Old 11-30-2005, 06:50 PM   #601
fastbagged68
fastbagged68's Avatar
Re: Crossmember Drop
Check out www.nolimit.net. That is where I got my motor mounts from.
fastbagged68 is offline   Reply With Quote
Old 12-01-2005, 01:50 AM   #602
dwcsr
Hollister Road Co.
dwcsr's Avatar
I see from the posts that some are using MII and some TBird racks. What are you using for tie rod ends that will fit the stock spindle? From my searching an MII is shorter than a Tbird are you cutting the rack?
dwcsr is offline   Reply With Quote
Old 12-01-2005, 01:42 PM   #603
fastbagged68
Using stock tie rod ends. I cut down my T-bird Rack and made adapters to make my tie rods work.
Old 12-01-2005, 02:21 PM   #604
dwcsr
Hollister Road Co.
dwcsr's Avatar
fastbagged68,
Did you make an adjuster or something else? Do you have a pic you can post?
I'm at the point on mine that I want to finish the front suspension and I am at the steering box. I need to replace the box so I thought I might just use a rack. The cost for a rack is less than a quick ratio Saginaw box and the project is very interesting but the rod ends are the stopper. I didn't want to use heim joints as some have done. So if I can use the stock ends with a modified adjuster it should work out ok.
I have to say I've been pretty impressed with what you guys have done with this modification and the way this thread has evolved from an idea into How-to. It makes it nice when I can read a thread and get everything I need to know to do the project and who not to buy the parts from and what not to do.
Good Job All
Old 12-01-2005, 02:38 PM   #605
fastbagged68
Took some solid stock and made an adjuster... tapped one end to fit rack the other end to fit tie-rod end...
Old 12-01-2005, 10:22 PM   #606
dwcsr
Hollister Road Co.
dwcsr's Avatar
That sounds easy enough, I think I'll go with a rack from a Tbird.
Old 12-05-2005, 12:43 AM   #607
FRENCHBLUE72
PROJECT 7DEUCE
FRENCHBLUE72's Avatar
Crap there is some good info on this thread.... I don't think I have anymore questions reguarding a crossmember drop ....
GO BIG GREEN GO DUCKS
MEMBER #6377
Project "7DEUCE"
Old 12-13-2005, 11:48 PM   #608
wdz28ss
wdz28ss's Avatar
Wow, surprised to see this thread is still active.....damn that was a long time ago....looks like fastbagged stuck it out...congrats! My hat is off to ya!
'72 Cheyenne super, short-fleet, air-tilt-tach, fuel injected LT1, 700r4, 3.08 posi, 4WDB, step notched and bagged. "the one i wish i still had"
wdz28ss is offline   Reply With Quote
Old 11-07-2006, 02:37 AM   #609
camaro__thunder
Epoxy Primer Friendly
camaro__thunder's Avatar
a tribute to the longest thread ever lol !! MEMORIES....
My Project 69 SWB
SHAVED BAGGED DOORED
camaro__thunder is offline   Reply With Quote
Old 05-17-2007, 01:27 PM   #610
jkade
jkade's Avatar
Any updates??????
jkade is offline   Reply With Quote
Old 10-30-2007, 08:51 PM   #611
jkade
jkade's Avatar
So, this is the second time I have read the whole thread. On the upper plate that the bag mounts to, do you use a plate or a cup? Does anything need to be modified on the spring pocket? I am going to section my crossmember 1.5", 3" drop spindles, plate on top of the bag and air ride arms. I am running a 235/40/20 on the front and wanna lay the frame. I am looking to have about a 5" ride height at the bottom of the frame. I also plan to move my crossmember foward 1" to correct the centerline of the wheel. I am also going to fab up R&P.
Old 10-30-2007, 08:55 PM   #612
fastbagged68
I am running a cup on the upper mount. I cut my crossmember higher to let the control arm come up more. Look back @ some of the pics.
Old 10-30-2007, 09:01 PM   #613
XXL
Seņor Member
XXL's Avatar
The Wallet Eater has a flat plate on top, no mod to the spring pocket... just the 1.5" xmember notch itself. Also, ART arms, bag mounts directly to LCA, and spindle.
XXL is offline   Reply With Quote
Old 10-30-2007, 09:44 PM   #614
jkade
jkade's Avatar
I didn't see any pics with a cup on the top. I will go back and look.
Old 10-30-2007, 09:45 PM   #615
jkade
jkade's Avatar
This is what I thought, Thanks
Old 01-16-2013, 03:08 AM   #616
Desert.Chevy
Desert.Chevy's Avatar
After reading this thread, I would say this was the start of it all. Good thread too, if you have the time to read it.
Desert.Chevy is offline   Reply With Quote
Old 01-17-2013, 10:23 AM   #617
jitteryguy
GoatLube Experss
jitteryguy's Avatar
Originally Posted by phantom dually View Post
oh yeah my dad can beat your dad up!! No really I will lay in the rear with a 33x21.50
one of the best post in this thread ! beside's all the good info.
I think a small cross member notch with a small "Z" would look the best , allthough over all it would be more work I think it would be less modifacation's.
gotta keep in mind these guy's were run'n 29" tall tire's back then, I think most of us have taller tire's these day's.
Goat Lube Express, locations in Qalat,Afghanistan & Clarksville, Tn.
'87 R30 dually 454/TH400
'85 1/2 ton CCSB
'92 S10 350/350
'84 MonteCarlo 383/PG/9"ford
'78 Malibu wagon 350/350
'78 Cutlass (project family car)
'96 S10 Jimmy (Moma's)
jitteryguy is offline   Reply With Quote
Old 01-22-2013, 01:44 AM   #618
fastbagged68
Ha this is a classic!
