Old 02-07-2011, 08:38 PM   #576
85burb
85burb's Avatar
Re: 85 burb meets 6.0 lq4
Originally Posted by harnalien View Post
I've got half the parts bought for mine. Still need a harness, tune and fuel system. I plan on buying those next week. I may be able to start at the end of the month. I'm gonna drop it in place, but let my shop handle the fuel system and wiring. We'll see what happens.
That is about how mine went. Got one part then wait, then next part, then next, tell i was pretty sure i had everthing. Then when i was putting it in i relized what else i needed. Ended up being quite a bit.
82 c10 5.3/4l60
84 c20 5.3/sm465
85 chevy k10 suburban LQ4/4l60
91 chevy c10 suburban Lsa 5.3/4l60
2017 Silverado whipple 5.3
1964 Vw beetle
1974 vw beetle
85burb is offline   Reply With Quote
Old 02-07-2011, 08:46 PM   #577
85burb
85burb's Avatar
Well folks we have a problem. After i have drivin truck a while it smokes out the driver side exhaust pipe. But if i let it idle for a while it clears up. It mostly does it about half way home if i sit at stop light i can see it coming out my pipe. Then when i take off again it kind of fades out but when i got home after doing about 65 mph then going strait to idle it was smoking pretty bad. Then after checking mail and idleing to my spot it was just bearly smoking. If i cold start it in the moring there is no trace of smoke. It does spit water out exhaust when it is cold. Equal on both sides. Only when cold tho. Seems like normal amount of water to me. What could it possibly be? PCV valve is on that side but goes to the carb maniflod port. Could it be a valve stem seal? It does not make any noise that it should not make. No squeking or rattle or knocking. I am not happy at all about this. Hope it is somehow my pcv or something stupid like that. Any ideas?
82 c10 5.3/4l60
84 c20 5.3/sm465
1964 Vw beetle
1974 vw beetle
Old 02-07-2011, 11:27 PM   #578
68GMCCustom
Truck and auto performance nut
68GMCCustom's Avatar
you don't have the passenger side valve cover vented to anything do you? I would try hooking that up to some vacuum, at the filter if possible, if not try and filter it (like a breather/catch can) before tapping manifold vacuum.
Otherwise....it could be valve seals (and guides) but valve seals are usually more of a startup problem. Check all the plugs on that side and see if ones oily wet or black.
Kurt -
'68 GMC short step - NIB '09 LY6 6.0L crate motor w/mods, NIB '12 crate 4L85e w/billet 3k stall Circle D, 3.73 posi 12 bolt, DynaTech f-swap headers, 3/4 drop, handling mods, etc. - my toy
'72 Chevy LWB C-10 Highlander - 350/350 ps/pb/tilt/ac - not original but close
'06 Chevy TrailBlazerSS - LS2/4L70e - little black hot rod SUV - my DD
'18 Kia Sorento - wife's econo-driver
'95 Chevy S10 - reg cab shortbed, LS, 4.3, auto...
my '68's powertrain and chassis build -links broken
A surprise phase - carb to efi -links broken
68GMCCustom is offline   Reply With Quote
Old 02-07-2011, 11:36 PM   #579
85burb
85burb's Avatar
I have the pcv valve on the driver side going to the pcv connection on the carb and the fresh air side is just sitting there. I was going to put it in my filter base but have not had chance. I knew i should have replaced them when i had springs off. But i have never known stem seals to make it smoke when driving but not when starting. I really hope it is the pcv.....
82 c10 5.3/4l60
84 c20 5.3/sm465
1964 Vw beetle
1974 vw beetle
Old 02-07-2011, 11:43 PM   #580
68GMCCustom
I'm surprised your setup came w/o them. When I swapped my cam the spring setup I bought was with new titanium retainers and keepers..plus it had new seals (viton?) which I also installed.
these motors can consume quite a bit of oil if the crankcase ventilation isn't up to par. I think they like neg. vacuum in the engine?
Kurt -
Old 02-08-2011, 12:08 AM   #581
85burb
85burb's Avatar
If i hold my finger over the fresh air side it does not suck. Should it be sucking? It mostly just seeps tiny bits of water droplets out.
82 c10 5.3/4l60
84 c20 5.3/sm465
1964 Vw beetle
1974 vw beetle
Old 02-08-2011, 10:22 PM   #582
85burb
85burb's Avatar
Well i found out what cylinder is causing the smoke it is #1. All other 3 on that bank looked brand new. Dry and white. That is amazing because of the rich exhaust smell it makes. But that is why i ordered a O2 sensor thing. Hope to replace valve seal this weekend and if it fixes the prob i will do all of them. Now that i think of it that may be the reason my vaccum gauge moves 2 notches when it is running. Really am hoping to not have to do any major work to this thing.
82 c10 5.3/4l60
84 c20 5.3/sm465
1964 Vw beetle
1974 vw beetle
Old 02-08-2011, 10:25 PM   #583
85burb
85burb's Avatar
Got most of my ordered parts in mail today. Got my mamoth sized tach. Did not think it was so big.....But i do like the half moon shift light thing. Also got pump cams and nozzel. Still waiting for one more nozzel. Wideband O2 sensor and break cables. Any ideas on where to mount the tach???
82 c10 5.3/4l60
84 c20 5.3/sm465
1964 Vw beetle
1974 vw beetle
Old 02-08-2011, 10:27 PM   #584
85burb
85burb's Avatar
PS if you need a new shaver just order something from summit and they will send you one i guess. Deff did not order that from anyone. Love free stuff....
