#601 |
Re: Starting my engine build
PUTTING IN ALL THE FLUIDS AND STARTIN HER UP!!!! I'll take video
#602 |
It started!!!!! Ran like a champ but the belt was screaming. New pulleys aren't lined up properly so tomarrow ill have to get a new belt and figure out a way to make the puppy's all line up.
BUT IT RAN!!!! Woooooohooooo I built a motor that works!! And it sounds so much more badass than it used to. The bump in compression made a huge difference. I'm not gonna be able to sleep tonight but I'll be at it again tomarrow |
#603 |
Just don't get so pumped you forget to go straight into break in mode when you do fire it up.
Maybe post straight from the side pictures of what is not aligned properly. New pulley's? aftermarket? Yea that can be a problem, there are shims available for the crank pulley, maybe water pump, that is if the pulley needs to be spaced away from the engine..
Mike. Swamp Rat build thread : http://67-72chevytrucks.com/vboard/s...d.php?t=595019 72 3/4T 4X4 4" BDS Lift 33" BFG's |
#604 |
Hey i thought you returned that chrome alternator.... Maybe that was the water pump..
#605 | |
#606 |
#607 | ||
"I ain't nobody, dork."
Is that your temp sending unit in the intake on the front passenger side? I'd put it where it belongs in the drivers side cylinder head, and reroute that heater hose to the passenger side front intake.
Not to nit-pick, but it will look way better too, so the hoses aren't stretched over the front of the engine. Like this: Gary
'cuz chicks dig scars... My 1972 GMC 1500 Super Custom (Creeping Death) "long term" build thread. The Rebuild of Creeping Death after the wreck Quote:
#608 |
This is why i hate aftermarket pulleys Unless you buy a system where they are all designed to work together, every aftermarket pulley i have looked at at the auto parts store's always have alignment issues when mixed with stock stuff..
#609 | |
#610 |
I'm working on shimming the alt pulley and water pump pulley OUT to match the crank pulley. Got a new belt and I'll try it again
#611 |
I see no mention of any break in of the camshaft. Please tell me you didnt just fire it up and let it idle.
Anthony |
#612 |
No he knows about the break in procedure, but he has threads allover the board so its hard to keep track.
![]() He said he had a 10 minute run and had to shut it down because the belt broke, but will start the procedure over upon refiring the engine.
#613 | |
I'm playing with the 650 AVS carb still. Two screws on the front, left is idle mixture screw correct? What should that be set at? Left screw is what? And Edelbrock masters out there. One thing I noticed is MUCH faster throttle response which I didn't expect but really really like. No studder when you stab it fast and it revs way faster than it used to. This thing honestly is NOTHING like it used to be, and I'm so glad I listened to advice and went ahead with pullin the motor and doing it all thorough and right, it really paid off big time. I'm no computer genius but I'm working on videos. I have the first three tries that died due to timing. And I have one where I got it dialed close enough and ran it. I also have an idle and rev video after it was all times right with a gun and light. Any body help with video posting? |
#614 | |
Anthony |
#615 | |
I am a bit concerned about your timing tho as mentioned above.
#616 |
![]() Join Date: Sep 2015
Congrats on building your first engine man!
![]() One thing I must say is I'm really impressed by how many just jumped in and taught you how to do it right the first time thats what I love about this board everyone just wants to help another guy out simply because we all love these trucks ![]()
"Orange Crush" |
#617 | ||
60-66 Nut
![]() ![]() Join Date: Mar 2007
It sounds to me like he set the timing at 36* @ 3000.
#618 |
Yeah but did you read the part where he said he put the timing mark at 0 and it started running better? 0 initial timing will make this thing a dog regardlessof what his timing at 3000 rpms is.
OP, did you do a full rebuild or just a cam and head swap? Not trying to bust your bubble, just trying to follow along. While a cam and head swap is a huge deal for a newbie, and sounds like you were successful, its not technically a rebuild.
Anthony |
#619 | |
#620 | |
#621 |
With the truck idling disconnect the vacuum advance and put the timing light on it. The ti.ing tab will tell you your initial or base timing. You want to advance it so look at the BTC numbers. It will run much better once you get the timing curve dialed in.
Anthony |
#622 |
How much initial or base do I want? And is initial set with dial on "0"
#623 | |
Anthony |
#624 |
#625 | |
