Closed Thread
Old 03-17-2013, 10:41 AM   #6326
BugzC10
BugzC10's Avatar
Re: What did you do to your truck today!
Installed Fatmat, rebuilt and installed steering column and cluster, installed new to me steering wheel and reinstalled carpet and bench seat. Also installed 3 point seat belts. All with my Scottie supervising.
1970 C10 Short Stepper with 71/72 front clip.
BugzC10 is offline
Old 03-17-2013, 11:28 AM   #6327
Shyguy
Junior Member
Shyguy's Avatar
Yesterday I said hi to my truck when I was over at the garage putting new lights and sideboards on a small utility trailer.
Tomorrow I am going to straigten out my garage and see if I can find all the parts I need to put tail lights on the '67 swb stepper.
'67 Chevy C-20 short stepper - build complete, 454/SM-465.
'75 C-30 Single Cab DRW-350 small block/NP-435.
'77 GMC-6500 Dump Truck, 427 Tall Deck.
'92 GMC K-3500 Duallie, 454/4L80E.
Shyguy is offline
Old 03-17-2013, 04:42 PM   #6328
magwakeenercew2jh
RAT1968 '68 Cab/'71 Parts
magwakeenercew2jh's Avatar
Retired the new, but suspect, mech. fuel pump.
Installed the block off plate and electric fuel pump while I wait for the gas tank to come back.
A little wiring inside the cab tomorrow, a precautionary fourth blow-out of the lines, and I'll be ready for clean gas to the carb.
M17
Coarsegold, CA
RAT's shiny now.
But always a rat.
magwakeenercew2jh is offline
Old 03-17-2013, 07:51 PM   #6329
Codez67Chevy
Codez67Chevy's Avatar
Yay I can finally say I did something on my truck. Its been too long. So my hood on the back two bolts the material has been tearing away, so I decided to take it off and weld it up. glad to be outside again.
Attachment 1077874
Attachment 1077875
" Dead Pumpkin" 67 Chevy short bed, 292 I6, 4spd manual. Fan of the "Slant Noses".
93' Toyota pickup 2WD 2dr and 32mpg. Daily driver. 300k+
Members I've met...
Mister-B
Codez67Chevy is offline
Old 03-17-2013, 07:58 PM   #6330
Scott>72-GMC
Scott>72-GMC's Avatar
Just showed up yesterday. And I got a cover today so hopefully the neighbors won't complain about the front clip missing for now lol . Best birthday ever
72 GMC super custom.
Scott>72-GMC is offline
Old 03-17-2013, 08:52 PM   #6331
asolde
asolde's Avatar
Worked on my Blazer today.....Replaced the shocks,replace the steering gear box, and install a steering stabilizer.
asolde is offline
Old 03-17-2013, 08:52 PM   #6332
Gmcfolife
Gmcfolife's Avatar
Installed a CPP c-notch and built new shock mounts.
Gmcfolife is offline
Old 03-18-2013, 09:14 PM   #6333
TexasSteve
TexasSteve's Avatar
Yesterday the '68 was empty. Today it isn't...... Just resting in there in the pic, ready to be bolted down!
2001 Yukon Factory Grey Metallic~2" DJM Key front drop/3" DJM Rear Springs~stock 16" chrome steel wheels~5.3/4L60E~Volante CAI w/under bumper air scoop~Magnaflow 10426 Bullet muffler~DDM LED all exterior lighting/55w-5000k HID Hi/Low/35w Fog
TexasSteve is offline
Old 03-18-2013, 10:48 PM   #6334
ole dollor
ole dollor's Avatar
well i finished up my cruise control install today, and it works great...now ole dollor has a/c, power steering, auto trans, 2.76 rear end,rear view mirror with map lights. new seat,carpet,paint, bed wood.white wall tires.and a good am/fm radio....man what else can a guy need...a good old daily driver. here are a few pics
ole dollor is offline
Old 03-18-2013, 10:53 PM   #6335
Carbajal
Carbajal's Avatar
Painted the cluster and the needles. Now just waiting for the led lights
[IMG][/IMG]
Carbajal is offline
Old 03-18-2013, 11:16 PM   #6336
rattle69
rattle69's Avatar
Not much, Gave her a bath, adjusted the idle from 1050ish to 850ish, replaced a couple burned out bulbs for turn signal and license plate light.
tomorrow pulling off cluster and looking for problems with dash lights. Probably painting cluster at same time like above
rattle69 is offline
Old 03-18-2013, 11:25 PM   #6337
OregonNed
OregonNed's Avatar
took a little drive to check tire pressures and a fill-up ($66 ouch!) - then I removed a mystery toggle switch that was bugging me and it's useless wiring under the hood. I also moved some good wiring into some black wire loom to pretty things up..
1968 Chevrolet C/10 LWB - 327, TH350 - 4/5 Drop
OregonNed is offline
Old 03-18-2013, 11:32 PM   #6338
HotRod C/10
HotRod C/10's Avatar
pulled the bed and mounted my rear disc brakes with built in emergencies. ground off the original shock mounts and bolted up the rear shock relocators.
