05-14-2020, 12:10 AM | #576 |
Post Whore
Re: A '54 named Busty
I love a clean canvas
05-14-2020, 12:11 AM | #577 |
Post Whore
I even cut off these nipples
05-14-2020, 12:16 AM | #578 |
Post Whore
who knew the Swiss made the firewall
05-14-2020, 12:18 AM | #579 |
Post Whore
so first we cleaned up around the edges for our weldingers to have a nice clean surface to stick to
05-14-2020, 12:21 AM | #580 |
Post Whore
then we cut out a circle and used the three Magnateers to hold it from the back
05-14-2020, 12:25 AM | #581 |
Post Whore
and then as if on que (and this never ever happens) this little guy decided to show up
I shall call him The Profanity Eliminator |
05-14-2020, 12:28 AM | #582 |
Post Whore
little guy proved useful on the 3/8th and smaller holes fer sure
05-14-2020, 12:30 AM | #583 |
Post Whore
meanwhile back in our hole plug facility...
05-14-2020, 12:31 AM | #584 |
Post Whore
... and then Abe Lincoln decided he had enuff welding for one day! [again]
05-14-2020, 12:41 AM | #585 |
Post Whore
but we wasn't done just yet, oh no, it was time to do the Native American Rain Dance!
and oh boy did it work, half a can or spray paint later, it was pouring outside |
05-14-2020, 12:43 AM | #586 |
Post Whore
but we got what we wanted primered, so there
05-14-2020, 08:40 AM | #587 |
Moving right along...Jim
my build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=459839 Jimbo's long bed step build:http://67-72chevytrucks.com/vboard/s...t=464626<br /> |
05-14-2020, 09:56 AM | #588 |
Post Whore
Thanks Jim, any tips on fixing / replacing a rusty driver side kick panel, I have a nasty 12" rusted out gash diagonally across it, I will try to snap a pic of it, odd why it's there, I could see such damage around the heater core but this is on the opposite side?
05-14-2020, 11:37 AM | #589 |
Looks handy.
05-14-2020, 11:38 AM | #590 |
Good progress man! Kinda cool the old switch with the breaker.
05-14-2020, 12:06 PM | #591 |
Post Whore
05-14-2020, 12:07 PM | #592 |
Post Whore
05-14-2020, 12:09 PM | #593 |
you may be able to fit a larger spool of wire on your welder, cheaper and less goofing around. I also suggest the little felt wire cleaner that goes over the wire prior to it feeding into the rollers. keeps the dirt out of the cable. some guys use what looks like a cigarette filter as well, something to allow the wire to feed through easily but rub any dust off the wire before it hits the cable liner. you would be surprised how much crap collects in the felt that would normally just wear out the liner on the cable.
05-14-2020, 12:16 PM | #594 | |
Post Whore
05-14-2020, 01:05 PM | #595 |
You'll need the insert for the larger spool, it should have come with the welder. If not, pick one up at the welding supply store.
In one of those first pics, the steering column looks a little low to me. You may have to shorten the seat base. I thought about that little tool, but didn't get one. Since you like it, I'll get one and try it out. Good progress.
8man-aka Robert 1948 on a S10 Frame, small block with a carb 1954 Cab, 53 Front and Bed, 50 Doors, S10 Frame, Power TBD Build thread: "]http://67-72chevytrucks.com/vboard/showthread.php?t=746899&highlight=wife%27s+48[/URL] [/URL]http://67-72chevytrucks.com/vboard/showthread.php?t=840204 |
05-15-2020, 12:08 AM | #596 | ||
Post Whore
Thank you |
05-15-2020, 12:10 AM | #597 |
Post Whore
so the plan for today was simple: Plug the rest of them holes in the firewall!
so... I decided to do something fun instead! |
05-15-2020, 12:15 AM | #598 |
Post Whore
seriously guys I hag to do something cause I could no longer see the floor it was such a mess in there, and oh my god it totally rejuvenated me
and let me tell you getting your rig to be a roller is such a huge milestone even if it means just rolling it back and forth so you don't have to wrench with your back against the wall if you know what I mean |
05-15-2020, 12:18 AM | #599 |
Post Whore
with the garage floor, swept, vacuumed, and mopped it was time for the mandatory stare down, just me in my Man Chair and sum gin and juice
05-15-2020, 12:22 AM | #600 |
Post Whore
then it was back to the grind, and as I prepped the driver side of the firewall and counted all the holes, I thought to myself, is 423 holes in the firewall enough, or is that just the bare minimum?
