#576 |
Re: Project Roxy
Whew.. Glad I saved those coil spring bumper brackets.. Now just have to clean 30-40 years worth of New England under coating off them..
///Relaxed Atmosphere |
#577 |
Re: Project Roxy
#578 |
Re: Project Roxy
Nothing crappy about that pic sir!
69 C10 SWB -- Left to me by a loving father. Finishing the build we never got the chance to do together |
#579 |
Re: Project Roxy
Looks awesome
Scott 67 c10 sold 89 c1500 90 k2500 91 s10 #chevyonly ![]() |
#580 |
Re: Project Roxy
Tailgate and bumper look great!
-Duane C/10 Club Texas member 1971 Chevy C10 "Brutus" SWB Fleetside 2016 6.0L (L96) 6L90E (driver/project) 1965 Pontiac GTO "Royal Goat" 400/TH400 w/AC (my baby) |
#581 |
![]() Join Date: Dec 2006
Re: Project Roxy
Very nice
Keith 66 Suburban Burb Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=751361 IG: bennett68c10 |
#582 |
Re: Project Roxy
Thinking about fuel lines. Does anyone see a problem running braided stainless steel line with -AN fittings from the sending unit (tank still in the cab) to the fuel pump (mechanical pump) . Then from the pump to the carb. There is be two filters in there also, before and after the pump.
#583 |
Re: Project Roxy
I don't see a problem with it. However, it's just like running rubber hose, but it has an outer armor on it. Meaning: You'll have to change them out as a disposable part once in a while. And it's a lot harder to see the hose fatigue over time because of the braid.
I'm currently running nylon braided fuel line from the tank to the carb (obviously with filters and pump in between). It works fine and looks good, but it's still only temporary.
#584 | |
Re: Project Roxy
That being said, I'm going to need to practice bending metal lines for the brakes anyway, So I should consider bending them for the fuel lines, also.
#585 |
Re: Project Roxy
#586 |
Re: Project Roxy
I know, right.. and I didn't have to sandblast it!
#587 |
Re: Project Roxy
#588 |
Re: Project Roxy
Sounds good to me.. Just have to learn how to bend it.
#589 |
Re: Project Roxy
the before and after pic is awesome...
#590 |
![]() Join Date: Nov 2008
Re: Project Roxy
Looks awesome
#591 |
Re: Project Roxy
#592 |
Re: Project Roxy
#593 |
Re: Project Roxy
Just went through this whole build. Wow, the end result is killer!
#594 |
Re: Project Roxy
Thank you
#595 |
Re: Project Roxy
#596 | |
Re: Project Roxy
#597 |
Re: Project Roxy
The piece was already flared. But I figured I try bending a scrap piece just to see how it went
#598 |
Re: Project Roxy
61 Ford uni ![]() ryans 77 c10 http://67-72chevytrucks.com/vboard/s...d.php?t=626594 |
#599 |
Re: Project Roxy
#600 |
Re: Project Roxy
Guy running Dropmembers and disks in the front ( I have CPP 13" rotors in the front). What are you using for brake hose kits from the caliper to the frame? (size, length, etc) CPP has a 7/6" and a 10mm stainless braided kit, but was wondering if I should get the 12" or 14" length.
///Relaxed Atmosphere Last edited by Rochlow; 10-01-2014 at 06:01 PM. |
