03-05-2008, 08:22 AM | #651 |
A guy with a truck
Re: Joined the Short Wheelbase Club *69 Tahoe Project*
I painted my slots too. I hate dirty slots... or do I?
-Chris Instagram _elgringoloco_ '70 Short-Wide How to: Ruin a perfectly good C10 ‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd '72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD) '72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD) '05 Yukon Daily Driven (not so stock) Yukon (SOLD) ‘07 Yukon Denali (daily) Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy Last edited by gringoloco; 03-05-2008 at 08:22 AM. |
03-05-2008, 08:25 AM | #652 | ||
I agree on the rust too, but those holes and slots would not be cleaned by the pads. |
03-05-2008, 11:20 PM | #653 |
Just looking out for you...... I picked my banjo bolts up at the Chevy dealership. Probably could have gotten them elsewhere, but I know I got the correct ones. I'll be back in FL in 2 weeks and then I get to play with new brakes, new headers and maybe a small engine upgrade, , .
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 |
03-06-2008, 01:11 AM | #654 |
Ya know..., if ol' Friz could bottle that motivation and resourcefulness he has flowing from every pore, he could be a rich man...
1969 C10 Suburban, 396cid, Turbo 400, 9" F***, Disk brakes all around 1968 C10 Suburban, 350cid, 700R4, bent frame 1968 C20 Suburban, no motor, trans or interior (SOLD!) 1953 Packard Ambulance 1992 Caprice wagon |
03-06-2008, 08:38 AM | #655 |
PROJECT 7DEUCE
Hey mike you have any pic of those headders installed?
GO BIG GREEN GO DUCKS MEMBER #6377 72 k-5 daily driver 6'' lift 35'' 350-350-205 slowly getting rust free. Project "7DEUCE" check out my build http://67-72chevytrucks.com/vboard/s...d.php?t=267665 Tim Powell..R.I.P EastSideLowlife..... R.I.P.. |
03-07-2008, 03:45 AM | #656 |
go cyclones
That looks pretty awesome. nice attention to detail
03-09-2008, 04:09 AM | #657 | ||
Nope. But I may have a big change coming my way that will allow for a TON of progress. Don't want to jinx it quite yet though... I promise I'll post pics as soon as they are between the frame rails. Thanks Here's another little tid-bit. These are now tacked in place: |
03-09-2008, 09:09 PM | #658 |
C10 Club Tennessee
hey friz, do those trailer fenders come as far over as the factory tubs?? do they make inner covers for them?? Thinking about using those on my roadster
Bryan www.gmtruckshow.com Project "Andes"-Halen's First Truck Project: Patina Burb for he is God’s servant for your good. But if you do wrong, be afraid, for he does not bear the sword in vain. For he is the servant of God, an avenger who carries out God’s wrath on the wrongdoer. Romans 13:4 |
03-09-2008, 09:22 PM | #659 |
howdy. that thing is SICK!! it looks like you do excellent work. much respect. hope to see it when its done, can't wait. take care.
03-09-2008, 10:00 PM | #660 |
You have'nt finished that thing yet!! Slacker I love the wheel wells, one you make a sheet metal cover for the insdie and stitch them up it will give a nice almost factory look. What are your plans for teh floor, metal or wood?
Kevin LFD Inc. |
03-09-2008, 10:49 PM | #661 | ||
I know man... I will do walls on both sides of the tubs. The outer walls will be more vertical than factory. On the inner walls I will use sections from the OG tubs along with extra material. The factory sections will provide the 2 rows of bead rolls. I'm going with stained wood/chrome strips in the back. Not sure about the notch cover yet, but I'm thinking I may use the wood there too (planks up/over). Last edited by Frizzle Fry; 03-10-2008 at 02:22 AM. |
03-10-2008, 12:30 AM | #662 |
Slicked & painted sheet metal w/similar beads like the sides of the OE wheel tubs? Might help tie it together?
03-10-2008, 01:41 AM | #663 |
03-10-2008, 03:54 AM | #664 |
hey frizzle, I may have missed it, but what kind of hose are you using for those rear bags? Is that rubber hyraulic line?
03-10-2008, 07:44 AM | #665 |
It's the DOT air line (some type of poly I think) with a sheathing over it for extra protection.
03-10-2008, 08:06 AM | #666 |
I made the template for the outer tub wall. Then I realized I didn't have any sheets large enough to do it in one piece. So I'll do those another day
This was just to get the rough radius so I wouldn't have a bunch of folds to deal with inside the tub. The installed tub radius is slightly tighter: Then I moved to the inner wall since I had the OG sections that could be fit: The blue line is roughly where the tub starts to roll over and the black line is where I cut according to the template. Because of this the edges required a little hammer/dolly work to flatten them: I'll add the lower section and outer wall after I pick up some larger sheets. But I'll get the other side this far first. |
03-10-2008, 09:28 AM | #667 |
Nice Job!!! I'm liking the factory look your after! Amazing work!
03-10-2008, 09:32 PM | #668 |
those tubbs look great please dont make me spend anymore money
03-11-2008, 12:26 AM | #669 |
Eat My Rust
Looks slick
03-11-2008, 01:38 AM | #670 |
So how do your outer tubs attach to the body? Any pics, I may need ideas someday
Kevin LFD Inc. |
03-12-2008, 08:10 PM | #671 |
soon to be bagged64sub
Very nice project. I have been reading this thread for the last 3 days. I do have to say I had the same idea for the tubs in my 64 burban. Im sure you will make sure the tubs are sealed good to the outside of the body, but I had some tubs installed on my 01 Jimmy and it leaked like hell when it rained because it wasn't sealed properly to the outside wall.
1969 c-10, bagged, Zd, 20" Boyds SOLD! 1964 Suburban COMING SOON Build threadhttp://67-72chevytrucks.com/vboard/s...d.php?t=304726 1965 c-10 long bed 1993 Sierra x-cab 1999 tahoe-4/5 on 22s 2005 Chevy work truck |
03-13-2008, 01:25 AM | #672 |
They will be walled in. Here's the template for the outers:
When I cut the stock tubs out I left the lower/outer sections in place for something to weld to: I'll also shorten and install the braces from the top of the stockers: I'll post up more pics when I fully stitch them in. Last edited by Frizzle Fry; 03-13-2008 at 01:28 AM. |
03-13-2008, 02:17 AM | #673 |
Skinned knuckles
Man Friz!! I can't, not, make a comment about this... I've been following this build religiously, and I have to say, DAM NICE!!! I must see this in person and meet the great Frizzle Fry someday!
'72 C-10 longbox soon to be short step! '72 Chevelle (sold in January) '07 Sebring '01 Ranger (I've gotta long commute..) If you try to fail, and succeed, which have you done? My build thread - http://67-72chevytrucks.com/vboard/s...d.php?t=276904 |
03-13-2008, 02:42 AM | #674 |
03-13-2008, 10:09 PM | #675 |
Those tubs look great. How long do you think it'll be before paint?
