Old 11-20-2017, 12:07 PM   #576
evilokc
Re: What did you do with your truck today, Part 3
Friday i drove 15 miles. it wasn't great but it drove. yesterday i tried to pull it out of the garage and it didn't want to idle. tried over and over until finally the rear float started overflowing. I'm so sick of this carb. ive run carbs before and never had issues like this with the edelbrocks. its one thing after the other and when i fix something it seems to unfix itself. i don't even know what my next step should be. I'm annoyed and frustrated.
evilokc is offline   Reply With Quote
Old 11-20-2017, 01:26 PM   #577
robertsjm711
robertsjm711's Avatar
Could it be something other than the carb, like an intake leak, timing, ignition module? Would you or a buddy have another carb to put on to make sure it is the carb?
I had a quadra-junk on an old Chevy back in the day and it had a vacuum leak at the throttle body primary shaft - it was a non-replacable bushing that turned it into a boat anchor. I spent days and weeks, rebuilding, gaskets, chasing rabbits down dark, evil holes. I know that pain and hate to see others go through it.
"Once you eliminate the impossible, whatever remains, no matter how improbable, must be the truth." - Arthur Conan Doyle
It was said that if you cut off one hydra head, two more grow back.
-Lernaean Hydra
Build Thread:
http://67-72chevytrucks.com/vboard/s...d.php?t=743246
robertsjm711 is offline   Reply With Quote
Old 11-21-2017, 12:40 AM   #578
mud.man.rj
mud.man.rj's Avatar
I run Edelbrocks year round on all trucks, lowered and lifted, small or big block, no problems...ever, every project I build for others, to many to count Edelbrock, no come backs, but 1/4 mile or straight mud racing I do get a "bit" more performance out of a Holley but still act up more often.
Mudman.
1987 Green n Green machine.
5.0 4spd std.
7" lift w 35's.
mud.man.rj is offline   Reply With Quote
Old 11-21-2017, 11:10 AM   #579
vintovka
vintovka's Avatar
Sorry to say my last 2 Edelbrock carbs were defective garbage. First one would not tune due to internal issues and last one had a vacuum leak only a spacer block and 2 thick gaskets would cure. These were brand new and installed on a brand new Edelbrock intake. I spoke to several Edelbrock reps several times. Some were flat rude and others listened but IMHO did not care. Cost us $100's in shop costs ( i have the bills) and weeks of delay and frustration. Think they have have quality control issues. Seems like even old reliable name brand (like Maytag and Craftsman) has gone to hell lately so keep your receipts handy and expect the worst.
vintovka is offline   Reply With Quote
Old 11-21-2017, 12:06 PM   #580
gigamanx
Mudman.
I'm of the same mindset that maybe its the carb that is the issue. My edelbrock 1406 came out of the box stock and with a couple of idle adjustments to the outside screws, it runs and operates normally. I have 4.5psi of fuel pressure. If you lived closer, I'd pull mine off just so you could throw it on and test it out. It's an expensive trial and error thing to do without another car guy that can loan you a carb.
Current Build Thread 1930 Ford Model A Modern Twist: Ford Model A Rat Rod With a Modern Twist
Build Thread Phase 1 "The Swap": 1949 3100 with S10 swap. Beginner build with ambition!
Build Thread Phase 2 "The Drop": Beginner Build with Ambition gets Air Ride
gigamanx is offline   Reply With Quote
Old 11-21-2017, 06:54 PM   #581
robertsjm711
Pulled motor & dropped pan to make sure it is a 5.3 vs a 4.8... and it is a 5.3!!!
Got it used from private party saying it was a 5.3, but after cleaning I found a 4.8 stamped on the tab on the head gasket, and injectors for a flex fuel.
All is good!!!
-Lernaean Hydra
Build Thread:
Old 11-21-2017, 09:28 PM   #582
Black_Sheep
Black_Sheep's Avatar
Getting stuff wired up...
Black_Sheep is offline   Reply With Quote
Old 11-21-2017, 10:22 PM   #583
Russell Ashley
Russell Ashley's Avatar
All is good!!!
The 5.3 in my 02 Suburban is a flex-fuel engine. Were you thinking the injectors were not from a 5.3?
