Old 11-14-2021, 08:05 PM   #601
The Rocknrod
Moderator
The Rocknrod's Avatar
Re: New 64 Stepper Project
Intersting article on the 200-R4 - https://www.motortrend.com/how-to/cc...mission-build/
Old 11-14-2021, 10:13 PM   #602
SCOTI
SCOTI's Avatar
Originally Posted by The Rocknrod View Post
Going to save that info. Need to get the one I have to the trans guy for an inspect assessment of its current health.
Thanks for sharing the link.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 11-14-2021, 10:46 PM   #603
The Rocknrod
Moderator
I read a previous article that was similar. Decided to go with Extreme Automatics due to they're race history and work in manufacturing their own valve bodies and shift characteristics . Although the company in that article is way more famous.
Oh, did you ever get that converter dust cover?
Old 11-15-2021, 12:00 PM   #604
SCOTI
SCOTI's Avatar
I did get the cover.
I'd read where that source was hit & miss on things. Ultimately, we went back/forth on 'interpretation' of the communications. What seemed so obvious in his mind did not translate over to what was written in his answers as there were key details left out.
Lesson learned. They'll only be a final-option source in the future.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 01-06-2022, 08:02 AM   #605
The Rocknrod
Moderator
Well it's winter, I thought I'd do a little cleanup and exhaust manifold change-out.
Old 01-06-2022, 12:38 PM   #606
66C10LB
Yup, definitely winter! Very tidy looking brackets on your engine.
66C10LB is offline   Reply With Quote
Old 01-06-2022, 07:28 PM   #607
The Rocknrod
Moderator
The manifolds I'm installing.
Old 01-06-2022, 08:48 PM   #608
Joe Pass
Joe Pass's Avatar
Sweet....
Joe Pass is offline   Reply With Quote
Old 01-07-2022, 07:59 AM   #609
The Rocknrod
Moderator
Originally Posted by Joe Pass View Post
Sweet....
Thanks Joe.
Old 01-07-2022, 08:14 AM   #610
The Rocknrod
Moderator
I expect that my engine will run a bit warmer after I conduct the carb re-work as I am changing the jets and the metering rods. When I pulled the plugs they all showed a very rich condition. After searching the internet I find the Street Demon comes in a very rich set-up from the factory for some reason. I think I have it nailed though.
Old 01-07-2022, 08:18 AM   #611
jmarkha1
they look great - very period. are they chrome plated or ceramic - love ram horn style manifolds - very clean work...
1965 c10 project - how does all this stuff go back together...
jmarkha1 is offline   Reply With Quote
Old 01-07-2022, 09:33 AM   #612
The Rocknrod
Moderator
Smoothed them ceramic coating.
Old 01-07-2022, 09:58 AM   #613
Hammered 77
Hammered 77's Avatar
Looking at some on speedway motors that say they are smoothed where did you get yours ceramic coated?
Hammered 77 is offline   Reply With Quote
Old 01-07-2022, 10:49 AM   #614
The Rocknrod
Moderator
Just so happens thats where I bought these already done.
Just torqued em up this am.
Old 01-07-2022, 12:41 PM   #615
pdxhall
pdxhall's Avatar
The new manifolds look great.
Sanity'66
http://67-72chevytrucks.com/vboard/s...d.php?t=515110
Long bed, Fleetside, Small back window
I've Done So Much, With So Little, For So Long, That Now I Can Do Anything With Nothing.
pdxhall is offline   Reply With Quote
Old 01-07-2022, 01:21 PM   #616
The Rocknrod
Moderator
Thank you.
Old 01-08-2022, 11:25 PM   #617
MT65
Did those reduced head bolts come with the manifolds or did you get ARP bolts?…
Those look great on that engine……
MT65 is offline   Reply With Quote
Old 01-08-2022, 11:47 PM   #618
The Rocknrod
Moderator
Those are ARP.
Thank you.
Just FYI the bolts Speedway sent were too long for the four end port bolts. I ordered everything from Alan's Fasteners:
ARP 3/8-16 HEX FLANGE BOLT STAINLESS STEEL
Product ID: 0520
Description: ARP 3/8-16 HEX FLANGE BOLTS STAINLESS STEEL,3/8 WRENCHING,.625 FLANGE
or
ARP 3/8-16 HEX STAINLESS STEEL FLANGE BOLT 7/16 WRENCHING
Product ID: 0520A
Description: ARP 3/8-16 HEX STAINLESS STEEL FLANGE BOLTS,7/16 WRENCHING,.698 FLANGE
https://www.allensfasteners.com/sear...ze=80&sortBy=3
And
ARP STAINLESS STEEL WASHER WITH CHAMFER
Product ID: 22247An
https://www.allensfasteners.com/sear...1&txtCatName=2
Old 01-09-2022, 09:37 AM   #619
The Rocknrod
Moderator
Almost ready to install the motor back in.
Old 01-09-2022, 03:49 PM   #620
SCOTI
SCOTI's Avatar
Outstanding!
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 01-09-2022, 05:54 PM   #621
The Rocknrod
Moderator
Outstanding!
Thanks Scotti.
I just got the engine stabbed in today and started torquing the trans to engine bolts. What a pain in the keester that is. I took a break, think I'll continue tomorrow.
Old 01-12-2022, 05:59 PM   #622
The Rocknrod
Moderator
Well I'm still at it, haven't given up yet.
Old 01-13-2022, 01:45 AM   #623
cwcarpenter98
cwcarpenter98's Avatar
Man, that would make me nervous to remove and reinstall that engine with all the new paint around it. Good idea with the towels and pads
Christian Carpenter
Overdrive wiring here
1981 C10 - Penny 305, th350 --> Soon to be 350, Saginaw 4 speed
1995 Dodge Dakota Sport
Old 01-13-2022, 08:14 AM   #624
The Rocknrod
Moderator
Piece of cake, I bought those moving blankets years ago and re purposed them to my shop.
Also just FYI I purchased an articulating engine lift device from Mac's years ago. The first time I installed the engine I had removed the front end, easy. This time I thought it would work as is. Kind of tricky had to remove it over the side fender area. I'm sure a simple engine lift plate would have been better in this instance. I just didn't have one.
And I'm not removing the hood!
Old 01-13-2022, 12:23 PM   #625
aggie91
I'm just glad to be here!
aggie91's Avatar
Your truck is just outstanding! and now you made improvements. Sure hope to get to see this one in person someday.
Karl
1965 Chevy Stepside(Grandpa's Old Blue) and (July 2015 Shop Build!)(2020, the Saga Continues)
http://67-72chevytrucks.com/vboard/s...d.php?t=372424
The LST Challenge:
http://67-72chevytrucks.com/vboard/s...=1#post7812257
Korbin's 1st Square: "Sunburn"
http://67-72chevytrucks.com/vboard/s...d.php?t=418618
1985 GMC Sierra: "White Trash", Korbin's 2nd now...
http://67-72chevytrucks.com/vboard/s...d.php?t=632305
Henry - 1984 Chevrolet, Owen's 1st Square
aggie91 is offline   Reply With Quote
