08-30-2015, 06:21 PM | #626 |
Re: What did you do with your truck today, take 2
When I got my truck it had a steel bed floor in it. I replaced it with an original style wood floor and put the cross members back like they were before, with the different one in the wrong location. See it in the pic. The odd one should be in the second from rear location. Just wanted to mention this since the question of the location of the odd cross member has come up before.
08-31-2015, 12:35 PM | #627 |
08-31-2015, 12:58 PM | #628 |
392Hemi....my springs say 450lb on them...thanks for the info.
08-31-2015, 01:01 PM | #629 |
08-31-2015, 02:16 PM | #630 |
Worked on my sons truck yesterday. Cleaned the gas tank and cleared the fuel line. Replaced wheel studs and lug nuts. Installed the new battery tray. We removed the radiator to put in the new one but they sent us the wrong one. Hoping to get the correct one by this Saturday.
Still looking for a drivers side door and a couple 6 lug 15in wheels. |
08-31-2015, 03:12 PM | #631 |
Yesterday I changed the seat in my truck to a 73-87 style, new carpet on the floor and wired in a new stereo. That seat sure gives me more legroom.
1966 427 biscayne with a 5 spd tremec on old school torque thrusts. 1972 Cheyenne Short Bed 1958 Apache short fleet 1980 Chevy short bed http://67-72chevytrucks.com/vboard/s...d.php?t=761005 1959 "Henry" http://67-72chevytrucks.com/vboard/s...d.php?t=670461 1966 Biscayne http://67-72chevytrucks.com/vboard/s...d.php?t=444419 1972 Suburban http://67-72chevytrucks.com/vboard/s...d.php?t=478828 |
08-31-2015, 04:01 PM | #632 |
Re: Last 2 items painted today. Steering wheel and rear bumper strut rod supports.
What color white are your wheels?
1959 Chevy Short Fleetside w/ 74 4WD drive train (current project) OrrieG Build Thread 1964 Chevelle Malibu w/ 355-350TH (daily driver) Helpful AD and TF Manual Site Old Car Manual Project |
08-31-2015, 04:53 PM | #633 |
Glad I'm not the only one who's pictures come out the wrong way
yoshi's 49 project |
08-31-2015, 05:14 PM | #634 |
Some friends called round & we went to the NSRA at Trinity Park on Sunday
08-31-2015, 07:40 PM | #635 |
yoshi, nice looking rides...Jim
my build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=459839 Jimbo's long bed step build:http://67-72chevytrucks.com/vboard/s...t=464626<br /> |
09-01-2015, 12:17 PM | #636 |
Hung all the front tin to help with bolt inventory. Here is a picture of the tin and a bag of bolts that have lost their label. I keep assembly groups together and spent half an hour trying to figure out what these are for; one set of 5 5/16 bolt s and nuts, 8 5/16 nut with washer in two lengths, and 3 each 5/16 shoulder and hex bolts. Front clip, hood, doors and bed bolts are accounted for. All chassis and drive train is installed. Any ideas????
09-01-2015, 03:11 PM | #637 |
09-03-2015, 07:01 PM | #638 |
09-03-2015, 08:49 PM | #639 |
If I was closer my friend I would take you over for a spin...
09-03-2015, 09:19 PM | #640 |
Loving the truck Ashley, i have a big soft spot for the 57's (miss the one i had). Prayers with you for the recovery.
55.1 GMC Suburban Hydramatic |
09-03-2015, 10:01 PM | #641 |
A320 Pilot/USAF Retired
Truck looks great Russell! Makes me want to do a patina blue on mine!!
JJ My 1957 build: http://67-72chevytrucks.com/vboard/s...d.php?t=334552 http://www.trifive.com/forums/showthread.php?t=22037 Instagram - Chuckdriver57 |
09-05-2015, 10:41 PM | #642 |
Just finished installing a lower bearing in my stock column to use with on my Camaro clip, I bought 2 qty-R12zz bearings for $6 delivered off EBay, Actually only needed 1(+1 spare)
I cut the stock column and shaft off almost flush with the gear box I then cut the tapered part of the column off so I have about 1 1/2" of shaft extended the bearing is .030 larger than the ID of the column so I cut 4 slits in the end of the column and bent each tab of the column out slightly to accept the bearing. I then welded a 7/8" washer on the end of the column and welded up the slits and ground smooth. Just had to weld slow not to overheat the bearing. Simple & smooth $3 solution , No need for a $70-$80 column bearing saver. +++++++++My prayers are with you Russell.++++++++++++ Last edited by 1958Warrior; 09-05-2015 at 10:52 PM. |
09-05-2015, 11:13 PM | #643 |
Russell, we are keeping you in our daily prayers.
09-06-2015, 11:26 AM | #644 |
Well it wasn't today, it was a few days ago! I purchased the plate to relocate the water pump on a 62 235 sitting in a 49 3100. The plate allows you to run the earlier water pump on the later 235 so the fan will actually be almost center on the radiator.
I followed the direction that came with the plate, however I couldn't get it to stop leaking with out the gaskets. So I ended up using both gaskets with sealer and so far so good. Was also able to use the stock lower radiator hose. That's nice and clean now. Yes the directions recommend just using sealer no gaskets! No Bueno |
09-07-2015, 12:59 AM | #645 |
washed the truck and took some pics!
Frank 1957 Chevy 3100 2000 Silverado z71 SOLD 2012 Ram 1500 Quad Cab 1992 International 4700 |
09-07-2015, 01:19 AM | #646 |
Looking great, Frank! I'm jealous, mine's a pile of parts right now.
No pics because they'd be boring but I stripped my driver's door of EVERYTHING inside and out to drop it off at the sandblaster this week. I'll do the passenger side tomorrow. Painter wants to fit them to the cab and set up the gaps. So far, I'm very pleased with this body man.
'55 Big Window Shortbed, Drive-It-&-Work-On-It slid down the "slippery slope" to a Frame-Off Rodstoration! LQ4/4l85e/C4 IFS/Mustang 8.8 rearend w/3.73's Dan's '55 Big Window "Build" - Well, Kinda! |
09-07-2015, 01:26 AM | #647 |
Been working on this most of the summer instead of driving Clarance J. Finally got the holes in firewall filled in and got the paint on today. Learned a few things about painting that are going to be helpful in the future. Just love working on this old truck. Putting the motor stuff back on tommorrow. One more thing to check off the list. Only 999 more things to go. Yahoo!
You have to have patiences or you'll be one. |
09-07-2015, 12:53 PM | #648 |
much improved. good job.
09-07-2015, 01:18 PM | #649 |
Looks very good Earl!
09-07-2015, 02:11 PM | #650 |
Looks great!
