12-23-2015, 02:38 PM | #576 |
Re: 1976 Square "Simple Green"
How come you don't run it? Struggling with this myself. They suggested it would run better with than without.
Posted via Mobile Device |
12-23-2015, 02:43 PM | #577 |
12-23-2015, 02:50 PM | #578 |
Makes sense.
12-23-2015, 06:10 PM | #579 |
Walbro 400
12-23-2015, 06:10 PM | #580 |
Pump
12-23-2015, 06:53 PM | #581 |
Did you find anything out on the rubber isolation piece that goes @ the bottom of the pump (post 561)?
12-23-2015, 07:46 PM | #582 |
Never found one I could buy. Only ones I found came with a pump. But I won't need it with the Walbro the bottom part as you can see in the pic above the fat part. Well it sits perfect in the cradle that holds the pump. I will post some pics up so everyone can see.
12-23-2015, 08:11 PM | #583 |
Pump sitting cradle. Fits perfect.
12-23-2015, 08:13 PM | #584 |
Now these pumps have purge holes in the base. So for the pump to work correctly and so it can purge. I drilled a hole in the cradle under the purge holes. It makes it nice to have a extra sender to mach stuff up on. Got luck on the first try. It will make drilling the hole on the sender I will use easy.
12-24-2015, 09:42 AM | #585 |
Ray here.
I'm not a chev. truck owner but I do have the Fitech power adder setup on my 408C mustang...works very nice! What am trying to find out is if anybody has got the laptop tuning to work? Tech has been less than helpful on this... Ray. |
12-24-2015, 09:51 AM | #586 |
Hey Ray. I am wanting the laptop tuning also. But I have not had time to ask them or even look into that feature yet. Do you have it setup to use like that now. Or are you trying to get the software from them. We will need some software for tuning. For my other toys I have the SCT software I can tune with. As long as you got the money SCT does not care they will let you have it. I did read the FAQ on FiTech website does not look like they want weekend worriers trying to blow up vehicle when some people can't change a spark plug lol. Not saying you or I do not know by you know how some people are. Nice to see someone else on a different application is enjoying the FiTech like myself and others.
12-24-2015, 10:11 AM | #587 |
I will say that the way you read the data logs on the FiTech is less than desirable. They just use excel. I want to look at a graph that I can scroll and zoom in on things. But you can use the excel just not as nice and clean cut IMO. I guess I am spoiled using SCT for so long and they are the industry standard IMO. But with saying that most people will just put it on and drive it and never worry or look at a data log.
12-24-2015, 10:45 AM | #588 |
Ray here.
The laptop stuff has 2-D.and 3-D graphs with tracking and more tuning than than most people will ever need. my problem is getting it to talk to the car.. Ray. |
12-24-2015, 10:59 AM | #589 |
O yes I know what I will be doing this weekend. I will let you know if I get it to work!! And Ray that must be a old lap top how long of a extension cord does that use lol. Just messing with you.
12-24-2015, 11:15 AM | #590 |
What steps or instructions has FiTech told you?
12-24-2015, 11:44 AM | #591 |
Ray here.
That's one of my big stand up things..(easy to photo) I have tried two laptops and two desktops and two different controllers. I feel am just missing something simple.. Fitech help line has been very very good up till now... For those who my care. 1.Using the timing control with a self modified MSD ready to run(3wire to 2wire) 2. Fuel commander for fuel. 3. After 3 new carbs-750-950-1050- the motor has never run better... The Fitech is an 850 by size...I'm thinking it flows way more than that.. If someone gets the software working let me know... Ray. Somehow am thinking I my have drifted this tread....sorry |
12-24-2015, 11:52 AM | #592 | |
12-24-2015, 12:00 PM | #593 |
Also my fuel hat upgrade wiring kit will be in today!!
12-24-2015, 12:59 PM | #594 | |
By the way, nice truck.
"In an insane world a sane man must appear insane" ~Spock~ |
12-24-2015, 01:12 PM | #595 | |
Using the relay,will reduce the current going through the 6 pin connector on the system. Also the pump would always have the voltage it needs. The PWM part is just a voltage reduction on the signal coming from the ECU, so as long as it's enough to turn the relay on, the relay will supply full voltage to the pump. The PWM by the time it gets through the relay, and the output has a super-fast PWM frequency that shows up as a constant voltage by the time it gets out of the ECU. The ECU is just turning the relay ON with this signal, and the pump is getting full voltage. On the ECU, the PWM only works when at low throttle and low RPM, and puts out about 10 volts. Above that, it switches over to the internal relay, and gets direct battery voltage and no more PWM. It's just a pump quieting scheme, and not a pressure control thing. Now everyone knows how the PWM on the FiTech works lol. I run the relay and it is not causing a issue and it is staying. And thanks I appreciate that. I like my truck also. Last edited by RodsGreen10; 12-24-2015 at 01:23 PM. |
12-24-2015, 01:54 PM | #596 |
Ray here.
At the risk of drifting this tread more. The computer guy at Fitech has been on holiday for a week or two. Till Monday or so. So help on software has been limited at best.. My problem is down loading the KlineDriver_AAFF_FFAA folder. Really its just finding it...... (this lets the two talk) Ray. The timing control really is nice if you can do it. Not opening the hood to adj. fuel or timing on that 90+deg.day after getting a tank of crap fuel while sporting your best girl..Priceless..... |
12-24-2015, 02:03 PM | #597 | |
12-24-2015, 02:34 PM | #598 |
Thanks, your info is very helpful. Because of my buddy's problem with the Bronco I have already decided to use a relay for the fuel pump and your info tells me that is the right decision.
Thanks again, Ronnie
12-24-2015, 02:49 PM | #599 |
12-24-2015, 03:58 PM | #600 |
Fuel hat rewire kit showed up! Nice day to work on stuff 74 degrees out side haha. Love it.
