07-11-2017, 11:54 AM | #626 |
Re: S10 Swap how to
I couldn't see any issues with 1" longer column.
51' 99toLife finished 2011,355 sbc,5speed, patina, redoing whole truck, inter, bags, etc http://67-72chevytrucks.com/vboard/s...d.php?t=382481 49Hardtimes s/10 susp- bagged, vortec sbc, 5 speed, patina, sold http://67-72chevytrucks.com/vboard/s...d.php?t=594874 VIDEOS https://youtu.be/E8zHhjgS_lA https://youtu.be/E8zHhjgS_lA Geronimo 54' LS engine, static drop IFS, Client build, just about done http://67-72chevytrucks.com/vboard/s...62#post7399162 52' 3100 Slowly in progress, will be painted two toned, have 235 with a t-5, lowered OG frame Other projects, 49' farmuse 3100, killer Patina, will be slammed, LS engine, full done interior up next! www.coffeeandcustoms.com |
07-14-2017, 10:03 PM | #627 | |
Re: S10 Swap how to
just make sure you fit behind the wheel before you make it permanent. these trucks dont have a lot of room with the stock seat and still are tight (to the steering wheel) with a late model truck seat.
the mass of men live lives of quiet desperation if there is a problem, I can have it. new project WAYNE http://67-72chevytrucks.com/vboard/s...d.php?t=844393 |
08-15-2017, 03:32 AM | #628 |
Re: S10 Swap how to
I have my 51 cab and body mounted on my 92 S10 frame. I placed the cab mounts 2 1/8" forward of the oval holes. All the bolt holes in the cab line up with the mounts well. I hung my fenders, core support, inner fenders, and hood support. I cut the front frame horns 1/2" off of the steering box as well. When I tried to mount my grille to mock it up, the vertical supports that hold the grille together are hitting the frame rails. Did anyone else have this issue?
08-15-2017, 10:21 AM | #629 | |
Re: S10 Swap how to
www.olesargecustoms.com email: chris@olesargecustoms.com '48 build: http://67-72chevytrucks.com/vboard/s...d.php?t=541904 '33 build: http://67-72chevytrucks.com/vboard/s...=1#post6232888 '49 build: http://67-72chevytrucks.com/vboard/s...=1#post6364475 |
08-15-2017, 11:32 AM | #630 | |
Re: S10 Swap how to
would that give you room for your grille uprights?
08-15-2017, 03:20 PM | #631 |
Re: S10 Swap how to
Shock absorber question-Does anyone here have input/preference for S10 shocks? I've got 2" drop spindles in front and 3" lowering blocks in the rear, so as I understand it I preserve the original dimensions for shock length. I'd like to at least consider air adjustables for the rears in case I carry a heavy load, but handling is more of a priority.
Thanks for any input.
http://67-72chevytrucks.com/vboard/s...s10+frame+swap |
08-15-2017, 08:38 PM | #632 | |
Re: S10 Swap how to
08-15-2017, 10:19 PM | #633 |
Re: S10 Swap how to
Skymangs, do I need to clearance my frame rail on the driver side for my exhaust to clear? I know nobody has mentioned this as I've read this post over multiple times over a year now. I have a 54 that I've used your cabstand design on a 94 LBRC chassis and I've installed an 04 6.0 LS with about 1" behind the passenger head to firewall for clearance and on the driver side the stock rear manifold looks like it's shooting straight for the frame. Am I missing something or will it clear?
08-15-2017, 10:31 PM | #634 | |
Re: S10 Swap how to
1999 GMC Suburban K2500 SLT, 454/4L80E 1991 Z/28, 6.0L/T56 1949 GMC 250, S10 Frame, 6.0L/4L80E Instagram @aceshighspeedshop |
08-15-2017, 10:42 PM | #635 |
Re: S10 Swap how to
Will do. Thanks. I'm doing a 6. 0/4l80e combo. Been sitting idle on it for other builds and I'm going to jump on it and have it on the road hopefully by January.
08-16-2017, 09:29 AM | #636 |
Re: S10 Swap how to
I am building my first truck using this website as direction. I don't want to use the in take fuel pump. I can't use a mechanical, so I need something like the rotary vane. Reading the reviews for fuel pumps on Summit/Jegs/Speedway they all are loud and unreliable. I need opinions from those that have a success story
Jim Building my first hot rod 54 Chevy truck, S10 frame 383/700r4/373 |
08-16-2017, 10:08 AM | #637 |
Re: S10 Swap how to
I used a carter rotary vane from summit, had it running and I doubt you'd ever hear it even at idle. Yet to have the truck back together to verify all that. The nice thing about the rotary vane is easy to install, cheap and from what I read reliable. It was maybe 50$ or something.
08-16-2017, 10:22 AM | #638 |
Re: S10 Swap how to
SHOCK answer, I was enlightened by joedoh on the Belltech drop shocks. Check them out on summit.