SOLD -77 CHEYENNE SWB,
LS SWAPPED
-1976 SILVERADO
YUBA GOLD/NEUTRAL (2-TONE)
HotRod C/10 is offline
Old 03-19-2013, 01:11 AM   #6339
choctaw bob
Installed the A/C part of the Painless harness. Removed the windshield wiper motor so I can replace it tomorrow. Replaced the small vacuum hoses under the hood along with the hoses under the dash that they attach to. Removed the cheap radio that didn't fit the dash holes correctly. Need to find one that fits. Anyone have any ideas?
choctaw bob is offline
Old 03-19-2013, 02:01 AM   #6340
woodwright
Enjoying left field
woodwright's Avatar
A few weeks ago, I pulled the 12 bolt out of my K10 with the intent of cleaning it up, painting it, and installing my 3.73 posi carrier and gears......And then the "might as well"s took over. The brakes were completely trashed, so I figured I might as well swap to rear disks, Found a relatively inexpensive way to do it, but I had to drill out the rotors and axles for different wheel studs. I've always hated the short 7/16" stock wheel studs so I figured I might as well upgrade to bigger 14mm studs. Finally got the caliper brackets welded on today, but now I need to put the truck on the back burner for a little bit so I can swap the motor and tranny in my 64 Nova.
Clint
70 Chevy 4WD "Ultimate Work Truck" SOLD
woodwright is offline
Old 03-19-2013, 05:30 AM   #6341
THE BOSS
yesterday i picked up the 72 at the shop, filled it up $60 to confirm my gas gauge worked.
swung by the house, got the wife and dog then went for a ride!
only got 2 waves, 1 thumbs up this ride.
THE BOSS is offline
Old 03-19-2013, 09:08 PM   #6342
CSGAS
optomistic ah-so
CSGAS's Avatar
This was actually Saturday, but I plugged a vacuum leak tightened some screws down above the float bowl grabbed an exhaust manifold bolt and screwed it in while the manifold was hot and the holes still lined up, then re-tuned the carb for Spring on an actually warm, dry day in NC.
Then I heard there's a chance of snow this coming Sunday
Rubbing is Racin'
Ribbing is Bench Racin'
1970 C-10 lwb Fleetside. Originally 350 2-bbl 3-on-the-tree, m/b, m/w, m/s no a/c. Currently running on a '76 Camaro 305.
CSGAS is offline
Old 03-19-2013, 10:09 PM   #6343
CSGAS
optomistic ah-so
CSGAS's Avatar
Whups, forgot to mention reconditioning and relubing my speedo cable, and reattaching my hand choke cable, and other "tinkerings and knick-knacks"
Rubbing is Racin'
CSGAS is offline
Old 03-19-2013, 11:56 PM   #6344
heathbirkendahl
Ordered my ZZ4 crate engine and all the parts to install it. Cant wait! 210 to 355 HP!
1971 C/10 - Orange & White
2009 GMC 1500 - Lowered 3/4 22' KMC Slides
heathbirkendahl is offline
Old 03-20-2013, 01:21 AM   #6345
red71c10
The Red Menace
red71c10's Avatar
Replaced the charcoal and filter in my vapor canister, put in a new PCV valve and got the thermostatic air cleaner working again. My truck runs best on warm or hot air so I leave the stock system alone and today I figured I'd get it working as well as possible.
1971 Custom 10 - 350/350TH - Pwr steering, gauges, Chrome front bumper, Chrome hubcaps, Door edge guards, HD rear springs (current)
1968 C-20 Custom Camper - 350/350TH (orig 327), Pwr steering & brakes, gauges w/tach (former)
1968 C-20 - 307/3sp column (Dad's when I was a kid)
"Driving is like coloring. Things get messy if you can't stay inside the lines."
red71c10 is offline
Old 03-20-2013, 07:11 AM   #6346
b.eddy's72
b.eddy's72's Avatar
Day before I got all the bed floor rails out by cutting all the rusted bolts off and got the TEMP gooseneck plate put in until I can build my hidden plate.
Yesterday I got my electric fan brackets built and the fan mounted and working and got my 6 way light connector mounted in the back bumper.
Today...............................nothing cause I have to go help a friend do a PA install at a church and the wife gets off early.
72 Chevy LB, LS in the works, 4L80, Grandfather bought it brand new.
66 GMC Short Step, 84 Front Suspension, many more mods to come
67 Chevy 3/4 Ton, 327, Auto, Factory A/C
Ya must have been movin cause I was haulin a*$ when I passed you
b.eddy's72 is offline
Old 03-20-2013, 03:55 PM   #6347
VDOG
Grand PooBaa Member
VDOG's Avatar
Pulled my grille, now have to purchase some support brackets to install the new grille. Also change out the passenger side fender.
VDOG is offline
Old 03-20-2013, 04:47 PM   #6348
magwakeenercew2jh
Yesterday, after i finished wiring the electric fuel pump to the fuse block, installing a secret, anti-theft switch,
and blew out the fuel lines, I got my gas tank back from the "hot tank" man.
Today, I attached some "anti-squeek" material around the edges of the gas tank. And I also put the stuff
(looks and feels like tar-paper) any place I thought it might contact the cab.
Tomorrow, I'll re-install the fuel gauge sending unit and get the tank back in the cab.
M17
Coarsegold, CA
RAT's shiny now.
But always a rat.
Old 03-20-2013, 05:01 PM   #6349
SCHRUMGMC
SCHRUMGMC's Avatar
How exactly do you put it in the back of the bed
1971 GMC Sierra
1959 GMC 100
SCHRUMGMC is offline
Old 03-20-2013, 08:37 PM   #6350
Expat_dude
Expat_dude's Avatar
Cab back on the frame!
1970 Chevy swb, project UGHH!
1987 Grand National
http://s168.photobucket.com/albums/u.../1970%20Chevy/
Expat_dude is offline
Closed Thread
