09-20-2016, 10:54 PM | #626 |
Re: My suburban's Twisted Little Sister
Awesome work Dale
My 63 GMC Panel Slow Build http://67-72chevytrucks.com/vboard/s...=1#post5457281 63 |
09-24-2016, 09:14 PM | #627 | ||
Thanks Nik. It's good to be back. Quote:
Thanks Palf Thanks Pirate After we got the rail changed we decided to modify the drivers side of the frame to make a new style of wheelchair lift in the pick up.Doing the modifications now will slow down the reassembly but it's easier with the body off. To start off we removed the exhaust, trailing arms and the crossmember. Stay tuned next week for more updates
Dale ---------------- My suburban's Twisted Little Sister http://67-72chevytrucks.com/vboard/s...d.php?t=655167 |
09-26-2016, 08:44 PM | #628 |
Today we got started on the new trailing arm crossmember. To make more space we are moving the crossmember back 9 inches so we chopped that amount out of the trailing arms then welded them back together. Then we remounted to the rear axle
09-27-2016, 01:07 AM | #629 |
Clever Clever Clever.
Amazing how necessity is the mother of invention. As always, great to see your updates. And of course the doggy assistant. They make a difference too.
MY BUILD LINK: http://67-72chevytrucks.com/vboard/s...585901]Redneck Express - 1966 C10 Short Fleetside MY USA ROADTRIPS http://forum.retro-rides.org/thread/...2018-humdinger IF YOU CAN'T FIX IT WITH A HAMMER, YOU'VE GOT AN ELECTRICAL PROBLEM MATE. |
09-28-2016, 11:51 PM | #630 |
Quality work! Anxiously awaiting the next installment.
1967 C10 Suburban 454/TH400/3.07's An Average Joe and His 'Burb: http://67-72chevytrucks.com/vboard/s...d.php?t=775843 |
09-29-2016, 07:41 PM | #631 | |
Thanks Joe The next instalment is coming up. Today we used the plasma cutter to split one side of a 2X2. Then we slid it over the bottom of the drivers side frame rail and tacked it in place.
09-30-2016, 08:11 AM | #632 |
Neat idea. I see great things coming.
http://67-72chevytrucks.com/vboard/s...d.php?t=648459 https://67-72chevytrucks.com/vboard/...d.php?t=769441 1951 MG TD 1967 Jeep CJ5 1.9L TDI 33X13.5X15 Mud Grapplers. 1952 GMC 9700 p/u 7.3L diesel on air, dually |
10-06-2016, 08:17 PM | #633 |
Thanks Lower
Today we finished the new trailing arm crossmember and welded and bolted it in place. Then we made the inside rail of the box we are making and then set it in place.
10-06-2016, 10:45 PM | #634 |
That is some serious steel frame you got going there.
10-07-2016, 12:32 PM | #635 |
Wow that is gonna be one beefy frame!
Nik...................____ 62 lwb c10 step-side 261 5 spd .........________//__{\_____ ,,,,,,,/__(O)___//___/__(O)_/ my build thread. Sending unit solution |
10-07-2016, 12:49 PM | #636 |
Serious frame modification.
10-12-2016, 02:23 PM | #637 |
Better to be over built than under built.
Well I don't want my butt dragging on the ground I really do like to cut things up. After a whole bunch of welding we have finally got to the point of cutting the original frame out. Here.s a couple of pictures of where we are now
10-13-2016, 03:57 PM | #638 |
Nice work!
10-13-2016, 06:29 PM | #639 |
I totally agree!! Looks great.
10-13-2016, 07:25 PM | #640 |
Looks great Dale, keep the show going
10-19-2016, 09:22 PM | #641 |
Thanks guys. I'm glad you're following along on the slight detour on the '67. Hopefully we'll get back to the Twisted Little Sister fairly soon.
We boxed the original frame forward of the cut out section and welded the boxing plates to the new frame. We also had to reroute the exhaust. Here it's just tacked together. We should have the welding done soon before the weather gets too cool
10-19-2016, 11:25 PM | #642 |
I take it you won't be boxing both sides then?
10-26-2016, 01:32 PM | #643 |
No, the boxing only extends about 12" ahead and behind the section we cut out of the drivers side frame rail.
We finished most of the welding so we pushed the frame back inside out of the cold weather. Then we carefully lowered the cab and box down on the frame
10-26-2016, 07:45 PM | #644 |
That was some impressive frame fabrication!
Dale, is that a combination tonneau cover and tailgate? Very cool look. |
10-27-2016, 03:38 AM | #645 |
That last chassis photo really shows the extent to which you have to modify your life to get from A to Z with a modicum of coolness.
That's some serious editing of the original design just to fit it around you. Amazed as always Dale.
10-27-2016, 10:05 AM | #646 |
Looks awesome
10-27-2016, 10:50 AM | #647 |
Looking great Dale, she'll be done in no time
10-31-2016, 08:16 AM | #648 |
Beautiful craftsmanship.
Black 93 CCLB 3500 6.5 diesel, GV OD, TCI Ez-TCU controlled 4L80E, back on road 10/25/16 after sitting 4 years. 96 ECLB 2500, 6.5 diesel, auto, gone. |
10-31-2016, 04:55 PM | #649 |
That frame looks great, should be nice and strong for your lift.
10-31-2016, 08:41 PM | #650 | |||
Thanks Pirate Thanks Nik. Hopefully I'll get a test drive before the snow arrives. Thanks DJ. Quote:
Today we installed the rad saddle and both front fenders so we could check that we had solved our panel fitment issues. Good news, things are looking good.
