09-27-2018, 03:16 PM | #601 |
Re: 67 GMC super custom build
Got my valve covers back. They look awesome. I also had the 67 only handle plates added to the back of my Nos door skins and had the door lock cylinders sunk into the door skin.
09-27-2018, 03:27 PM | #602 |
Wow those valve covers are perfect! Nice work
ANDREW 1972 Chevy SWB Cheyenne Super JANE http://67-72chevytrucks.com/vboard/s...d.php?t=462072 1972 GMC Jimmy PENNY http://67-72chevytrucks.com/vboard/s...d.php?t=735827 1968 GMC patina swb PEARL http://67-72chevytrucks.com/vboard/s...d.php?t=731315 1972 Chevy K20 BRUCE http://67-72chevytrucks.com/vboard/s...d.php?t=805788 1972 Chevy SWB Highlander OLIVE Build thread coming |
09-27-2018, 05:10 PM | #603 |
Beautiful work on those valve covers. And gotta love those handle plates. I just went out and looked at my Burb doors, and the area behind the door handles are all scratched from finger nails. Could use a set of three of those plates. And those locks should have been recessed from the factory.
Bob 1967 2wd Burb, 350/TH350, 3.73 posi |
09-27-2018, 07:56 PM | #604 | |
09-27-2018, 09:28 PM | #605 |
This is awesome! Better add that one to my to do list.
10-04-2018, 07:33 AM | #606 |
Still Learning
Very nice work on the valve covers and door skins! Awesome!
10-04-2018, 11:24 AM | #607 |
Thanks. I am very happy with them. I took out my torque converter from the box yesterday and found a plug on it. Turns out you can have a drain on a torque converter. I have never seen this so I thought I'd share.
10-13-2018, 10:52 AM | #608 |
amazing ........just read thru some of this, glad i found this build thread ....amazing detailed work
Doc & Kim build http://67-72chevytrucks.com/vboard/s...d.php?t=722288 I am from the desert http://67-72chevytrucks.com/vboard/s...d.php?t=650332 basket case build SOLD http://67-72chevytrucks.com/vboard/s...d.php?t=648557 Last edited by zicc1835; 10-13-2018 at 10:53 AM. Reason: more info |
11-23-2018, 01:53 PM | #609 |
I liked the valve covers so much that I added script from a th400 deep pan to my original 67 pan and added a drain and a spot for my temperature sending unit.
12-15-2018, 03:13 PM | #610 |
Got the transmission pan powder coated. Also got my cloyes cover for roller cam. I have to put 1/8"spacers in behind my water pump to make it work. Hopefully soon I'll get the engine to the machine shop.
12-15-2018, 06:54 PM | #611 |
Active Member
Looking good !!!!!
12-30-2018, 11:21 PM | #612 |
This is how I decided to run my power seat and heated seat harness. I may run my done lights and fuel gauge here too. It's a flat ribbon body harness from a 66 pontiac. I just shortened it to the length I needed it to be. Goes under the rug. Slick and smooth. I'll weld some tabs on the floor when it's finished to help hold this flat and out of damages way.
12-31-2018, 05:25 PM | #613 |
Is that timing cover a vintage part??? or something currently available???
12-31-2018, 09:12 PM | #614 |
It's new. Allows you to run a modern roller cam easier in a pre 86 small block. One Thing I wanted modern was a roller cam so I don't have to worry about oil zinc and you can't really notice this cover with the short water pump on. Here is a link. https://www.ebay.com/itm/SBC-327-283...gAAOSwKM9Zt~h9
01-13-2019, 10:44 PM | #615 |
Started painting the engine pieces! I love a shiny orange engine.
01-28-2019, 12:27 PM | #616 |
Some of the small pieces!
01-28-2019, 12:57 PM | #617 |
Looking good! When are you getting the machine work done?
01-28-2019, 03:44 PM | #618 |
It's almost done. Then I can get the block painted and install the drivetrain. Can't wait
01-28-2019, 04:10 PM | #619 |
Awesome! I'm excited to see it come together! ..... Finally
01-28-2019, 07:12 PM | #620 |
I could not stop reading this thread after I opened it this afternoon for the first time. From '71 to '73 I was a make-ready man in a Chevrolet dealership. I installed many of the factory accessories you've found (or, I should say I've installed some of those accessories many times!). It brought back many memories. There was a couple of big bins in the parts department full of those GM accessories. If I remember correctly, the 8-track players were called "multiplex" on the box. Fond memories of simpler times! I wish I had a dollar for every dealer-imprinted rear step bumper I hung, mostly by myself, back on the concrete, holding one end up with my foot and the other up with one hand, while I stabbed two bolts with the other hand!
02-03-2019, 06:56 PM | #621 |
Now that my small pieces are dry I wanted to replicate what gm did with the plug Wire holders. I bought a small can of plasti-dip. Turned out perfect. I touched up my Nos engine and trans mounts as well. Just where gm left the metal raw when they manufactured them though. Made sure not to cover up part numbers. When it dries it's a perfect match to the rubber.
02-05-2019, 05:48 PM | #622 |
I finished off the lid on my air cleaner. It kind of has 2 lids now. What I did was I added a lid from a 65 ambassador to the inner part of My air cleaner. It sits perfect with the bumps on the lid of my oil bath lid to hold it down. Now the oil bath lid is really just for show and you will never tell there is a paper cartridge in it. And it uses the exact same size filter a 67 would have used with a factory paper filter. And if I have low air intake I can drive it without the oil lid on and use it just for show.
02-08-2019, 01:12 PM | #623 |
Got my decals back from the shop and been working on my transmission temp gauge. This is how it will look. I wish the colors could be closer to the original gauge color. I will keep looking for a shop who can get a better color but otherwise it looks ok. I also changed my temp light ( only used for dummy lights) to a tow light. If i turn off the variable pitch converter the tow light will come on and I won't burn out the transmission.
02-08-2019, 05:36 PM | #624 |
Here is how the back looks. It doesn't mess with the printed circuit and it uses an independent harness just like the electric tachometer does.
02-08-2019, 09:54 PM | #625 |
Complete
