Old 05-26-2017, 10:21 AM   #626
jhama78
jhama78's Avatar
Re: 1991 V3500 Project Heavy Hauler
Cant wait to see them on the rig!!
-j-rod
'06 3500 LWB CC 4wd, 8.1 Allison
jhama78 is offline   Reply With Quote
Old 05-27-2017, 01:24 AM   #627
MTCK
MTCK's Avatar
Thanks again for the help JRod and welcome home! One more teaser. I've got a truck day approved tomorrow so hope to knock out the punch list on the lift, do the motor work, remove the topper and install the hitch and camper tie downs and wiring. That'll never happen in one day....
-Marcus
1991 V3500 L29 454 4L80E NP205 D60/14 Bolt 4.56's
1984 K30 292 TH400 NP205 D60/14 Bolt 4.56's flat bed 7'6" Meyer Plow
2022 Silverado 3500 L8T
Project Daily Driver
Project Plow Truck
MTCK is offline   Reply With Quote
Old 05-27-2017, 01:55 AM   #628
daddyjeep
daddyjeep's Avatar
You gotta have goals. Maybe a little unrealistic, but might as well go for it.
85 K30 crew cab dually - Project http://67-72chevytrucks.com/vboard/s...d.php?t=694939
87 Wrangler Rock Crawler - Reason for the project http://www.wranglerforum.com/f330/da...ld-122601.html
04 1500 crew cab
http://67-72chevytrucks.com/vboard/s...d.php?t=786514
daddyjeep is offline   Reply With Quote
Old 05-27-2017, 05:52 AM   #629
Greenlee
Greenlee's Avatar
Nice! She looks mean with the new tires.
Greenlee is offline   Reply With Quote
Old 05-28-2017, 12:29 PM   #630
MTCK
MTCK's Avatar
Thanks guys. Here's a shot back on the ground. List install is done. On to the motor work and camper prep and hitch install. BTW I think the B&W hitch is going to fit well.
-Marcus
Project Plow Truck
Old 05-28-2017, 05:38 PM   #631
MTCK
MTCK's Avatar
I always wonder will this aftermarket part work with that one? If the question is will the 16k B&W receiver hitch work with an ord 2.5" one ton flip kid, the answer is yes with a tiny bit of flapper wheel clearancing on the middle mount.
-Marcus
Project Plow Truck
Old 05-28-2017, 07:42 PM   #632
jhama78
jhama78's Avatar
Looks great man!!
-j-rod
Old 05-29-2017, 07:56 PM   #633
y5mgisi
Second Chance Program
y5mgisi's Avatar
Very nice!
90 Chevy Suburban 2500 5.3 swap/th400/np241/14bltSF/10blt.
77 C20 crew cab Silverado. 396/th400. In work.
y5mgisi is offline   Reply With Quote
Old 05-29-2017, 08:35 PM   #634
Half Assed
Half Assed's Avatar
I like the tire and wheel combo.
I have a poptop 8' truck camper that I am working on for mine too. It's an old ass AMF skamper from the 1970s.
Half Assed is offline   Reply With Quote
Old 05-30-2017, 01:01 PM   #635
daddyjeep
daddyjeep's Avatar
That looks like the same hitch that came with my truck. I had to move my center mount about an inch after I shortened my frame. I'm glad you got it to work with a little grinding. The truck looks great with it's new stance.
04 1500 crew cab
Old 05-30-2017, 06:10 PM   #636
BriRan
Great work Mick, that truck is a work of art!
BriRan is offline   Reply With Quote
Old 06-06-2017, 06:20 PM   #637
whitels1
whitels1's Avatar
That's the hitch I went with on the K10 before the transition, it's beefy and the price was right. Made in USA if I recall!
The beast is coming along awesome, Keep up the good work!
GoldyLS1 K20 Build
My K10 Rock Crawler
-Dave
whitels1 is offline   Reply With Quote
Old 06-07-2017, 12:26 AM   #638
'63GENIII
'63GENIII's Avatar
Looking ridiculously good there Marcus. The black wheels and period correct camper shell really round it out!
Chris
'63 k15 long step
Vortec 7.4 - L29 Blackbear tune, Five 0 Motorsports injectors, Chris Straub Cam, NV4500, divorced 205
52" front and 63" rear spring swap
D44 / 14bff - disc axles
Milemarker 9K and 10.5K hydraulic winches
63" & B52 Spring Install http://67-72chevytrucks.com/vboard/s...ng+swap+thread
NV4500 Reverse Build Thread http://67-72chevytrucks.com/vboard/s...=reverse+build
L29 - 7.4 Vortec Build http://67-72chevytrucks.com/vboard/s...&highlight=L29
'63GENIII is offline   Reply With Quote
Old 06-11-2017, 02:40 AM   #639
MTCK
MTCK's Avatar
Thanks everybody for the compliments. Been moving at a snails pace the past few weeks with lots of other stuff going on, but think I am on track to be on the road tomorrow.