08-16-2017, 12:04 PM | #639 |
Re: S10 Swap how to
Thanks, 99. I found those yesterday, and I'll probably order up a set today. Tire Rack seems to be the place.
08-17-2017, 12:07 PM | #640 |
Re: S10 Swap how to
i use stock monroe's up front with drop spindles and i can think of no reason to not use air shocks in the rear.
i don't recommend using stock manifolds for that exact reason. any shorty header will work, or if you can find them, trailblazer SS. and he's right, i've been running a Carter rotory vane in my son's 48 for 5+ years.
08-19-2017, 12:16 AM | #641 |
Re: S10 Swap how to
On the 1950/s-10 frame swap. Has anyone done a in frame master cylinder/power booster pedal assembly ? Instead of on the firewall ? Similar to what they used in the early 50s. If so what named brand kit did you use that fit the s-10 frame.. No reason to use in frame , other then trying to cleanup and smooth the firewall.
08-19-2017, 02:27 AM | #642 |
Re: S10 Swap how to
Had a question guys. My 50 chevy has nothing in the engine bay nor the inside of the cab. I only have the steering column of a 93 s10. It sits on a 94 s10 frame. Do you guys recommend i buy a running vehicle with the engine/trans combo i want and use everything and anything i can from that vehicle? (Seat, driveshaft, trans oil cooler, brake booster...) Or should i just buy the engine/trans pullout and then get the other stuff from a junk yard as i need it? Want to see what route would cause me less headaches. Thanks in advance!
08-19-2017, 11:03 AM | #643 | |
Re: S10 Swap how to
(I do have a 2.8L v6, wiring harness, and matching transmission if you can find a way to ship it to Texas ) If you're already rolling on an S10 chassis with suspension, steering, and brakes, there isn't much value in tearing apart another one unless the plan is to drive with the V6 engine and trans it comes with. If your dreams are for an LS swap with a 4L60E or similar transmission, then an engine and transmission pull with a new wiring harness makes much more sense, IMO. I am on truck 1 of 1, there are others who have done a bunch of these builds. I believe I asked the seat question before and the S10 seat doesn't fit the Chevy 3100 cab.
Current Build Thread 1930 Ford Model A Modern Twist: Ford Model A Rat Rod With a Modern Twist Build Thread Phase 1 "The Swap": 1949 3100 with S10 swap. Beginner build with ambition! Build Thread Phase 2 "The Drop": Beginner Build with Ambition gets Air Ride |
08-19-2017, 01:35 PM | #644 |
Re: S10 Swap how to
i did an under floor master on my 49 (in my sig), but i didn't use a kit, i built my own.
as for the 50, i'd buy a nice 5.3 takeout with a 2wd trans, wire harness, and computer. then sorce everything else. gm g bodies make a good doner.
09-14-2017, 07:35 PM | #645 |
Re: S10 Swap how to
I'm currently working on my s10 swap. I've got a 53 gmc that I'm putting on an s10 frame. I purchased a zr2 rear end, a chevy 2500, a 98 blazer for parts. My question is will the zr2 rear end work. I've heard some say it will an some say it won't. I was on the ad-engineering website and they said the zr2 will not work. Is this just for their kit? Also I'm wanting to know what wheel and tire sizes for this setup including offset and back spacing for an 18" wheel. I plan on purchasing 2" drop spindles and 3" blocks for the rear. Thanks
Posted via Mobile Device |
09-14-2017, 08:01 PM | #646 |
Re: S10 Swap how to
http://67-72chevytrucks.com/vboard/s...448842&page=15
check out daverods build, uses a zr2 rear. I'm about to do the same thing.
09-14-2017, 09:49 PM | #647 | |
09-15-2017, 02:19 PM | #648 |
Re: S10 Swap how to
Nchristi,
My rear tire size is 255/50/17. I don't remember the wheel offset, but I don't think there is any. My rear axle is from a '70 Chevelle, which is around 61.5" from mounting surface to mounting surface. I did not want to tub my bed, which is why I used such a wide axle. My tires just barely clear the bedside (by like 1/4") so I will probably kick them out about 1" or so with spacers. I have to wait until I put the rear fenders back on to determine clearance, but those 255 tires will be a pretty tight fit between the bed and fender.
09-16-2017, 01:16 PM | #649 |
Re: S10 Swap how to
as far as the manifolds go, I never use the stock manifolds on an LS swap, for that very reason. any cheap blocks hugger will do.
09-18-2017, 02:19 AM | #650 |
Re: S10 Swap how to
Hi Guys, new to the thread, 1st post. I'm considering doing an S10 swap on my '51 5 window. Is it possible to use the 4.3L as it sits without moving the motor position? Looking for the simplest way to approach this project. Thanks for sharing your knowledge.
