10-25-2012, 08:11 PM | #6401 |
Re: What did you do to your truck today?
Pick up my seat tomorrow, hope to wrap this build up soon
10-25-2012, 09:39 PM | #6402 |
GMC's n H.D.'s too!
That seat looks great towersddg9!
10-25-2012, 09:41 PM | #6403 |
Seats look great! That's the instrument cluster I want. Very nice.
------ 65 Chevy C10 Fleetside |
10-26-2012, 09:37 AM | #6404 |
I agree that is nice!!!
LIFE IS SHORT HAVE FUN |
10-26-2012, 09:41 AM | #6405 |
Been busy with yard work and closing the pool for winter but... put a quick detail shine on the truck!
LIFE IS SHORT HAVE FUN Last edited by glos55; 10-28-2012 at 09:53 AM. |
10-26-2012, 09:54 AM | #6406 |
Ordered a P/s bracket mount......hopefully I can get it to fit.
62 C10, LWB fleetside, 350SBC, Munie 4spd, |
10-26-2012, 05:05 PM | #6407 |
Thanks for the input, here she is all done
Posted via Mobile Device Posted via Mobile Device |
10-26-2012, 06:31 PM | #6408 |
back on 4 wheels
10-26-2012, 07:03 PM | #6409 |
Today I dropped my truck off to the paint shop. Will be posting pics during and after. Can't wait to see the great job
10-26-2012, 10:03 PM | #6410 |
New weatherstripping installed and the doors hung!
10-26-2012, 10:50 PM | #6411 |
Took the crossmember over to my buddy's shop, put it up on the bench and took it most of the way apart. Can't get the ball joints off. I cut the rivet heads and used a punch but the rivets wouldn't budge.
Steven
“Life is and will ever remain an equation incapable of solution, but it contains certain known factors.” - Nikola Tesla Matt. 6:27 "Who of you by worrying can add a single hour to his life?” http://www.67-72chevytrucks.com/vboa...=507266&page=2 |
10-26-2012, 11:05 PM | #6412 |
Got my GMC ready to be drivien for the first time since 1997...going to a car show tomorrow. So far it has new rear brake shoes with wheel cylinders, all new cap, coil, rotor, wires, plugs, points, and condensor. In addition to all that, I had to free up 5 stuck intake valves, straighten 3 push rods, break free the door mechanisms, and fix the gas gage. The truck has sat so long, a lot of things on it are corroded together. I still have to figure out why the front parking lights & turn signals don't work, and the heater doesn't work. I've gone thru almost a full can of penetrating oil working on her.
My Projects: 1960 GMC 1/2ton with 305 V6 (daily driver) 1963 Chevy 1/2ton 2wd...converting to 4x4 1967 Suburban 1/2ton 2wd My Girlfriends Projects 1985 Chevy Suburban 3/4ton 4x4 with 6.2L diesel, 4" lift, converted to TH-400, Warn Premium manual hubs, & Wildcat 315/75/R16 tires. (daily driver) 1978 Camaro Type LT with a Marine 350 & vortec heads, Rochester Carb, & roller cam 1978 Camaro Z28 |
10-27-2012, 03:51 AM | #6413 |
I had the same problem. I ended up using an air chisel between the ball joint and the control arm. It took a min but, it finally worked a gap in there so I could pry it the rest of the off.
10-27-2012, 06:27 PM | #6414 |
Thanks for the tip!
Steven
10-27-2012, 09:54 PM | #6415 |
10-28-2012, 01:28 AM | #6416 |
Senior Enthusiast
Spent all day mounting the new fender emblems. Who would think so much time could be spent on such a simple project. The upside being both sides came out exactly the same and I'm very pleased with the results. Details and photos tomorrow.
My Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=444502 |
10-28-2012, 10:54 PM | #6417 |
I have a finished rolling chassis, now onto the motor and trans.
10-28-2012, 11:17 PM | #6418 |
They just did this on trucks TV Saturday. Not sure if you can watch the segment but they cut off the ball joint with a torch then heated the rivets with the torch and used an air hammer to get the rivets out. Looked pretty easy if you have a torch.
66 shorty |
10-29-2012, 12:03 AM | #6419 |
Bought a toolbox that I will be refurbishing to stick in the back. It is a drop in style so it will sit below the level of the side rails so it won't be seen easily. It's diamond plate but pretty beat up. I think it will be getting a coat of paint to match the truck.
10-29-2012, 04:05 AM | #6420 | |
cheers |
10-29-2012, 07:59 AM | #6421 |
Finished the shifter, pedals and column and started on the Dynamat
10-29-2012, 01:50 PM | #6422 |
Oil changed, emergency brake adjusted, clock installed, gas and drove it.
1963 Short bed step side SBW 427 big block and borg warner T-16 HD 3 speed manual http://67-72chevytrucks.com/vboard/s...d.php?t=519869 1963 Short bed fleetside BBW 348 1st gen big block w/Powerglide http://67-72chevytrucks.com/vboard/s...d.php?t=619024 1964 Short bed trailer |
10-30-2012, 12:14 AM | #6423 |
Senior Enthusiast
Not exactly work on my truck, but I just spent the last hour and a half reinserting at least a dozen missing photos in my build thread that Imageshack unceremoniously feels a need to randomly drop. And I’m not done yet.
10-30-2012, 02:00 PM | #6424 |
Bought the power steering kit from the Captain and picked up a 1.25" front sway bar from Pick and Pull. Ordered up the Energy Suspension bushings for it and I'm going to finish painting it up today.
I was thinking of using that silver Hammertone paint on the sway bar to give it some colour. How durable is that stuff? Brian
1965 Chevy Short Box Stepside, 230 - 3 speed, 4:11 gears, original paint rust free survivor. Now sporting a 383 SBC and TKO-600 |
10-30-2012, 02:59 PM | #6425 |
Continued with tear down this past weekend. Hadn't planned on removing the cross member, but could not think of a good reason not to once that was all that was left attached to the frame. Actually, cleaning, degreasing, and rust removal will be a TON easier with it off
Now time for rust removal, then POR15 on the frame.
Craigerrr My build thread, CRGRS 66 Winter Build: http://67-72chevytrucks.com/vboard/s...09#post5638709 |
