#6426 |
Resident Photoshop Nerd
Re: What did you do to your truck today?
Parked him in his new storage space until we finish the engine, in our new city of Phoenix.
PJ - 1966 C10 Panel -- Max˛ - 1964 Jeep Wagoneer Panel-delivery -- Waiting his turn |
#6427 |
after driving my truck for 4 years with no gas pedal i found a easy fix at the good guys show this past weekend. welded a nut to the end of the arm.... i like it and it was easy and cheap.
The price of cool aint cheap. |
#6428 |
I really like that solution!
I just might borrow it. Steven
“Life is and will ever remain an equation incapable of solution, but it contains certain known factors.” - Nikola Tesla Matt. 6:27 "Who of you by worrying can add a single hour to his life?” http://www.67-72chevytrucks.com/vboa...=507266&page=2 |
#6429 |
It's Better With Nitro
Finished welding up and smoothing out the last holes in the cowl area, rear of cab interior, and repair of the top of the dash (replaced speaker grill and fixed dents in the dash). This is the last repairs of literally 100s of holes the PO drilled throughout the cab and floor. Time to put the cab back on the chassis and get it ready for real bodywork and paint...
#6430 |
willp p.....cool mod. Ill get with you this weekend if your going to be around. Will be doing a bonfire/bbq at my place Sat night if you'd like to come out.
1963 Short bed step side SBW 427 big block and borg warner T-16 HD 3 speed manual http://67-72chevytrucks.com/vboard/s...d.php?t=519869 1963 Short bed fleetside BBW 348 1st gen big block w/Powerglide http://67-72chevytrucks.com/vboard/s...d.php?t=619024 1964 Short bed trailer |
#6431 | |
http://kieth.smugmug.com/Trucks/66-G...8634&k=cFvxQKn Now that I look back on it, we might have gotten a little carried away but it looked good at the time. Kieth |
#6432 |
I welded in the support section on the underside of the cab stretch project.
#6433 |
thanks for the invite, ill be here all weekend. give me a ring.
#6434 |
Senior Enthusiast
Took the truck out this morning to shoot a few photos, and discovered the pesky and irritating windshield trim squeak had returned. So this afternoon I spent another couple hours with a blade like jewelers file and opened up a good size gap between the two upper pieces. Hopefully this will be the last time it needs attention because it's miserable working on that spot with the hood in place.
My Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=444502 |
#6435 |
"Where were you in '62?"
![]() Join Date: Jul 2004
Well seeing everyone working on their trucks here lately made me do a little tinkering while she's down.
PROJECT: "FULL METAL YELLOW JACKET" 1962 Chevy C-10 Stepside Shortbed Nostalgia Pro/Street Pickup Truck PROJECT: "FULL METAL YELLOW JACKET Build Thread What Are You Workin' On? - 1Bad62ChevyPickup PROJECT: "TYRANNORAMBLER REX" 1969 AMC Rambler American Nostalgia Pro/Street Youtube Channel: Father Son Projects Youtube Channel: 2TIMOTHY2FITHTEEN ![]() ![]() ![]() ![]() ![]() ![]() ![]() "North and South Carolina Folks Click Here!" (((( ~ I have Parts For Sale & Miscellaneous Stuff ~ )))) "Well being as there's no other place around the place, I reckon this must be the place, I reckon...Nyuk Nyuk Nyuk" -Curly Howard Ph.D. |
#6436 |
Last pic.
#6437 |
Redneck Hillbilly
Went out to try and fire her up for a little drive.....and no start. This carb is junk, and I'm tired of messing with it. So I guess she sits until I can get the Caddy engine in, or I figure something else out.
#6438 |
#6439 |
(technically this weekend, but this is the first chance I've had to post it)
Replaced the valve cover & pushrod cover gaskets. Repainted all the pieces I took off. Since I can't find the correct engine color I went with GM blue. ![]() Started laying sound deadener down, I've only done the middle area as I still need to finish rust repair & repainting at the sills, and get the rest of the old insulation off the firewall. ![]() |
#6440 |
A few more today...
I'm using Cold Drawn Steel. All steel used on my truck is Cold Drawn Steel. Will add more of the progress later. ![]() ![]()
#6441 |
Just picked up my first pre-80's truck in fresno yestersay, driving it back to ohio until sunday
66 with 3pd, 327, 3 gas tanks, sbw, long bed. Posted via Mobile Device |
#6442 |
Senior Enthusiast
Welcome to the forum, and good luck on your journey!
#6443 |
I finish the 2 1/2 day puzzle today. I think I was only able to lay (2) complete sheets the rest was make a template cut and lay. Then go back and tape all the seames and there was alot of them.
#6444 | |
Craigerrr My build thread, CRGRS 66 Winter Build: http://67-72chevytrucks.com/vboard/s...09#post5638709 |
#6445 |
A little bummed today, thought I would see my CPP order today... most likely next Tuesday now, the bright side is that I am not really ready for it anyway
#6446 |
Senior Enthusiast
Wow that looks beautiful.
#6447 |
![]() Join Date: Mar 2011
Great job, man! Your truck is really coming along. I can't wait to see it finished.
#6448 |
My son took our 63' to high school autoshop for a brake job...$40 in parts and free labor including turning the rotors and drums and we have a truck that actually stops! Good job kids! The shop teacher likes the older vehicles because they make great teaching projects because they are simple..
#6449 |
took the truck to the BBQ today at work. one of my joes took these...pretty cool. then the drivers window got stuck down, had to fix that when i got home.
#6450 |
weld in fender patch http://67-72chevytrucks.com/vboard/a...1&d=1351823657
STEVES 63 BUILD http://67-72chevytrucks.com/vboard/s...d.php?t=412554 GIBSON63 YouTube channel https://www.youtube.com/user/1gibsonl4 |
