so the radiator can move & expand independent of the core support. Rigidly mounting aluminum to steel will end badly. They flex differently and expand differently due to temp changes.
Old 09-03-2011, 08:49 PM   #597
smokedat
smokedat's Avatar
started the work on the hinges, I did the layout and the hinge did not clear over the firewall so i had to notch the corners on the firewall, later I will box them. I placed the hood in position crawled in the engine area and markd and punched the holes for the fenders and the top ones for the hood. hood and hinge were not flat-level so i had to cut a bump on the hood so the hinge would be flat on. Process is slow but thats just how it is when doing metal work. Il post sum pics later.
Old 09-03-2011, 08:58 PM   #598
my4by2
my4by2's Avatar
Should'a just waited a bit... I am having hinges custom built for my '77 & the shop doing it will be able to reproduce them if required. Still though, it's looking killer man - love all your work!
Old 09-04-2011, 10:03 PM   #599
smokedat
smokedat's Avatar
Thanks for the offer but honestly i couldnt resist the chalenge of installing thes 72 hinges.
Old 09-04-2011, 10:06 PM   #600
my4by2
my4by2's Avatar
I understand, I actually looked into doing the very same thing to save some loot, but just decided against it so the body panels didn't require mod'ing to make it work. Look forward to seeing how your's turns out though!
73c10, c10, cheyenne, ls1, swap
