Old 03-27-2013, 10:56 PM   #576
longbed67
longbed67's Avatar
Re: Project: Turbo 250
the stout will be good in a couple months right now its a little bitter.
Adam
My 1967 C10 - Turbo 250 Build Thread
http://67-72chevytrucks.com/vboard/s...d.php?t=485843
(608) 214-8706
longbed67 is offline   Reply With Quote
Old 03-31-2013, 09:59 PM   #577
longbed67
longbed67's Avatar
Well 6.5 hours later I have the exhaust 75% finished. I still have to add in the wastegate and the O2 sensor bung, and extend the pipe to the correct length behind the muffler. But the hard part is done now.
Adam
(608) 214-8706
Old 04-02-2013, 04:09 PM   #578
NewType72
NewType72's Avatar
That's pretty sweet looking looks a bit off by itself of course but we get the gist of it
Project NewType 1972 Chevy C/10 Cheyenne Super ( Daily Driven Showtruck ) http://67-72chevytrucks.com/vboard/s...d.php?t=507903
Project Great Grandpa's Legacy 1973 Chevy C/10 Cheyenne ( Current daily driver collecting big time parts ) http://67-72chevytrucks.com/vboard/s...89#post7084289
- Dylan
(209)-985-7721
NewType72 is offline   Reply With Quote
Old 04-11-2013, 07:22 PM   #579
longbed67
longbed67's Avatar
Thought I would update the build thread. I finished up the exhaust just am waiting for one wastegate flange to finish bolting in the dump pipe. I tied up a lot of loose ends with the wiring under the hood and it is just about ready to fire up. Which doesnt do me much good unless this weather warms up and I can get the bodywork done. And I am still waiting for my plates back from the WI DMV. The turbo heat shield is a Titanium by DEI and the downpipe is wrapped with DEI Titanium Header wrap. The O2 bung is where my Innovate LC-1 will go for getting the carb dialed in. Oh yeah I got in some sweet chome powder coated hood hinges and hood catch that I got from another member here on the forum! You can see part of one in the top pic
Adam
(608) 214-8706
Old 04-11-2013, 07:31 PM   #580
longbed67
longbed67's Avatar
A little setback happened the other night... after getting the new trunion installed on the top case for the shifter, When sliding the shifter back into the top case, the top case busted out... sooo that means I will be back to gutting the interior again pulling the high hump back out pulling the top case of the transmission and installing the new top case which should be here mid to late next week.
Adam
(608) 214-8706
Old 04-11-2013, 08:03 PM   #581
longbed67
longbed67's Avatar
I was thinking about using Marine grade plywood for the wood bed and bolting in a sheet of polished Aluminum Diamond Plate 1/8" over top of the plywood for looks and strength as I will be using this truck when I am done.... Any thoughts on this????
Adam
(608) 214-8706
Old 04-11-2013, 08:59 PM   #582
cAlvis165
cAlvis165's Avatar
Beware that the salt and chemical content in treated/Marine plywood may corrode the aluminum plate quickly. I tried to wrap some treated wood with the aluminum stock and it rusted through in just over a year. I was using a very thin trim stock (like flashing metal from your local home-improvement store) so thicker material would last much longer.
Having said that, I know that the marine world uses aluminum trim on pontoon boats with marine plywood all the time. So maybe it's not a problem... Just something you may want to check into.
Oh by the way, I love the way the engine bay is coming together. Also, diamond plate in the bed would l00k awesome!
Success is not final, failure is not fatal: it is the courage to continue that counts. Winston Churchill
DD 2000 Chevy Suburban 4x4/5.3 Vortec/4L60E/4:10s, 18" Escalade rims, Electric fans
Project Dooley One-Ton 4x4 on 38.5s Corn-binder build
cAlvis165 is offline   Reply With Quote
Old 04-11-2013, 09:05 PM   #583
longbed67
longbed67's Avatar
Clavis 165- Thank you... I just need to tidy up the engine bay a bit too it seems busy! If your refering to Green treat plywood that is commonly available at home improvement stores, that is completely different than Marine grade plywood.... The chemicals in Greentreated will eat through just about every metal except for stainless. I would finish the marine grade in Spar Varnish so the metal wouldnt be touching the plywood either way, but thank you again for the input!
Adam
(608) 214-8706
Old 04-11-2013, 09:15 PM   #584
cAlvis165
cAlvis165's Avatar
I figured you knew all that (bein' a doctor and all. :-) Just wanted to make sure. Like I said, I think it would look great and be functional as well. Keep up the good work!