Combining all the right fittings to put the oil pressure sending unit in a happy place was a huge PITA. After a little pinch weld massaging I'm happy. Also if anyone is wondering, can you drop a BBC oil pan with the motor and all cross members installed the answer is no. I did get enough gap at the rear to replace the oil pump. Lifters are also swapped. Tomorrow need to drop the dizzy, install fuel rail, wiring, upper intake, plumbing... really need to drive the ~360 miles down to get my pop up before it wears out it's welcome in a buddy's driveway.
-Marcus
Project Plow Truck
Old 06-11-2017, 03:03 AM   #640
'63GENIII
'63GENIII's Avatar
Ahhh, I remember that view. Not terribly fond of it either. Had to get #8 ex valve to open in order to get the VC off.
So Im guessing you didn't do the oil pump? Its going to be real nice with the new lifters. It will probably run better with those rollers getting their max lift!
Chris
'63 k15 long step
Old 06-11-2017, 10:02 AM   #641
MTCK
MTCK's Avatar
That's my hope. A guy always needs more power. I was able to just barely snake the old pump out and new one in, so the parts pile is empty.
-Marcus
Project Plow Truck
Old 06-11-2017, 08:27 PM   #642
st1
st1's Avatar
Empty parts pile... SCORE!!
stone sends...
78 GMC Stepside (http://67-72chevytrucks.com/vboard/s...d.php?t=243201)
06 Dodge Charger Daytona R/T
05 Suzuki GSX-R 1000
st1 is offline   Reply With Quote
Old 06-12-2017, 03:24 AM   #643
MTCK
MTCK's Avatar
Had a good wrenching session today. Man the new lifters springs are soooo much smother than the hammered old ones. Got everything together just before quitting time and hit the key. I think the distributor is out 180. What a rookie movie if that's what it is. I hope that is it though because if not I'm stumped. Pretty hard to screw up anything else as all the sensors only have one plug that will fit them. It's not setting an error code at all. Anybody know if that is normal?
-Marcus
Project Plow Truck
Old 06-14-2017, 03:33 AM   #644
MTCK
MTCK's Avatar
Well I installed the distributor correctly the first time. Part of me is happy because I did t screw up, but I would rather know what the problem is and be able to fix it.
Procedure used on setting the lifter preload was the same as every other time I have worked on the motor. Rotate until exhaust starts to open, adjust intake. Rotate until intake starts to close, adjust exhaust. It was actually way easier than with the old lifters because everything moves freely.
So the truck cranks, sounds like it has compression, and sputters and pops, but won't fire. The whole time I've been running this motor it always lights off so quickly it surprises me. Seems to have some spark and some fuel. My logic is to throw a fuel pressure gauge on the rail and timing light on the distributor while cranking. Not setting any codes but it won't run. Any brilliant ideas???????
-Marcus
Project Plow Truck
Old 06-14-2017, 08:24 AM   #645
y5mgisi
y5mgisi's Avatar
Did you say you replaced the fuel pump? Check the fuel pressure?
Old 06-14-2017, 11:41 AM   #646
MTCK
MTCK's Avatar
Oil pump, not the fuel pump was replaced. Confirmed it shoots fuel out the test port but I'll put a gauge on it today.
-Marcus
Project Plow Truck
Old 06-14-2017, 01:59 PM   #647
'63GENIII
'63GENIII's Avatar
Could be crank sensor relearn? That dist has to be within 1 or 2 degrees or weird stuff happens
Chris
'63 k15 long step
Old 06-14-2017, 02:22 PM   #648
MTCK
MTCK's Avatar
Excellent idea. I recall when I installed the distributor on the engine stand last year that I could not get the rotor to line up perfectly with the 8 cast into the base of the distributor. When I dropped it in the truck it was spot on, but now it doesn't run!
I think I'll get my piston stop out, confirm TDC again and go through the whole process again. I'm getting good at tearing the top end off this motor.
-Marcus
Project Plow Truck
Old 06-14-2017, 02:40 PM   #649
'63GENIII
'63GENIII's Avatar
Mine ran even though it was off but it kept throwing 1345 crank trigger code. I was in the middle of getting it timed with the knockoff Tech 2 and the damn thing blew up. With the T2, it's real easy. Little more work without it.
On another note, how'd your injectors look when you popped the upper plenum off? And did you do the fuel regulator while you were there? I can't tell you how much I despise the engineer that put that thing in that location!
Chris
'63 k15 long step
Old 06-14-2017, 02:54 PM   #650
MTCK
MTCK's Avatar
Injectors looked great, and the FPR was a new AC Delco unit last spring. This is a good lead, I'm going to tear into it this afternoon.
-Marcus
Project Plow Truck