82 c10 5.3/4l60
84 c20 5.3/sm465
1964 Vw beetle
1974 vw beetle
Old 02-08-2011, 10:44 PM   #585
68GMCCustom
they still sending those things out?
Kurt -
Old 02-08-2011, 10:45 PM   #586
85burb
85burb's Avatar
Yes how long have they ben doing that for. I have needed new shaver for a while
82 c10 5.3/4l60
84 c20 5.3/sm465
1964 Vw beetle
1974 vw beetle
Old 02-08-2011, 10:57 PM   #587
68GMCCustom
since before christmas!
Kurt -
Old 02-09-2011, 12:09 AM   #588
85burb
85burb's Avatar
Wow has it ben that long? That means i have not ordered parts in like 8 weeks or so. Hmmmmmmm
82 c10 5.3/4l60
84 c20 5.3/sm465
1964 Vw beetle
1974 vw beetle
Old 02-09-2011, 01:50 PM   #589
grayharville
^^who I am^^ what I say>
grayharville's Avatar
A buddy of mine ordered a carb and intake the other day, and when we opened the package we were both like, "WTF a razor? Freebie!" lol
70 chevy LWB 350/TH350 Barn find (AKA the 70)
http://www.67-72chevytrucks.com/vboa...d.php?t=406364
East Tx Squares
grayharville is offline   Reply With Quote
Old 02-09-2011, 09:01 PM   #590
85burb
85burb's Avatar
Now i have 2 cause i got my other carb nozzle in mail today. Also got my wideband.....YAY
82 c10 5.3/4l60
84 c20 5.3/sm465
1964 Vw beetle
1974 vw beetle
Old 02-10-2011, 08:28 PM   #591
85burb
85burb's Avatar
Any votes on where to put my new gauges? Was thinking of putting tach up on dash put then i would not be able to put my inspection stickers on easy. Then i was thinking of putting wideband gauge up there and tach below dash. But i dont know. In need of some ideas.
82 c10 5.3/4l60
84 c20 5.3/sm465
1964 Vw beetle
1974 vw beetle
Old 02-10-2011, 09:17 PM   #592
flamingbig10
6.0 powered square
flamingbig10's Avatar
I put some where the a/c control switch and vent were
Aaron
1980 c-10 short bed lowered, cammed 6.0, 4l80e 3600 stall, smp tune, wilwoods, and flames best time so far best et 7.86 @87 on motor 7.57 90 on a 75 shot
Build http://67-72chevytrucks.com/vboard/s...d.php?t=283326
flamingbig10 is offline   Reply With Quote
Old 02-10-2011, 10:33 PM   #593
68GMCCustom
thinking of mounting my extras in one of these on the dash...instead of that expensive dash pad that holds 3 gauges. Guess I'm cheap.
Kurt -
Old 02-10-2011, 10:37 PM   #594
85burb
85burb's Avatar
Those look good. I may mount tach on the side of the dash by the ac stuff. Not really sure never had to mount in a truck like this.
82 c10 5.3/4l60
84 c20 5.3/sm465
1964 Vw beetle
1974 vw beetle
Old 02-10-2011, 10:39 PM   #595
85burb
85burb's Avatar
You sir are deff NOT cheap. Now if you ask my wife she will tell you i am one of the biggest cheap a$$es on earth. She is not happy with my smokey motor. Keeps reminding me of how much it costs and she could have got a new car with the money i have spent on my burb so far.
82 c10 5.3/4l60
84 c20 5.3/sm465
1964 Vw beetle
1974 vw beetle
Old 02-10-2011, 10:55 PM   #596
68GMCCustom
so...what did you figure out on it?
Kurt -
Old 02-10-2011, 11:03 PM   #597
85burb
85burb's Avatar
I am hoping for a valve stem seal. Will change it this weekend. That would go with my flickering vaccum gauge if i remember school right. If it is not that then it has to be rings. I have not came up with answer on what i am going to do if it does not stop after i put stem seal in... Pull hole motor and rebuild hole thing and put old motor back in or pull head and pan and do just rings. Stem seal better fix the smoke or i may just throw hole engine in trash....
82 c10 5.3/4l60
84 c20 5.3/sm465
1964 Vw beetle
1974 vw beetle
Old 02-11-2011, 12:08 PM   #598
MTCK
MTCK's Avatar
Hope it is the easy fix... Too bad you have a column shift - you definitely want both of those gauges where you can see them easily while driving. I guess top left of the dash is my vote for the tach, maybe pillar for the A/F.
-Marcus
1991 V3500 L29 454 4L80E NP205 D60/14 Bolt 4.56's
1984 K30 292 TH400 NP205 D60/14 Bolt 4.56's flat bed 7'6" Meyer Plow
2022 Silverado 3500 L8T
Project Daily Driver
Project Heavy Hauler
Project Plow Truck
MTCK is offline   Reply With Quote
Old 02-11-2011, 02:11 PM   #599
jhln8c
I think you should put the tach on the left side dash, Mine doesnt get in my way when driving and it is very easy to see
Jason
1985 Chevrolet K10
LQ4 swap under way
jhln8c is offline   Reply With Quote
Old 02-11-2011, 10:13 PM   #600
85burb
85burb's Avatar
Thanks for the ideas. I hope to install the valve seals in the morning. Hope it fixes it. I dont think i can tell yall how much i dont want to pull the head or the motor. Dont really have the money for that and i need to drive it everyday.
82 c10 5.3/4l60
84 c20 5.3/sm465
1964 Vw beetle
1974 vw beetle
