#601 |
![]() Join Date: Jun 2009
Re: My 68 swb build.
sorry...had to make it an even 600 replies before i hit the sack...
68 C10 Stepper #1- GONE 68 C10 Stepper #2 1977 Chevy Cheyenne...gone...was my first Chevy 04 Tahoe Z71, 04 Silverado 2500HD, 04 Sierra 2500HD 99 Sierra Stepside, 17 Denali HD, 84 K10 My 1st build-- http://67-72chevytrucks.com/vboard/s...d.php?t=379333 My 2nd build-- http://67-72chevytrucks.com/vboard/s...d.php?t=700310 |
#602 |
The lines are a 100% better. I think you did a great job on the alignment. Congrats on getting it fired up, I know you are excited to be at this point. You are smoking through this build.
71 Ol' Blue: http://67-72chevytrucks.com/vboard/s...d.php?t=474752 Carving the Jake-olantern: http://67-72chevytrucks.com/vboard/s...d.php?t=679537 |
#603 |
It looks really good. Your patience paid off. The nicks in the paint can be fixed easy. Just get it together and have your body guy touch them up.
#604 |
low n' slo
![]() Join Date: Mar 2009
good work on the gaps man, i think they should be good!
67 1/2 ton Suburban - Project DRGNWGN. Build thread ![]() -_--_--_ _________ _--_-_ -/____|__|__\__ ,.,,,.,.,,.,|_O _______ O_] |
#605 |
Thanks bro. I'm takin what jonathon said and let it be.....or at least I will for now the only thing that is really bugging me is the cowl. I have to pull it back off to do the wipers so I got a feeling its gonna piss me off putting it back on. Lol
#606 |
my progress for the day....took the day off of work, had the case of fire down below..lol the front is completely bolted down except for the latch assembly
got my ac hoses back from napa and temp installed
#607 |
#608 |
Looks KILLER Chris...
I sure would like to come see it in person one Sunday afternoon... By the way, do you know the part# for the top radiator hose you are using? That looks like the one I need to run on mine... My build thread is way behind where I am actually at... I'm close to firing mine up soon, too...
To the best of my knowledge there is still not a cure for stupid... And Stupid Hurts... Check out my build: http://67-72chevytrucks.com/vboard/s...d.php?t=427503 |
#609 |
Sofa King Crazy!!
It lives!!!!! Good to hear some notes coming from the exhaust! Hope she runs great from now on.
You found the Tater. ![]() My Blazer Build (New) - http://67-72chevytrucks.com/vboard/s...d.php?t=654650 My 67 Build - http://67-72chevytrucks.com/vboard/s...d.php?t=335650 67 Chevy LWB big window a/c AKA TOTALLED BY A JACKASS. ![]() 1972 2wd Blazer "Porterbuilt and Sloshed" ![]() |
#610 |
VA72C10
![]() Join Date: Mar 2008
Nice progress! Looks great!!!
Looking for a 67-72 swb or blazer project in or around VA. ![]() |
#611 |
![]() Join Date: Dec 2006
Looking really good
Keith 66 Suburban Burb Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=751361 IG: bennett68c10 |
#612 |
Sofa King Crazy!!
I just noticed ya got one of those new invisible proportioning valves at the same store I got my a/c from!!!
#613 | |
#614 |
Thanks guys. !! I'm hoping to have more done this week. All depends how work goes. I think im gonna finish the Windows in the doors next. The hook still hits the division bar. Gonna try to do it with the door on and just remove the hook so I dont have to realignment. Loli dropped my driveshaft off at napa to have them resize it once again. It should be right this time 56" center to center.
#615 | |
#616 | |
#617 |
Sounds good! Congrats on getting it fired up.
1972 GMC (PROJECT LONG OVERDUE) ![]() 1998 SWB 4WD |
#618 | |
Still Learning
#619 |
Sofa King Crazy!!
^ ^^ Excellent advice. Talk to the builder. Also use a zinc additive in your oil ESPECIALLY on break in so you won't have a flat cam.
#620 | ||
Posted via Mobile Device Where do u get the zinc additive and how long do u run it in the motor?
#621 |
on a good note, i got the driveshaft back today...
#622 |
Still Learning
You should do a search on Lucus oil zinc additive then just search for a retailer in your area. HERE
Be careful about running synthetic oil in your engine too unless you have an additive. |
#623 |
I got Lucas brake in oil from my local carquest which came in a 1 quart bottle then I added Rotella oil which I believe is the only oil with zinc. My engine builder said I should run it about 500 miles then change the oil.
#624 |
Sofa King Crazy!!
I got my zinc additive from O'Reilly. It comes in a clear bottle and it says ZINC on it in big red letters. The additive is clear. You should use it everytime you change your oil, which adds another ten bucks to your oil change but if it saves the cam it's worth it!
#625 |
67cheby
![]() Join Date: Sep 2008
looking good !