Russell Ashley is offline   Reply With Quote
Old 11-21-2017, 10:45 PM   #584
robertsjm711
Oh, yes, that probably didn’t make any sense. The guy told me it was a 2001 5.3 non-flex, and 5.3 flex didn’t come out till 2002-2003 (depending on where you look), which made it confusing on what it actually was, and with a “4.8” stamped on the head gasket tab made me think twice (or three times...)
Overall I now am confident it is a 2002 flex 5.3 - injectors, crank/piston/rod casting, and non-DBW throttle body all say 5.3.
-Lernaean Hydra
Build Thread:
Old 11-22-2017, 05:55 AM   #585
MiraclePieCo
MiraclePieCo's Avatar
Threw some primer on my newly-filled firewall.
MiraclePieCo is offline   Reply With Quote
Old 11-23-2017, 12:50 AM   #586
robertsjm711
De-Swiss cheesing the firewall. Won’t look as sweet as the guy above, but I won’t get as wet from the rain.
-Lernaean Hydra
Build Thread:
Old 11-23-2017, 03:35 AM   #587
MiraclePieCo
;-) Winter is coming - those holes will let a lot of heat in the cab to keep you warm!
I've been watching your build and wanted ask you what you have found is the best procedure for installing your front sheet metal - assemble on the ground first, or one piece at a time? What's the best order? Thanks!
Old 11-23-2017, 12:16 PM   #588
robertsjm711
Well, a little of both. If I have help available, I remove it as a clip, radiator and all. I kept this in mint when creating the wiring harness so I can just move it aside. I can get it off by myself but need someone to get it back on. It is not exactly "show ready", so if I am not too concerned if I scrap the bottom on the ground. If alone, I'll remove piece by piece by piece.
When fitting for the first time, I set up everything loose and used stands to get the alignment right and figured out how they would mount. It seems every time I add something this changes a bit, but it is a process.
-Lernaean Hydra
Build Thread:
Old 11-24-2017, 06:53 PM   #589
Black_Sheep
Still wrapping up some wiring but it starts and runs again. I brought the truck up to temp to burp the air pockets out of the cooling system...
https://www.facebook.com/25349890836...9675440418896/
Old 11-26-2017, 04:26 PM   #590
Moeller
Continued to clean down my frame (1953), dirty work.....
Moeller is offline   Reply With Quote
Old 11-27-2017, 05:04 AM   #591
MiraclePieCo
Attachment 1711385
Looks like you're well-equipped. Welcome to the forum, and keep us posted on your progress.
Old 11-27-2017, 08:32 PM   #592
gigamanx
A whole 7 days...Got it resolved?
Old 11-29-2017, 01:30 PM   #593
dsraven
anybody with LS questions, check this out.
http://www.pirate4x4.com/tech/billav...SPrimer/Part1/
the site also has some tech tips on other stuff as well, fabbing, suspension etc. some good reads if you have time.
Old 12-01-2017, 12:56 AM   #594
59GMCApache
59GMCApache's Avatar
I got my moser 9 in tack welded in.
59GMCApache is offline   Reply With Quote
Old 12-01-2017, 09:16 AM   #595
evilokc
haven't touched it in over a week. had family in town for the holiday. hoping to break it worse...I mean fix it this weekend.
Old 12-02-2017, 07:35 PM   #596
Russell Ashley
Put about 60 miles on it today, most I've driven it all year. Got lots of good comments and thumbs up.
Old 12-03-2017, 12:49 AM   #597
evilokc
since I cant get the piece of crap to run well enough to take it to the body shop to have the fender fixed I removed the fender so it can be taken to the body shop. hope they will get it straighten out. I have been doing some custom work to my motorcycle while steeping away from the tuck. I'm forming a plan though.
Old 12-03-2017, 04:04 AM   #598
MiraclePieCo
Count one more thumb up from me!
Old 12-03-2017, 06:25 PM   #599
ItsJustMoney
Got my repop fender burned in. It takes a lot of time and a bit of tweaking to get the gaps just right. Sorry trying to figure out how to flip the pics.
ItsJustMoney is offline   Reply With Quote
Old 12-03-2017, 10:58 PM   #600
svr
svr's Avatar
Declared mockup done and blew it all back apart to finish the welding on the frame and get some paint on it. Back to frame and running gear on jack stands again. Am sure i missed something during the mockup. And gave the shop a good sweeping and straightened up the place so maybe i can find everything again.
57 short box, 235, T5, C4
http://67-72chevytrucks.com/vboard/s...d.php?t=739132
svr is offline   Reply With Quote