Chad
Old 04-12-2013, 08:00 AM   #585
longbed67
longbed67's Avatar
Chad
Just because you are a doctor does not mean you know a lot! I had a lot of classmates who were complete air heads! Its actually a little scary some of the people out there who are licensed who are book smart but not much else.... And Thanks again Chad!
Adam
(608) 214-8706
Old 04-12-2013, 11:12 AM   #586
67cheby
67cheby
67cheby's Avatar
looking great man ! sorry about the trans issue
67cheby is offline   Reply With Quote
Old 04-12-2013, 06:22 PM   #587
longbed67
longbed67's Avatar
Minor complication...I just hope I dont have further complications.... As I recall Mike you have had your fair share of trans issues!!
Adam
(608) 214-8706
Old 04-14-2013, 09:59 AM   #588
FRENCHBLUE72
PROJECT 7DEUCE
FRENCHBLUE72's Avatar
Its been awhile since I checked in looks like you have made huge gains...
GO BIG GREEN GO DUCKS
MEMBER #6377
Project "7DEUCE"
Old 04-14-2013, 09:11 PM   #589
longbed67
longbed67's Avatar
Well got a lot of little stuff wrapped up this weekend...Buttoned up all of the little bolts up front, got the meth injection tubing secured drivers side engine bay wiring harness finished up, the front splash apron on, in the back I got a whole bunch done as well. I took out the oem shock tower crossmember and got my gooseneck hitch cut to size and set in place I also built some shock mounts and figured out a mounting system behind the axle outside the frame rail that still uses the factory sized shocks and has full travel from the axle touching the frame rail to past my full bag height! I also secured all of the brake lines properly so they do not get pinched like it looks like in the shock picture. And I do have new shocks, I just used the old ones to mock up with
Adam
(608) 214-8706
Old 04-15-2013, 12:31 AM   #590
NewType72
NewType72's Avatar
Gooseneck what?!? Gotta love the little touch up stuff when putting a truck together
- Dylan
(209)-985-7721
Old 04-15-2013, 07:10 AM   #591
longbed67
longbed67's Avatar
It's been in the works since day 1 but I wasnt sure how to exactly integrate it until now!
Adam
(608) 214-8706
Old 04-15-2013, 09:30 AM   #592
67cheby
67cheby
67cheby's Avatar
...WOW...didn't see that coming ! LOL
Old 04-15-2013, 10:16 AM   #593
jlsanborn
jlsanborn's Avatar
Looking good dude! The hitch looks hella stout. What are you going to be draggin around with the truck?
'77 K30 3+3 - "The Crummy"
http://67-72chevytrucks.com/vboard/s...d.php?t=640134
'67 C10 L/SWB - Soon to be daily driver!
http://67-72chevytrucks.com/vboard/s...d.php?t=471776
jlsanborn is offline   Reply With Quote
Old 04-15-2013, 08:33 PM   #594
longbed67
longbed67's Avatar
Thanks guys! I Like to throw a few curve balls here and there Definitely a flatbed trailer possibly with another show worthy vehicle Have a few plans for a tilt bed trailer with air ride and will have air hook ups for an auto leveling system.
Adam
(608) 214-8706
Old 04-15-2013, 09:44 PM   #595
jlsanborn
jlsanborn's Avatar
On the mobile here, so without looking back what kind of hp/torque are you looking to make?
Old 04-15-2013, 11:44 PM   #596
longbed67
longbed67's Avatar
At a conservative 8lbs of boost, I am expecting around 450 hp and 510 ftlbs torque.
Adam
(608) 214-8706
Old 04-29-2013, 08:16 PM   #597
longbed67
longbed67's Avatar
Shot some more paint today! Finally the weather was nice enough!
Adam
(608) 214-8706
Old 04-29-2013, 09:38 PM   #598
cAlvis165
cAlvis165's Avatar
Oh yeah!
Old 04-29-2013, 10:20 PM   #599
mjensen
mjensen's Avatar
Looking good!
Mike
'69 GMC 3/4 ton 4x4 Build Thread
mjensen is offline   Reply With Quote
Old 04-29-2013, 10:33 PM   #600
Benlugchev
Benlugchev's Avatar
Very nice. looks like its going to be a fun truck
71' Chevy C10-Turbo 6.0L-80e-JFR218-738hp/700tq-10.1@133mph... 1.54 60' (3737lbs)
00' GMC-c2500-Turbo 6.0L-80e-JFR212-500hp/560tq -11.67@116mph (5182lbs)
Benlugchev is offline   Reply With Quote
